I found a small problem with the code: "real[0] = 2.0*scaler*amplitude[k]; // DC and Nyquist are a little different" what is k in that ? I think it's (n/2-1) but I'm not really sure. Thanks. "robert bristow-johnson" <rbj@audioimagination.com> wrote in message news:1146625438.510983.281330@e56g2000cwe.googlegroups.com...> Robert A. wrote: >> Hello, >> >> After you explained it to me I think I understand now but I'm not >> positive >> yet. > > you're getting very close. here is how i would do it: > > > // size of wavetable. needs to be even, maybe a power or 2. > #define N 128 > > > > double amplitude[N/2]; > double phase[N/2]; > > > // fill them in... > > for (int k=1; k<N/2; k++) > { > amplitude[k] = ...; // amplitude of kth harmonic > phase[k] = ...; // phase of kth harmonic > } > > phase[0] = 0.0; // this could be +/- pi or 0, but nothing else > > // my suggestion is that amplitude[N/2] be zero > > // now make new arrays for the FFT (twice the size) > double real[N]; > double imag[N]; > > // convert first half to rectangular and fill in part of the array > > > double scaler = (double)N/2.0; > // maybe just scaler = 1.0/2.0 if iFFT doesn't scale by 1/N > > real[0] = 2.0*scaler*amplitude[k]; // DC and Nyquist are a little > different > imag[0] = 0.0; // just to make awul damn sure. > > double energy = rea[0]*real[0]; > > for (int k=1; k<N/2; k++) > { > real[k] = scaler*amplitude[k]*cos(phase[k]); > imag[k] = scaler*amplitude[k]*sin(phase[k]); > > energy += rea[k]*real[k] + imag[k]*imag[k]; > } > > // now set the second half to the complex conjugates > > real[N/2] = 0.0; // amplitude[N/2] = zero > imag[N/2] = 0.0; // just to make awul damn sure. > > for (int k=N/2+1; k<N; k++) > { > real[k] = real[N-k]; > imag[k] = -imag[N-k]; > } > > > // I think that part might be messed up > // because of element 0 and element N/2 ? > > // it was, but i fixed it. > > // then do the inverse FFT > > FFT(-1, N, real, imag); > // i am presuming that iFFT has a 1/N in it. > > // then my wavetable is the real components ? > // yup. the imag components should all be zero. > > double wavetable[N]; > double imag_error_limit = log((double)N)*energy*1e-15; > int imag_error = 0; > > for (int n=0; n<N; n++) > { > wavetable[n] = real[n]; > if (imag[n]*imag[n] > imag_error_limit) > { > imag_error++; > } > } > > if (imag_error) > { > printf("i did something wrong. imag_error = %d", imag_error); > } > > // data is in wavetable[] and imag_error should be 0. > // scaling of wavetable[] can be done properly by scaling amplitude[] > correctly. > > > so, you had the right idea. does this do it for you? > > BTW, i forgot to mention that the DFT (which the FFT is a fast > implementation of) maps a discrete-time periodic function of period N > to another discrete-frequency periodic function of period N. so the > result is "perfectly loop-able". if you want to get more anal > wavetable mathematics than you would ever want, take a look at: > > http://www.musicdsp.org/files/Wavetable-101.pdf > > r b-j >
IFFT to Wavetable ?
Started by ●April 29, 2006
Reply by ●May 14, 20062006-05-14
Robert A. wrote:> I found a small problem with the code: > > "real[0] = 2.0*scaler*amplitude[k]; // DC and Nyquist are a little different" > > what is k in that ? I think it's (n/2-1) but I'm not really sure.oooops. it's 0. real[0] is the real part of the DC componet and amplitude[0] is the amplitude of the 0th harmonic, or the DC component. dunno what "n" is. it was from copy/paste and modify and i didn't do it perfectly right. for musical waveforms, if i were you i would set the DC and Nyquist components to zero and then there is no confusion with them. particularly Nyquist (N/2) should be set explicitly to zero. save yourself headache. r b-j
