Hi There I'm fairly new to FFT and the like and I'm trying to implement the Exocortex.DSP for C# and I have it working but I'm not really sure how to interpret to results? So I pass a 1024 sized array of floats (they are 16 bit audio samples, only the first 700 or 800 are actual values, I've zeroed the rest) to Fourier.FFT(myarray, 512, FourierDirection.Forward) So I'm wondering a few things . . . . the length variable (here I've hard coded 512), what is this length? Then how do I interpret the results of the new values in myarray? I've heard something's about where complex numbers, where two slot represent one complex number? When I graph the resulting array, it doesn't look like most of the FFT graphs I've seen? I'd appreciate a layman's response without to much reference to math, as it not really my strong point. Thanks for your help Carmen Branje Toronto
Exocortex.DSP FFT implimentation? What should my result look like.
Started by ●May 18, 2006
Reply by ●May 18, 20062006-05-18
cbranje@gmail.com wrote:> Hi There > > I'm fairly new to FFT and the like and I'm trying to implement the > Exocortex.DSP for C# and I have it working but I'm not really sure how > to interpret to results? > > So I pass a 1024 sized array of floats (they are 16 bit audio samples, > only the first 700 or 800 are actual values, I've zeroed the rest) to > > Fourier.FFT(myarray, 512, FourierDirection.Forward) > > So I'm wondering a few things . . . . > > the length variable (here I've hard coded 512), what is this length?At the risk of being obvious, It's the length of the Fourier transform. Take a step backwards and look at it like this: You have N data points: x[0], x[1], ..., x[N-1]. When you take the Fourier transform of those N points, you are answering the following question: What are the coefficients of the function f(t) which has the form f(t) = a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) - b_k sin(2 pi k / N t) ) + a_{N/2} cos(pi t), such that f(n) = x[n] ? That is, you are fitting a periodic function (f(n) = f(n+N)) through the data points x[n]. The DFT computes the coefficients a_k and b_k (sometimes called real and imaginary part of the DFT). Another, but equivalent form of f(t) is f(t) = sum_{k=0}^{N/2} A_k cos(2 pi k / N t + phi_k). The A_k's are called the magnitudes, and the phi_k are called the phases. Together, they form an estimate of the spectrum of the data x[n]. Other names for these coefficients: the a_k's and b_k's are called the rectangular coordinates of the DFT, while the A_k's and the phi_k's are called the polar coordinates of the DFT.> > Then how do I interpret the results of the new values in myarray? I've > heard something's about where complex numbers, where two slot > represent one complex number? When I graph the resulting array, it > doesn't look like most of the FFT graphs I've seen?Usually, FFT routines return the rectangular coordinates of the DFT (look up the documentation of your routine for the exact format - remember that real part = a_k and imaginary part = b_k). For graphing and human interpretation, we prefer the polar coordinates - in addition, we neglect the phi_k and only concentrate on the A_k's. The A_k's can be computed through A_k = sqrt(a_k^2 + b_k^2). Graphs usually plot 20 log(A_k) = 10 log(a_k^2 + b_k^2). This kind of graph should be more familiar to you.> I'd appreciate a layman's response without to much reference to math, > as it not really my strong point. > > Thanks for your help > > > Carmen Branje > TorontoRegards, Andor Zurich
Reply by ●November 11, 20082008-11-11
Hello Is there anyone that can help me. I don't care what the FFT does in the background, all I'm asking is how to impliment it using a 1D array of audio samples. I am using Exocortex.DSP in C#. If someone could respond, refering to elements of C# (array number 1 etc, instead of A_k etc) that would be most helpful. Thanks in advance Carmen Branje>cbranje@gmail.com wrote: >> Hi There >> >> I'm fairly new to FFT and the like and I'm trying to implement the >> Exocortex.DSP for C# and I have it working but I'm not really sure how >> to interpret to results? >> >> So I pass a 1024 sized array of floats (they are 16 bit audio samples, >> only the first 700 or 800 are actual values, I've zeroed the rest) to >> >> Fourier.FFT(myarray, 512, FourierDirection.Forward) >> >> So I'm wondering a few things . . . . >> >> the length variable (here I've hard coded 512), what is this length? > >At the risk of being obvious, It's the length of the Fourier transform. >Take a step backwards and look at it like this: > >You have N data points: x[0], x[1], ..., x[N-1]. When you take the >Fourier transform of those N points, you are answering the following >question: > >What are the coefficients of the function f(t) which has the form > >f(t) = a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) - b_k sin(2 pi >k / N t) ) + a_{N/2} cos(pi t), > >such that f(n) = x[n] ? That is, you are fitting a periodic function >(f(n) = f(n+N)) through the data points x[n]. The DFT computes the >coefficients a_k and b_k (sometimes called real and imaginary part of >the DFT). Another, but equivalent form of f(t) is > >f(t) = sum_{k=0}^{N/2} A_k