jim wrote:> "Ron N." wrote: > > > A spline won't do what you wanted in your example either. A low > > enough degree spline would be the same as linear interpolation, and > > a high degree spline would show "ripples" before and/or after any > > step function. > > Nope that's bad information. Some will and some won't. It depends on the > type of spline interpolation.What type of, say, 4th degree spline will preserve the original points (the OP's request, not mine), be continuous, and not show any overshoot or undershoot when interpolating samples from a unit step function? What kind of 1st degree spline would preserve all the original points and be different from linear interpolation? Or are there non-linear types of splines which are still commonly attributed with a "degree"? IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Convolution-based image interpolation
Started by ●April 23, 2006
Reply by ●April 27, 20062006-04-27
"Ron N." wrote:> What type of, say, 4th degree spline will preserve the original > points (the OP's request, not mine), be continuous, and not > show any overshoot or undershoot when interpolating samples > from a unit step function?It's the same deal as before if you require the spline to pass thru the original points you have the overshoot and undershoot or ripple problem. A more relaxed implementation will be able to transition a step smoothly. There are even spline algorithms that include a tension factor so that you can control how tightly or loosely it follows the original points. Degree 4 and other even degree splines are often not used to avoid the half sample shift they introduce.> > What kind of 1st degree spline would preserve all the original > points and be different from linear interpolation? >To some people "linear" combined with "spline" is an oxymoron given the origins of the meaning of the word spline. But I wasn't disagreeing with those statements. If you have a generalized algorithm for spline construction that allows you to plug in any degree you want, then if you plug-in 1 for degree you usually get linear interpolation, that's true. -jim> Or are there non-linear types of splines which are still > commonly attributed with a "degree"? > > IMHO. YMMV. > -- > rhn A.T nicholson d.0.t C-o-M----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
chris_bore@yahoo.co.uk wrote:> Michel Rouzic wrote: > > who would want to interpolate images by FIRs anyways? > > It is quite common to interpolate images by FIRs. This is especially so > in digital video where natural images are concerned, as it may give the > most pleasing visual effect.Image data is typically not bandlimited in the formal sense. More likely rectangularly windowed samples from local blurring due to some combination of the diffraction Airy disk of the aperature, the MTF distribution due to lens aberations, the Bayer pre-CCD scattering blur, and such. I think this means that their will be aliased high frequency contamination of the samples. Are there any characterisitics of this image noise which might help in the design of an interpolating filter that would be less affected by the high frequency aliasing already contained in the image samples, and produce a "more pleasing visual effect"? IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Ron N. wrote:> jim wrote: > > "Ron N." wrote: > > > > > A spline won't do what you wanted in your example either. A low > > > enough degree spline would be the same as linear interpolation, and > > > a high degree spline would show "ripples" before and/or after any > > > step function. > > > > Nope that's bad information. Some will and some won't. It depends on the > > type of spline interpolation. > > What type of, say, 4th degree spline will preserve the original > points (the OP's request, not mine)I never requested it, I just stated that the way I imagined it it would preserve the original points, now that we're talking about that point, I remember that there are curve interpolations that don't go through the original points, and thus would fix both the scalloping on a ramp and the ripple, I guess.> be continuous, and not > show any overshoot or undershoot when interpolating samples > from a unit step function? > > What kind of 1st degree spline would preserve all the original > points and be different from linear interpolation? > > Or are there non-linear types of splines which are still > commonly attributed with a "degree"? > > > IMHO. YMMV. > -- > rhn A.T nicholson d.0.t C-o-M
