Hello I'm trying to perform Channel Estimation on an OFDM signal by using various interpolation techniques between pilot symbols. The best method is to implement an interpolation filter (in the time domain, or in the freq domain using FFT). The problem is that in order to achieve a "good" FIR interpolation filter, the filter must be quite long. Because of the long filter length (long tail) => I can't estimate properly the channel on the edges of the signal. If I would be able to use an IIR filter (short length) with linear phase, I can pass the signal through the filter in both directions (the forward and backward) and get the best result at the edges of the signal. 1) Is there method to build an IIR interpolation filter with linear phase 2) Is there an alternative method to solve the above problem Thanks, oren
Interpolation using IIR
Started by ●June 15, 2006
