For starters, I'm still a newbie muddling my way through the various texts and fourier terminologies. I'm of the impression that given an FFT with an odd size. Zero padding the FFT to the next power of two amounts will do the trick. Barring efficiency reasons with regards to odd sizes, I'm only interested in how the padded and non padded version could be equivalent. Now utilizing matlab as my analysis tool. Given:>> x=[0,1,2,3,4]x = 0 1 2 3 4>> y=fft(x)'y = 10.0000 -2.5000 - 3.4410i -2.5000 - 0.8123i -2.5000 + 0.8123i -2.5000 + 3.4410i Now zero pad to the next power of two.>> x=[0,1,2,3,4,0,0,0]x = 0 1 2 3 4 0 0 0>> y=fft(x)'y = 10.0000 -5.4142 + 4.8284i 2.0000 - 2.0000i -2.5858 + 0.8284i 2.0000 -2.5858 - 0.8284i 2.0000 + 2.0000i -5.4142 - 4.8284i>>How is the result from the result from the padded and non-padded version equivalent or is there my understanding flawed? Thanks in advance
zero padding radix - 2 FFT
Started by ●May 13, 2006
Reply by ●May 13, 20062006-05-13
Hallo, In the N-points signal x(t), usually we pad with zeors up to L , L>N so it becomes L-point DFT. There is no much eye catching information in time domain regarding to this padding, but in the frequency this will result a better frequency resolution. Therefore, from your result its showed a better resolution than unpadded one. This also can be named as spectral interpolation. Regards Mohadig Widha
The larger the size of the DFT, the smaller the sampling interval in the frequency domain. If you have, for instance, x = [1:1000]; X = fft( x, [], ); Xpadded = fft( x, 4096 ); Both X and Xpadded represent the same function, viz. the spectrum of x, the difference is in the sampling of the spectrum. The sample spacing for X is 2*pi/1000, while for Xpadded it is 2*pi/4096. Zero-padding does not increase resolution, it only decreases the sampling interval.
On 13 May 2006 12:29:50 -0700, forums_mp@hotmail.com wrote:>For starters, I'm still a newbie muddling my way through the various >texts and fourier terminologies. I'm of the impression that given an >FFT with an odd size. Zero padding the FFT to the next power of two >amounts will do the trick. Barring efficiency reasons with regards to >odd sizes, I'm only interested in how the padded and non padded version >could be equivalent. Now utilizing matlab as my analysis tool. >Given: > >>> x=[0,1,2,3,4] >x = > 0 1 2 3 4 >>> y=fft(x)' > >y = > 10.0000 > -2.5000 - 3.4410i > -2.5000 - 0.8123i > -2.5000 + 0.8123i > -2.5000 + 3.4410i > >Now zero pad to the next power of two. > >>> x=[0,1,2,3,4,0,0,0] >x = > 0 1 2 3 4 0 0 0 >>> y=fft(x)' > >y = > > 10.0000 > -5.4142 + 4.8284i > 2.0000 - 2.0000i > -2.5858 + 0.8284i > 2.0000 > -2.5858 - 0.8284i > 2.0000 + 2.0000i > -5.4142 - 4.8284i > >>> > >How is the result from the result from the padded and non-padded >version equivalent or is there my understanding flawed? > >Thanks in advanceHi forums_mp, ah ha, you're startin' to learn about the discrete Fourier transform. This is good. The sequence x=[0,1,2,3,4] has continuous Fourier transform (an infinite-resolution transform) that is called the Discrete-time Fourier Transform, the "DTFT". For simple sequences, that DTFT can be obtained with pencil & paper algebra. However, we can approximate (compute) the DTFT of x on a computer by "padding' the x sequence with many many zero-valued samples and perform a very large-sized DFT (using the FFT algorithm). OK, here's where I'm going. The discrete Fourier transform (DFT) of x computes a *sampled* version of the DTFT of x. Computing a 5-point DFT of x will give your five samples on the full DTFT curve for the time sequence x. If you pad x with three zero-valued samples and perform an 8-point DFT you'll obtain eight samples of the full DTFT curve for the time sequence x. If you pad x with 2043 zero-valued samples and perform an 2048-point DFT you'll obtain 2048 samples of the full DTFT curve for the 5-sample sequence x. In this case, you'll have a very accurate (very highly sampled) representation of the true Fourier tansform of your original 5-sample x sequence. Hope that made some sense. Good Luck, [-Rick-]
forums_mp@hotmail.com wrote:> For starters, I'm still a newbie muddling my way through the various > texts and fourier terminologies. I'm of the impression that given an > FFT with an odd size. Zero padding the FFT to the next power of two > amounts will do the trick. Barring efficiency reasons with regards to > odd sizes, I'm only interested in how the padded and non padded version > could be equivalent. Now utilizing matlab as my analysis tool. > Given: > >>> x=[0,1,2,3,4] > x = > 0 1 2 3 4 >>> y=fft(x)' > > y = > 10.0000 > -2.5000 - 3.4410i > -2.5000 - 0.8123i > -2.5000 + 0.8123i > -2.5000 + 3.4410i > > Now zero pad to the next power of two. > >>> x=[0,1,2,3,4,0,0,0] > x = > 0 1 2 3 4 0 0 0 >>> y=fft(x)' > > y = > > 10.0000 > -5.4142 + 4.8284i > 2.0000 - 2.0000i > -2.5858 + 0.8284i > 2.0000 > -2.5858 - 0.8284i > 2.0000 + 2.0000i > -5.4142 - 4.8284i > > > How is the result from the result from the padded and non-padded > version equivalent or is there my understanding flawed?They are both sets of points on (samples of) the same underlying continuous complex curve, just spaced differently. The longer you pad your sequence the closer the sample points get to each other in the frequency dimension. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●May 14, 20062006-05-14
Rick Lyons wrote: [.....]> > ah ha, you're startin' to learn about > the discrete Fourier transform. This is good.Indeed. How do you folks do it :)? It seems intimidating - but I suspect this is because I'm new to things so I have more questions than answers. [...]> > If you pad x with 2043 zero-valued samples and > perform an 2048-point DFT you'll obtain 2048 samples > of the full DTFT curve for the 5-sample sequence x. > In this case, you'll have a very accurate > (very highly sampled) representation of > the true Fourier tansform of your original > 5-sample x sequence. > > Hope that made some sense.Got it. If only I'd have seen that in the text. Part of my curiosity stemmed from a project I'm perusing here, where taylor weights ( still haven't quite gotten my head around what the taylor window is buying me but I'll keep reading ) was precomputed. The weights ( an array 32 deep ) were then applied (multiplied) to a sequence - call it x of size 32.. An forward transform was run on the result. I'm thinking.. lets take this a step further. How about a forward transform 64 deep. IOW: zero pad to 64. The question then became would the result be the same? I now konw my answer lies in your paragraph above. Thanks alot
