90 degree phase shift
Started by ingresman June 9, 2006
Jerry Avins wrote:
> ingresman wrote: >> Thanks for the link Andor, I found it in an earlier post but to be >> honest the hilbert looks a bit odd. It just asks for sample rate and >> the impulse length. The sample rate has no impact on the ouput >> generated so I'm still a little confused. ... > > The sample rate is a standard question that is needed for all the > filters _but_ the HT. It is there only as a vestige. Put in whatever > value will make the frequency axis of output plot "pretty". > > Jerry
I guessed the sample rate would be required merely to format the graphs. However, it doesn't even do that. The graphs are labeled as a fraction of Fs. Its not clear why the sample rate is needed at all. Steve
ingresman wrote:
> Thanks guys I'll track down that book. > > As for the encoding Wendy Carlos has a great deal of info on her site. > You might remember switched on Back. The link is > http://www.wendycarlos.com/surround/surround4.html#matrix
I remember back when "Switched on Bach" was released. It was by Walter Carlos. It seems that more than music may be synthesized ;-) Clay
Hi All,
Sorry to be away for time. I've pulled together some code to do a
hilbert transform (from the university of york site) which i'll include
below in case anyone will find it usefull. If put a sample trought the
transform and then again will you get an invrerted signal i.e.
180degree shift. This code doesn't seem to do that si I'd be interested
in comments
cheers
#define NZEROS 500
#define GAIN   1.571116176e+00
static float xv_left[NZEROS+1];
static float xcoeffs[] =
  { +0.0000000000, +0.0003214310, +0.0000000000, +0.0003252099,
    +0.0000000000, +0.0003302355, +0.0000000000, +0.0003365372,
    +0.0000000000, +0.0003441444, +0.0000000000, +0.0003530868,
    +0.0000000000, +0.0003633944, +0.0000000000, +0.0003750973,
    +0.0000000000, +0.0003882260, +0.0000000000, +0.0004028113,
    +0.0000000000, +0.0004188840, +0.0000000000, +0.0004364757,
    +0.0000000000, +0.0004556178, +0.0000000000, +0.0004763424,
    +0.0000000000, +0.0004986818, +0.0000000000, +0.0005226689,
    +0.0000000000, +0.0005483367, +0.0000000000, +0.0005757189,
    +0.0000000000, +0.0006048495, +0.0000000000, +0.0006357632,
    +0.0000000000, +0.0006684951, +0.0000000000, +0.0007030809,
    +0.0000000000, +0.0007395569, +0.0000000000, +0.0007779600,
    +0.0000000000, +0.0008183281, +0.0000000000, +0.0008606994,
    +0.0000000000, +0.0009051133, +0.0000000000, +0.0009516098,
    +0.0000000000, +0.0010002299, +0.0000000000, +0.0010510155,
    +0.0000000000, +0.0011040098, +0.0000000000, +0.0011592568,
    +0.0000000000, +0.0012168018, +0.0000000000, +0.0012766915,
    +0.0000000000, +0.0013389738, +0.0000000000, +0.0014036982,
    +0.0000000000, +0.0014709156, +0.0000000000, +0.0015406788,
    +0.0000000000, +0.0016130421, +0.0000000000, +0.0016880620,
    +0.0000000000, +0.0017657969, +0.0000000000, +0.0018463073,
    +0.0000000000, +0.0019296564, +0.0000000000, +0.0020159096,
    +0.0000000000, +0.0021051351, +0.0000000000, +0.0021974040,
    +0.0000000000, +0.0022927905, +0.0000000000, +0.0023913723,
    +0.0000000000, +0.0024932304, +0.0000000000, +0.0025984499,
    +0.0000000000, +0.0027071199, +0.0000000000, +0.0028193341,
    +0.0000000000, +0.0029351907, +0.0000000000, +0.0030547934,
    +0.0000000000, +0.0031782511, +0.0000000000, +0.0033056791,
    +0.0000000000, +0.0034371988, +0.0000000000, +0.0035729386,
    +0.0000000000, +0.0037130347, +0.0000000000, +0.0038576311,
    +0.0000000000, +0.0040068807, +0.0000000000, +0.0041609461,
    +0.0000000000, +0.0043200000, +0.0000000000, +0.0044842264,
    +0.0000000000, +0.0046538214, +0.0000000000, +0.0048289944,
    +0.0000000000, +0.0050099691, +0.0000000000, +0.0051969851,
    +0.0000000000, +0.0053902989, +0.0000000000, +0.0055901856,
    +0.0000000000, +0.0057969412, +0.0000000000, +0.0060108836,
    +0.0000000000, +0.0062323557, +0.0000000000, +0.0064617271,
