How much benefit can adaptive equalization really get you in a packet transmission system over multipath channel? Since one will need to do synchronization before training the equalizer, it seems to me that synch will be the first one to fail most of the time if ISI is really serious. So that means you must have a synchronization scheme that can deal with serious ISI first. Or you will have to do blind equalizer training, then do synchronization. Is there any expert here willing to share some thoughts? Thanks. Min
adaptive equalization benefit
Started by ●May 8, 2006
Reply by ●May 8, 20062006-05-08
mguo wrote:> How much benefit can adaptive equalization really get you in a packet > transmission system over multipath channel? Since one will need to do > synchronization before training the equalizer, it seems to me that synch > will be the first one to fail most of the time if ISI is really serious. > > So that means you must have a synchronization scheme that can deal with > serious ISI first. Or you will have to do blind equalizer training, then > do synchronization. > > Is there any expert here willing to share some thoughts? > > Thanks. > Min >Without adaptive equalisation only the most elementary, low bit density, forms of transmissions will generally work. There are plenty of symbol synchronisation schemes which don't care much about serious ISI. They may pull in faster when there is no ISI, but they will still pull in when there is. Carrier recovery can also be accomplished without decoding the symbols, so ISI is no big deal there, either. If you have a very rounded constellation, like V.34, blindly recovery the carrier might be tough. Most constellations have corners sticking out, even with high ISI, and you can lock to those. Once you have nailed down the symbol timing, and stopped the constellation spinning, using algorithms like CMA to train an equaliser will gradually make the symbols come into focus through the ISI, and the output error rate will fall to something acceptable. Once you are recovering the data accurately, and you can switch to decision feedback adjustment of the parameters if you so desire. Steve
Reply by ●May 9, 20062006-05-09
>mguo wrote: >> How much benefit can adaptive equalization really get you in a packet >> transmission system over multipath channel? Since one will need to do >> synchronization before training the equalizer, it seems to me thatsynch>> will be the first one to fail most of the time if ISI is reallyserious.>> >> So that means you must have a synchronization scheme that can dealwith>> serious ISI first. Or you will have to do blind equalizer training,then>> do synchronization. >> >> Is there any expert here willing to share some thoughts? >> >> Thanks. >> Min >> >Without adaptive equalisation only the most elementary, low bit density,>forms of transmissions will generally work. > >There are plenty of symbol synchronisation schemes which don't care much>about serious ISI. They may pull in faster when there is no ISI, but >they will still pull in when there is. > >Carrier recovery can also be accomplished without decoding the symbols, >so ISI is no big deal there, either. If you have a very rounded >constellation, like V.34, blindly recovery the carrier might be tough. >Most constellations have corners sticking out, even with high ISI, and >you can lock to those. > >Once you have nailed down the symbol timing, and stopped the >constellation spinning, using algorithms like CMA to train an equaliser >will gradually make the symbols come into focus through the ISI, and the> output error rate will fall to something acceptable. > >Once you are recovering the data accurately, and you can switch to >decision feedback adjustment of the parameters if you so desire. > >Steve >Hi Steve, Thanks for your reply. Could you give an example of an symbol timing scheme that does not care about multipath effect? System still need to establish the starting point for the training sequence. -Min
Reply by ●May 10, 20062006-05-10
mguo wrote:>> mguo wrote: >>> How much benefit can adaptive equalization really get you in a packet >>> transmission system over multipath channel? Since one will need to do >>> synchronization before training the equalizer, it seems to me that > synch >>> will be the first one to fail most of the time if ISI is really > serious. >>> So that means you must have a synchronization scheme that can deal > with >>> serious ISI first. Or you will have to do blind equalizer training, > then >>> do synchronization. >>> >>> Is there any expert here willing to share some thoughts? >>> >>> Thanks. >>> Min >>> >> Without adaptive equalisation only the most elementary, low bit density, > >> forms of transmissions will generally work. >> >> There are plenty of symbol synchronisation schemes which don't care much > >> about serious ISI. They may pull in faster when there is no ISI, but >> they will still pull in when there is. >> >> Carrier recovery can also be accomplished without decoding the symbols, >> so ISI is no big deal there, either. If you have a very rounded >> constellation, like V.34, blindly recovery the carrier might be tough. >> Most constellations have corners sticking out, even with high ISI, and >> you can lock to those. >> >> Once you have nailed down the symbol timing, and stopped the >> constellation spinning, using algorithms like CMA to train an equaliser >> will gradually make the symbols come into focus through the ISI, and the > >> output error rate will fall to something acceptable. >> >> Once you are recovering the data accurately, and you can switch to >> decision feedback adjustment of the parameters if you so desire. >> >> Steve >> > > > Hi Steve, > > Thanks for your reply. Could you give an example of an symbol timing > scheme that does not care about multipath effect? System still need to > establish the starting point for the training sequence. > > -Min >Try http://ieeexplore.ieee.org/iel4/5559/14886/00679062.pdf?arnumber=679062 for a quick and easy to follow introduction to the topic. I don't quite understand the pictures at the end, though. The first one is supposed to be the starting point, but doesn't show the effects of the carrier not being locked - i.e. the constellation should be spinning. Steve
>mguo wrote: >>> mguo wrote: >>>> How much benefit can adaptive equalization really get you in apacket>>>> transmission system over multipath channel? Since one will need todo>>>> synchronization before training the equalizer, it seems to me that >> synch >>>> will be the first one to fail most of the time if ISI is really >> serious. >>>> So that means you must have a synchronization scheme that can deal >> with >>>> serious ISI first. Or you will have to do blind equalizer training, >> then >>>> do synchronization. >>>> >>>> Is there any expert here willing to share some thoughts? >>>> >>>> Thanks. >>>> Min >>>> >>> Without adaptive equalisation only the most elementary, low bitdensity,>> >>> forms of transmissions will generally work. >>> >>> There are plenty of symbol synchronisation schemes which don't caremuch>> >>> about serious ISI. They may pull in faster when there is no ISI, but >>> they will still pull in when there is. >>> >>> Carrier recovery can also be accomplished without decoding thesymbols,>>> so ISI is no big deal there, either. If you have a very rounded >>> constellation, like V.34, blindly recovery the carrier might be tough.>>> Most constellations have corners sticking out, even with high ISI, and>>> you can lock to those. >>> >>> Once you have nailed down the symbol timing, and stopped the >>> constellation spinning, using algorithms like CMA to train anequaliser>>> will gradually make the symbols come into focus through the ISI, andthe>> >>> output error rate will fall to something acceptable. >>> >>> Once you are recovering the data accurately, and you can switch to >>> decision feedback adjustment of the parameters if you so desire. >>> >>> Steve >>> >> >> >> Hi Steve, >> >> Thanks for your reply. Could you give an example of an symbol timing >> scheme that does not care about multipath effect? System still need to >> establish the starting point for the training sequence. >> >> -Min >> >Try >http://ieeexplore.ieee.org/iel4/5559/14886/00679062.pdf?arnumber=679062 >for a quick and easy to follow introduction to the topic. I don't quite >understand the pictures at the end, though. The first one is supposed to>be the starting point, but doesn't show the effects of the carrier not >being locked - i.e. the constellation should be spinning. > >Steve >Steve, Could you post the title of the article? I can't access the link for some reason. This is a very interesting topic. Thank you very much. -Min
