Octave Smoothing
Started by mikem May 23, 2006
In Matlab, I have a room impulse response. I need to plot a frequency
response from 20 to 20k Hz, smoothed to 1/3 and 1/6 octave. I can
calculate the ISO octave center frequencies. I see lots of RTA software
that does this real-time. Anyone have the Matlab code that does this, or
provide the algorithm? Thanks.
Hi mikem,
I used for many applications the "octave" package written by Christophe
COUVREUR. You can find it on
http://www.mathworks.com/matlabcentral/fileexchange/loadAuthor.do?objectType=author&objectId=802858
Bye,
Marco
mikem wrote:
> In Matlab, I have a room impulse response. I need to plot a frequency > response from 20 to 20k Hz, smoothed to 1/3 and 1/6 octave. I can > calculate the ISO octave center frequencies. I see lots of RTA software > that does this real-time. Anyone have the Matlab code that does this, or > provide the algorithm? Thanks. > > >
Thanks Marco,
I have tried to use this package. I'm starting with an impulse response
and I believe this package looks for the original signal. Can I adapt the
octave package to take an impulse response or process my impulse response
into a form that the package can accept?
>Hi mikem, > >I used for many applications the "octave" package written by Christophe >COUVREUR. You can find it on > >http://www.mathworks.com/matlabcentral/fileexchange/loadAuthor.do?objectType=author&objectId=802858 > >Bye, >Marco > > >mikem wrote: >> In Matlab, I have a room impulse response. I need to plot a frequency >> response from 20 to 20k Hz, smoothed to 1/3 and 1/6 octave. I can >> calculate the ISO octave center frequencies. I see lots of RTA
software
or
>> provide the algorithm? Thanks. >> >> >> >
I used the package only with continuous signals, but I think that if you
have a waveform with the impulse response it should work as is.
Marco
mikem wrote:
> Thanks Marco, > > I have tried to use this package. I'm starting with an impulse response > and I believe this package looks for the original signal. Can I adapt the > octave package to take an impulse response or process my impulse response > into a form that the package can accept? > > > >>Hi mikem, >> >>I used for many applications the "octave" package written by Christophe >>COUVREUR. You can find it on >> >>http://www.mathworks.com/matlabcentral/fileexchange/loadAuthor.do?objectType=author&objectId=802858 >> >>Bye, >>Marco >> >> >>mikem wrote: >> >>>In Matlab, I have a room impulse response. I need to plot a frequency >>>response from 20 to 20k Hz, smoothed to 1/3 and 1/6 octave. I can >>>calculate the ISO octave center frequencies. I see lots of RTA > > software > >>>that does this real-time. Anyone have the Matlab code that does this, > > or > >>>provide the algorithm? Thanks. >>> >>> >>> >> > >