    +0.0000000000, +0.0066993973, +0.0000000000, +0.0069457986,
    +0.0000000000, +0.0072013994, +0.0000000000, +0.0074667084,
    +0.0000000000, +0.0077422784, +0.0000000000, +0.0080287117,
    +0.0000000000, +0.0083266658, +0.0000000000, +0.0086368590,
    +0.0000000000, +0.0089600787, +0.0000000000, +0.0092971888,
    +0.0000000000, +0.0096491399, +0.0000000000, +0.0100169797,
    +0.0000000000, +0.0104018664, +0.0000000000, +0.0108050829,
    +0.0000000000, +0.0112280539, +0.0000000000, +0.0116723666,
    +0.0000000000, +0.0121397934, +0.0000000000, +0.0126323203,
    +0.0000000000, +0.0131521795, +0.0000000000, +0.0137018887,
    +0.0000000000, +0.0142842976, +0.0000000000, +0.0149026446,
    +0.0000000000, +0.0155606252, +0.0000000000, +0.0162624744,
    +0.0000000000, +0.0170130694, +0.0000000000, +0.0178180552,
    +0.0000000000, +0.0186840011, +0.0000000000, +0.0196185982,
    +0.0000000000, +0.0206309077, +0.0000000000, +0.0217316805,
    +0.0000000000, +0.0229337690, +0.0000000000, +0.0242526657,
    +0.0000000000, +0.0257072177, +0.0000000000, +0.0273205841,
    +0.0000000000, +0.0291215436, +0.0000000000, +0.0311463069,
    +0.0000000000, +0.0334410798, +0.0000000000, +0.0360657647,
    +0.0000000000, +0.0390994399, +0.0000000000, +0.0426486966,
    +0.0000000000, +0.0468607407, +0.0000000000, +0.0519447683,
    +0.0000000000, +0.0582084316, +0.0000000000, +0.0661234757,
    +0.0000000000, +0.0764519642, +0.0000000000, +0.0905102051,
    +0.0000000000, +0.1107845781, +0.0000000000, +0.1426030657,
    +0.0000000000, +0.1998184590, +0.0000000000, +0.3332243858,
    +0.0000000000, +0.9999636803, +0.0000000000, -0.9999636803,
    -0.0000000000, -0.3332243858, -0.0000000000, -0.1998184590,
    -0.0000000000, -0.1426030657, -0.0000000000, -0.1107845781,
    -0.0000000000, -0.0905102051, -0.0000000000, -0.0764519642,
    -0.0000000000, -0.0661234757, -0.0000000000, -0.0582084316,
    -0.0000000000, -0.0519447683, -0.0000000000, -0.0468607407,
    -0.0000000000, -0.0426486966, -0.0000000000, -0.0390994399,
    -0.0000000000, -0.0360657647, -0.0000000000, -0.0334410798,
    -0.0000000000, -0.0311463069, -0.0000000000, -0.0291215436,
    -0.0000000000, -0.0273205841, -0.0000000000, -0.0257072177,
    -0.0000000000, -0.0242526657, -0.0000000000, -0.0229337690,
    -0.0000000000, -0.0217316805, -0.0000000000, -0.0206309077,
    -0.0000000000, -0.0196185982, -0.0000000000, -0.0186840011,
    -0.0000000000, -0.0178180552, -0.0000000000, -0.0170130694,
    -0.0000000000, -0.0162624744, -0.0000000000, -0.0155606252,
    -0.0000000000, -0.0149026446, -0.0000000000, -0.0142842976,
    -0.0000000000, -0.0137018887, -0.0000000000, -0.0131521795,
    -0.0000000000, -0.0126323203, -0.0000000000, -0.0121397934,
    -0.0000000000, -0.0116723666, -0.0000000000, -0.0112280539,
    -0.0000000000, -0.0108050829, -0.0000000000, -0.0104018664,
    -0.0000000000, -0.0100169797, -0.0000000000, -0.0096491399,
    -0.0000000000, -0.0092971888, -0.0000000000, -0.0089600787,
    -0.0000000000, -0.0086368590, -0.0000000000, -0.0083266658,
    -0.0000000000, -0.0080287117, -0.0000000000, -0.0077422784,
    -0.0000000000, -0.0074667084, -0.0000000000, -0.0072013994,
    -0.0000000000, -0.0069457986, -0.0000000000, -0.0066993973,
    -0.0000000000, -0.0064617271, -0.0000000000, -0.0062323557,
    -0.0000000000, -0.0060108836, -0.0000000000, -0.0057969412,
    -0.0000000000, -0.0055901856, -0.0000000000, -0.0053902989,
    -0.0000000000, -0.0051969851, -0.0000000000, -0.0050099691,
    -0.0000000000, -0.0048289944, -0.0000000000, -0.0046538214,
    -0.0000000000, -0.0044842264, -0.0000000000, -0.0043200000,
    -0.0000000000, -0.0041609461, -0.0000000000, -0.0040068807,
    -0.0000000000, -0.0038576311, -0.0000000000, -0.0037130347,
    -0.0000000000, -0.0035729386, -0.0000000000, -0.0034371988,
    -0.0000000000, -0.0033056791, -0.0000000000, -0.0031782511,
    -0.0000000000, -0.0030547934, -0.0000000000, -0.0029351907,
    -0.0000000000, -0.0028193341, -0.0000000000, -0.0027071199,
