After I have setup the ccs in the condition of c671x XDS510 Emulator and want to enter into the enviroment of ccs , but it failed .It give me the error message as follows : Can't Initialize Target CPU: Error 0x80000200/-1031 Fatal Error during : 0CS, Device Driver: Problem with Emulation Controler. It Recommended to RESET Emulator.This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by emureset and reconnect to each target. I don't know what it means and where the problem is. Hope you can help me .Thank you in advance. I have checked the problems as someone pointed,such as the power supply,but it still couldn't work.Do you have any ideas ?Please help me,thank you in advance!
I can't link ccs with my c6713 board by JTAG
Started by ●June 8, 2006
Reply by ●June 9, 20062006-06-09
Have you configured the CCS so that the expected device is c6713 ? check the installation guide again ? sunnyzitong@126.com wrote:> After I have setup the ccs in the condition of c671x XDS510 Emulator > and want to enter into the enviroment of ccs , but it failed .It give > > me the error message as follows : > > Can't Initialize Target CPU: > Error 0x80000200/-1031 > Fatal Error during : 0CS, > Device Driver: Problem with Emulation Controler. > It Recommended to RESET Emulator.This will disconnect each target from > > the emulator. The targets should then be power cycled or hard reset > followed by emureset and reconnect to each target. > I don't know what it means and where the problem is. Hope you can help > me .Thank you in advance. > > I have checked the problems as someone pointed,such as the power > supply,but it still couldn't work.Do you have any ideas ?Please help > me,thank you in advance!
