Hi I've read a book about adaptive noise reduction methods. I don't understand why the original signal (without noise) is needed in Wiener filtering, RLS filtering, LMS filtering... I mean, in most of the cases, you don't have any reference of the original signal when you want to reduce noise in a noisy signal! (otherwise, if you already know how the original signal is, why do you have to handle the noisy signal??) Maybe there is something that I don't understand about adaptive filtering philosophy... Could you help me? Thanks a lot Thom
Adaptive filters
Started by ●May 3, 2006
Reply by ●May 3, 20062006-05-03
"thom" <soniceric@hotmail.com> wrote in message news:S4OdnSvnH_a-U8XZnZ2dnUVZ_sadnZ2d@giganews.com...> Hi > > I've read a book about adaptive noise reduction methods. I don't > understand why the original signal (without noise) is needed in Wiener > filtering, RLS filtering, LMS filtering... I mean, in most of the cases, > you don't have any reference of the original signal when you want to > reduce noise in a noisy signal! (otherwise, if you already know how the > original signal is, why do you have to handle the noisy signal??) > > Maybe there is something that I don't understand about adaptive filtering > philosophy... Could you help me? > > Thanks a lotThe reference is used in the adaptation. Don't think of the reference as "fixed". It can vary - and that's one of the good things about adaptive filters. Indeed, if you knew everything about the reference, and it was stable, then maybe you could design a filter once and for all to do what you need. Similar comments can be made for adaptive line cancellers. The lines being cancelled can come and go and move around. Otherwise you might apply some notch filters. Fred
thom wrote:> Hi > > I've read a book about adaptive noise reduction methods. I don't > understand why the original signal (without noise) is needed in Wiener > filtering, RLS filtering, LMS filtering... I mean, in most of the cases, > you don't have any reference of the original signal when you want to > reduce noise in a noisy signal! (otherwise, if you already know how the > original signal is, why do you have to handle the noisy signal??) > > Maybe there is something that I don't understand about adaptive filtering > philosophy... Could you help me? > > Thanks a lot > > ThomThe reference signal could also be the noise itself. Furthermore, it is not necessary that the noise is the exact noise which has "ruined" the original signal. I believe it is sufficient that the reference noise has the same characteristics (e.g. autocorrelation) as the noise in the measured signal. Thus sometimes it is possible to record the noise with a second microphone and use that as a reference signal. -- Jani Huhtanen Tampere University of Technology, Pori
Sorry I don't understand... Do I need a reference of the original signal when I have only the noisy version of the signal, to implement adaptive filtering? If the answer is "yes", can I build this reference from the noisy signal?? Thom
"thom" <soniceric@hotmail.com> wrote in message news:W_CdnfCqXtjxSMXZRVn-gg@giganews.com...> Sorry I don't understand... Do I need a reference of the original signal > when I have only the noisy version of the signal, to implement adaptive > filtering? If the answer is "yes", can I build this reference from the > noisy signal?? >Thom, It sounds like you don't fully understand what a system looks like when it has an adaptive filter in it. Here are some examples where "LMS" is the filter that adapts / changes: input--------->------------------------------->(+)----+----> e[n] ^ | . ^ | . | | . | | error noise ->----------------------->[LMS]------------+ | feedback ^ | to | | control filter +--------------------+ changes Adaptive line-cancelling filter LMS adaptive filter adjusts to minimize e[n] which cancels noise in the signal by subtracting filtered version of noise. The LMS filter adjusts the amplitude and phase of its periodic input components to cancel the periodic noise component in the signal. ************************************************************************ error feedback to control filter changes +--------------------+ | | | | | | input------+---------------------|------------>(+)----+----> e[n] | | ^ | | | | +-----------+ v | +---| Delay |-->[LMS]------------+----------> o[n] +-----------+ Adaptive enhancer LMS adaptive filter adjusts to minimize e[n] which cancels signal o[n] ideally contains only signal ***************************************************************************** error feedback to control filter changes +--------------------+ | | | | | | input---+------------------------|------------>(+)----+----> e[n] | | ^ | | | | +-----------+ v | +--| Delay |------>[LMS]------------+----------> o[n] | +-----------+ | | | | | | v | +--------------------->[LMS]------------+----------> p[n] Adaptive predictor LMS adaptive filter adjusts to minimize e[n] which uses a delayed version of the input as a reference signal. So, the filter adapts to "predict" the input to the delay. Then, input the real time signal into the same filter to view a prediction of the input. ************************************************************************** So, only the line canceller needs a "reference" and, indeed, the reference can be different than the version of interference that's in the signal. Often it's possible for the reference to be a *better / higher SNR* version of the interference. For example, an accelerometer on a machine that causes interference elsewhere - with the objective to remove the interference at that latter location / signal. There is *no* notion really of an "original signal", just the signal and the interference that exist *now*. The point of being adaptive is to adjust to accomodate changes in both of them. Again, if the signal and interference were unchanging then adaptation would be uncessary unless it's just a handy way of designing a fixed filter. It's usually not worth it - but may be in some circumstances. Fred
In some cases you do know the signal exactly (or at least with a high probability). For example, in QPSK there are only four possible signals that were transmitted. If you assume the one that is closest to what you actually received then you essentially do know the original signal. In other cases all you really need to know is the statistics of the original signal. For example, you know that a speech waveform is fairly predictable at least over short intervals. Noise on the other hand is totally unpredictable. So if I use an adaptive filter to predict a voice signal and compare it against the noisy voicy signal I actually received I can assume that everything that wasn't predictable was noise and subtract it out. -Clark "thom" <soniceric@hotmail.com> wrote in message news:S4OdnSvnH_a-U8XZnZ2dnUVZ_sadnZ2d@giganews.com...> Hi > > I've read a book about adaptive noise reduction methods. I don't > understand why the original signal (without noise) is needed in Wiener > filtering, RLS filtering, LMS filtering... I mean, in most of the cases, > you don't have any reference of the original signal when you want to > reduce noise in a noisy signal! (otherwise, if you already know how the > original signal is, why do you have to handle the noisy signal??) > > Maybe there is something that I don't understand about adaptive filtering > philosophy... Could you help me? > > Thanks a lot > > Thom
Normally you have two inputs - SIgnal + Noise and Nosie alone for the ref. You don't need the 'true' signal - as you say what's the point! The biggest trouble is getting noise alone. In speech + noise we can get this during pauses in the speech - harder than it sounds otherwise we woudl have cracked all teh problems by now. Tam
Reply by ●May 4, 20062006-05-04
thom wrote:> Hi > > I've read a book about adaptive noise reduction methods. I don't > understand why the original signal (without noise) is needed in Wiener > filtering, RLS filtering, LMS filtering... I mean, in most of the cases, > you don't have any reference of the original signal when you want to > reduce noise in a noisy signal! (otherwise, if you already know how the > original signal is, why do you have to handle the noisy signal??) > > Maybe there is something that I don't understand about adaptive filtering > philosophy... Could you help me?Thom, I already described to you how adaptive filtering (in predictor configuration) with only signal + noise as input can be used for noise reduction, here (the "Spectral Subtraction" thread): http://groups.google.ch/group/comp.dsp/msg/162e07132ee98e70 Regards, Andor