    -0.0000000000, -0.0025984499, -0.0000000000, -0.0024932304,
    -0.0000000000, -0.0023913723, -0.0000000000, -0.0022927905,
    -0.0000000000, -0.0021974040, -0.0000000000, -0.0021051351,
    -0.0000000000, -0.0020159096, -0.0000000000, -0.0019296564,
    -0.0000000000, -0.0018463073, -0.0000000000, -0.0017657969,
    -0.0000000000, -0.0016880620, -0.0000000000, -0.0016130421,
    -0.0000000000, -0.0015406788, -0.0000000000, -0.0014709156,
    -0.0000000000, -0.0014036982, -0.0000000000, -0.0013389738,
    -0.0000000000, -0.0012766915, -0.0000000000, -0.0012168018,
    -0.0000000000, -0.0011592568, -0.0000000000, -0.0011040098,
    -0.0000000000, -0.0010510155, -0.0000000000, -0.0010002299,
    -0.0000000000, -0.0009516098, -0.0000000000, -0.0009051133,
    -0.0000000000, -0.0008606994, -0.0000000000, -0.0008183281,
    -0.0000000000, -0.0007779600, -0.0000000000, -0.0007395569,
    -0.0000000000, -0.0007030809, -0.0000000000, -0.0006684951,
    -0.0000000000, -0.0006357632, -0.0000000000, -0.0006048495,
    -0.0000000000, -0.0005757189, -0.0000000000, -0.0005483367,
    -0.0000000000, -0.0005226689, -0.0000000000, -0.0004986818,
    -0.0000000000, -0.0004763424, -0.0000000000, -0.0004556178,
    -0.0000000000, -0.0004364757, -0.0000000000, -0.0004188840,
    -0.0000000000, -0.0004028113, -0.0000000000, -0.0003882260,
    -0.0000000000, -0.0003750973, -0.0000000000, -0.0003633944,
    -0.0000000000, -0.0003530868, -0.0000000000, -0.0003441444,
    -0.0000000000, -0.0003365372, -0.0000000000, -0.0003302355,
    -0.0000000000, -0.0003252099, -0.0000000000, -0.0003214310,
    -0.0000000000,
float shiftLeft(float isamp)
 float sum; int i;
 for (i = 0; i < NZEROS; i++)       xv_left[i] = xv_left[i+1];
 xv_left[NZEROS] = isamp / GAIN;
 sum = 0.0;
 for (i = 0; i <= NZEROS; i++)
           sum += (xcoeffs[i] * xv_left[i]);
       return sum;
Just put a sample in as a parameter and you shoud get a shifted value
out as the result. The code has compiled under Visual C on windows.
Clay wrote:
> ingresman wrote: > > Thanks guys I'll track down that book. > > > > As for the encoding Wendy Carlos has a great deal of info on her site. > > You might remember switched on Back. The link is > > http://www.wendycarlos.com/surround/surround4.html#matrix > > I remember back when "Switched on Bach" was released. It was by Walter > Carlos. > > It seems that more than music may be synthesized ;-) > > Clay
ingresman wrote:
> Hi All, > > Sorry to be away for time. I've pulled together some code to do a > hilbert transform (from the university of york site) which i'll include > below in case anyone will find it usefull.If put a sample trought the > transform and then again will you get an invrerted signal i.e. > 180degree shift. This code doesn't seem to do that si I'd be interested > in comments
[code snipped] The Hilbert transform is a bandpass operation. For a full band signal, applying the HT twice will be different than multiplying by -1 [1]. Try testing your implementation with a single sine wave and see if you get the expected result. Be careful to align the input and output according to the delay of the HT filter. Regards, Andor [1] To find out whether multiplying by -1 is indeed a 180=B0 phase shift, read this thread (beware: 2 hours spare time needed :-): http://groups.google.com/group/comp.dsp/browse_frm/thread/af1b4caf51d6c239/= 6c8e066df0ec0daf?#6c8e066df0ec0daf
Andor wrote:
> The Hilbert transform is a bandpass operation. For a full band signal, > applying the HT twice will be different than multiplying by -1 [1]
... That's only because most of us aren't willing or able to wait for 90 degrees of shift at 1E-21 Hz, let alone DC. As always, we have to distinguish between the theoretical and the practical when making pronouncements. If Ingressman's filter had 1E-21 coefficients, it might come closer to meeting his expectations. Jerry -- Engineering is the art of making what you want from things you can get. &#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;&#2013266095;