cos(2 pi k / N t + phi_k). > >The A_k's are called the magnitudes, and the phi_k are called the >phases. Together, they form an estimate of the spectrum of the data >x[n]. > >Other names for these coefficients: the a_k's and b_k's are called the >rectangular coordinates of the DFT, while the A_k's and the phi_k's are >called the polar coordinates of the DFT. > >> >> Then how do I interpret the results of the new values in myarray? I've >> heard something's about where complex numbers, where two slot >> represent one complex number? When I graph the resulting array, it >> doesn't look like most of the FFT graphs I've seen? > >Usually, FFT routines return the rectangular coordinates of the DFT >(look up the documentation of your routine for the exact format - >remember that real part = a_k and imaginary part = b_k). For graphing >and human interpretation, we prefer the polar coordinates - in >addition, we neglect the phi_k and only concentrate on the A_k's. The >A_k's can be computed through > >A_k = sqrt(a_k^2 + b_k^2). > >Graphs usually plot 20 log(A_k) = 10 log(a_k^2 + b_k^2). This kind of >graph should be more familiar to you. > >> I'd appreciate a layman's response without to much reference to math, >> as it not really my strong point. >> >> Thanks for your help >> >> >> Carmen Branje >> Toronto > >Regards, >Andor >Zurich > >
Reply by ●March 17, 20092009-03-17
bump . . .anyone have some new light to shed? Thanks Carmen>Hello > >Is there anyone that can help me. > >I don't care what the FFT does in the background, all I'm asking is howto>impliment it using a 1D array of audio samples. > >I am using Exocortex.DSP in C#. > >If someone could respond, refering to elements of C# (array number 1etc,>instead of A_k etc) that would be most helpful. > >Thanks in advance > >Carmen Branje > >>cbranje@gmail.com wrote: >>> Hi There >>> >>> I'm fairly new to FFT and the like and I'm trying to implement the >>> Exocortex.DSP for C# and I have it working but I'm not really surehow>>> to interpret to results? >>> >>> So I pass a 1024 sized array of floats (they are 16 bit audiosamples,>>> only the first 700 or 800 are actual values, I've zeroed the rest) to >>> >>> Fourier.FFT(myarray, 512, FourierDirection.Forward) >>> >>> So I'm wondering a few things . . . . >>> >>> the length variable (here I've hard coded 512), what is this length? >> >>At the risk of being obvious, It's the length of the Fourier transform. >>Take a step backwards and look at it like this: >> >>You have N data points: x[0], x[1], ..., x[N-1]. When you take the >>Fourier transform of those N points, you are answering the following >>question: >> >>What are the coefficients of the function f(t) which has the form >> >>f(t) = a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) - b_k sin(2 pi >>k / N t) ) + a_{N/2} cos(pi t), >> >>such that f(n) = x[n] ? That is, you are fitting a periodic function >>(f(n) = f(n+N)) through the data points x[n]. The DFT computes the >>coefficients a_k and b_k (sometimes called real and imaginary part of >>the DFT). Another, but equivalent form of f(t) is >> >>f(t) = sum_{k=0}^{N/2} A_k cos(2 pi k / N t + phi_k). >> >>The A_k's are called the magnitudes, and the phi_k are called the >>phases. Together, they form an estimate of the spectrum of the data >>x[n]. >> >>Other names for these coefficients: the a_k's and b_k's are called the >>rectangular coordinates of the DFT, while the A_k's and the phi_k's are >>called the polar coordinates of the DFT. >> >>> >>> Then how do I interpret the results of the new values in myarray?I've>>> heard something's about where complex numbers, where two slot >>> represent one complex number? When I graph the resulting array, it >>> doesn't look like most of the FFT graphs I've seen? >> >>Usually, FFT routines return the rectangular coordinates of the DFT >>(look up the documentation of your routine for the exact format - >>remember that real part = a_k and imaginary part = b_k). For graphing >>and human interpretation, we prefer the polar coordinates - in >>addition, we neglect the phi_k and only concentrate on the A_k's. The >>A_k's can be computed through >> >>A_k = sqrt(a_k^2 + b_k^2). >> >>Graphs usually plot 20 log(A_k) = 10 log(a_k^2 + b_k^2). This kind of >>graph should be more familiar to you. >> >>> I'd appreciate a layman's response without to much reference to math, >>> as it not really my strong point. >>> >>> Thanks for your help >>> >>> >>> Carmen Branje >>> Toronto >> >>Regards, >>Andor >>Zurich >> >> > > >
Reply by ●July 11, 20102010-07-11
