Hi, I am deveoping a fec system. i am using convolution codes (K=7, code rate=1/2). i did some simulations in MATLAB to test convolution decoder's performance against burst errors. I took 128 bit frame of random data. Then used convenc function to encode it. and then introduced burst errors by selecting some bit randomly and making following bits zero (total number of consecutive bits which become zero = burst length chosen). Then i decoded it using vitdec function. i did this for 10000 frames and for different burst length. I kept burst length constant for one iteration over 10000 frames. I varied burst lenght from 4 to 24 in steps of 2. i was expecting that BER will go up monotonically as burst length increses. but result was different. BER increased as burst length incresed from 4 to 10. But then BER decreased when burst length increased from 10 to 16. And BER again increased after that. I am confused with such behaviour. Can anybody explain this behaviour? Actually i want to test if use of interleaver improves convolution decoder's performance against burst errors. Thank you, I can send matlab *.m file if required. -Viraj
strange performance of convolution decoder for burst errors
Started by ●May 17, 2006
