I'm trying to create a custom-spectrum noise sample, basically 1 second of white noise but filtered with a certain response. Its not quite pink or white, its got several peaks and valleys. I've been thinking about doing it like this: Step 1: Use a program like ScopeFIR to create a digital filter so that when white noise is run through it it comes out with the desired output spectrum. Step 2: Take that digital filter, and somehow run actual white noise samples (PCM audio file?) through it to actually create a .WAV file of the noise I want. I think you could probably do this whole thing in Matlab, but I cant afford it, and I cant get the student version. I already have the demo of ScopeFIR, but I dont have anything to process the white noise using the filter I create and output a .wav file. Is there a way to do this thats not expensive? I can program in C, maybe implementing a digital filter in C is simple? (designing it in scopefir first). Or is there another way? Or maybe some freeware program that lets you input a digital filters info and then process wav files with it? Thanks for any suggestions or help!
PCM audio processed by custom digital filter?
Started by ●April 27, 2006
Reply by ●April 27, 20062006-04-27
acannell@wwc.com wrote:> I think you could probably do this whole thing in Matlab, but I cant > afford it, and I cant get the student version.Try scilab or octave. They are free, and very matlab-like. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Anything is possible if you don't know what you are talking about.