>bump . . .anyone have some new light to shed? > >Thanks >CarmenI am aware that this is a really old thread, but seeing as Carmen came back years after the original posting, I though I would just shed what little light I can on the matter in case somebody else is still asking the same question. I was stuck the same way Carmen was using the exocortex library and wishing I had a recognizable fft output to look at. Andor's reply put me on the right track. I did learn about FFT at uni, but that's years ago and I have barely thought about it since much less used it in practice, so my approach is highly results-oriented (as in I didn't strive to understand it fully, just to get the results I'm after). Keeping this in mind, the following C# method may provide the sought for output: //See www.dspguide.com (chapter 8) for a nice explanation of the concepts that come into play when one needs to do spectral analysis public static void ComputeFFTPolarMag(float[] samples, float[] fft, out float dcComponent) { int nextPowerOf2 = RoundToNextPowerOf2(samples.Length); if (fft.Length < nextPowerOf2) throw new Exception("length of fft result array must be big enough for next power of two"); Array.Copy(fft, samples, fft.Length);//Copy FFT input into the array that will hold the output so we don't destroy the input samples Fourier.RFFT(fft, nextPowerOf2, FourierDirection.Forward); for (int i = 2; i < nextPowerOf2; i++) fft[i] /= nextPowerOf2 / 2;//Divide all bins by N/2 to obtain amplitude of respective sinusoids (http://www.dspguide.com/ch8/5.htm) fft[0] /= nextPowerOf2;//Special treatment of DC component //Convert from rectangular coordinates to just the magnitude of polar coordinates - disregarding the phase 'coordinate' //(http://www.dsprelated.com/showmessage/58198/1.php) dcComponent = fft[0]; for (int i = 1; i < nextPowerOf2 / 2; i++)//Skip the first pair as first bin is at index 2 and 3 fft[i - 1] = (float)Math.Sqrt(fft[i * 2] * fft[i * 2] + fft[i * 2 + 1] * fft[i * 2 + 1]); for (int i = nextPowerOf2 / 2 - 1; i < fft.Length; i++)//Zero the rest fft[i] = 0.0f; //The fft array now holds plottable fft results from index 0 to N/2 } I thought I would include this utility method as it is quite clever. I can't take credit, though. I don't remember where I dug it up. public static int RoundToNextPowerOf2(int x) { if (x <= 1) return 1; x--; x |= x >> 1; x |= x >> 2; x |= x >> 4; x |= x >> 8; x |= x >> 16; x++; return x; } Please note that the above source is a quick and untested adaptation of a larger method specific to my application intended to provide only what is requested here and nothing more. Hope to help. Lars Ole> >>Hello >> >>Is there anyone that can help me. >> >>I don't care what the FFT does in the background, all I'm asking is how >to >>impliment it using a 1D array of audio samples. >> >>I am using Exocortex.DSP in C#. >> >>If someone could respond, refering to elements of C# (array number 1 >etc, >>instead of A_k etc) that would be most helpful. >> >>Thanks in advance >> >>Carmen Branje >> >>>cbranje@gmail.com wrote: >>>> Hi There >>>> >>>> I'm fairly new to FFT and the like and I'm trying to implement the >>>> Exocortex.DSP for C# and I have it working but I'm not really sure >how >>>> to interpret to results? >>>> >>>> So I pass a 1024 sized array of floats (they are 16 bit audio >samples, >>>> only the first 700 or 800 are actual values, I've zeroed the rest) to >>>> >>>> Fourier.FFT(myarray, 512, FourierDirection.Forward) >>>> >>>> So I'm wondering a few things . . . . >>>> >>>> the length variable (here I've hard coded 512), what is this length? >>> >>>At the risk of being obvious, It's the length of the Fourier transform. >>>Take a step backwards and look at it like this: >>> >>>You have N data points: x[0], x[1], ..., x[N-1]. When you take the >>>Fourier transform of those N points, you are answering the following >>>question: >>> >>>What are the coefficients of the function f(t) which has the form >>> >>>f(t) = a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) - b_k sin(2 pi >>>k / N t) ) + a_{N/2} cos(pi t), >>> >>>such that f(n) = x[n] ? That is, you are fitting a periodic function >>>(f(n) = f(n+N)) through the data points x[n]. The DFT computes the >>>coefficients a_k and b_k (sometimes called real and imaginary part of >>>the DFT). Another, but equivalent form of f(t) is >>> >>>f(t) = sum_{k=0}^{N/2} A_k cos(2 pi k / N t + phi_k). >>> >>>The A_k's are called the magnitudes, and the phi_k are called the >>>phases. Together, they form an estimate of the spectrum of the data >>>x[n]. >>> >>>Other names for these coefficients: the a_k's and b_k's are called the >>>rectangular coordinates of the DFT, while the A_k's and the phi_k's are >>>called the polar coordinates of the DFT. >>> >>>> >>>> Then how do I interpret the results of the new values in myarray? >I've >>>> heard something's about where complex numbers, where two slot >>>> represent one complex number? When I graph the resulting array, it >>>> doesn't look like most of the FFT graphs I've seen? >>> >>>Usually, FFT routines return the rectangular coordinates of the DFT >>>(look up the documentation of your routine for the exact format - >>>remember that real part = a_k and imaginary part = b_k). For graphing >>>and human interpretation, we prefer the polar coordinates - in >>>addition, we neglect the phi_k and only concentrate on the A_k's. The >>>A_k's can be computed through >>> >>>A_k = sqrt(a_k^2 + b_k^2). >>> >>>Graphs usually plot 20 log(A_k) = 10 log(a_k^2 + b_k^2). This kind of >>>graph should be more familiar to you. >>> >>>> I'd appreciate a layman's response without to much reference to math, >>>> as it not really my strong point. >>>> >>>> Thanks for your help >>>> >>>> >>>> Carmen Branje >>>> Toronto >>> >>>Regards, >>>Andor >>>Zurich >>> >>> >> >> >> >
