PSD in ZP-OFDM and CP-OFDM
Started by chaselweng June 13, 2006
Hi all....
I just simulated the Zero-Padding OFDM and Cyclic-Prefix OFDM system...
I found some difference between their power spectrum density...
In CP-OFDM, the in-band ripple is larger than ZP-OFDM...
But in out-of-band, the ZP-OFDM is larger than CP-OFDM....
I just got the conclusion through simulation...
How could i explain the phenomenon in physical or math. sense....
Anyone can tell me how to formulate it as a math problem..!?
(any recommend paper or book also good)...Thx a lot!!
ZP may be seen as CP at all. (looking the padded zeros as a part of the
data block, ZP of the former OFDM symbol is CP of current OFDM symbol.)
So the difference is mainly arised from the parameters.
In your case, ZP-OFDM symbol  is shorter than CP-OFDM symbol.
That is all.
chaselweng wrote:
> Hi all.... > I just simulated the Zero-Padding OFDM and Cyclic-Prefix OFDM system... > I found some difference between their power spectrum density... > In CP-OFDM, the in-band ripple is larger than ZP-OFDM... > But in out-of-band, the ZP-OFDM is larger than CP-OFDM.... > I just got the conclusion through simulation... > How could i explain the phenomenon in physical or math. sense.... > > Anyone can tell me how to formulate it as a math problem..!? > (any recommend paper or book also good)...Thx a lot!!
