Hello, i'm currently working on a channel estimation algorithm for OFDM. I already programmed the main part according to the implementation in DVB-T. But my system is rather abstract. First a symbol will be sent only with pilots to make the channel estimation. All the other symbols after that are full of purely real data (without pilots). With the help of the channel freq. resp. (which calculated in the CE procedure) the channel equalization will be realized. My question is: is the content of the preamble important for the CE? Which kind of values can i use in this preamble? thanks in advance!
Content of the preamble for OFDM channel estimation
Started by ●June 24, 2006
Reply by ●June 24, 20062006-06-24
It depends on what kind of channel are you assuming, how long will it remain the same. Also since ofdm is wideband one technique would be to cycle your pilot through all the tones. and then the equalizer can make a decision based on (1) when was the last pilot on that tones spot. (2) what were the pilots value in nearby tones. Since you would not want to wait till the pilot is running through all the tones, you would want the pilot to be sent along with the data. There are a lot of sequences with a strong auto correlation that you can use for the pilot hopping sequence so receiver can first lock on to the pilot, then data This method is typicaly used with a very short(often nonexistant) preamble, In this technique you will have a constant pilot overhead in your data tones though....
Reply by ●June 25, 20062006-06-25
On Sat, 24 Jun 2006 08:16:56 -0500, "skywalker601" <kataculy@yahoo.de> wrote:>Hello, > >i'm currently working on a channel estimation algorithm for OFDM. I >already programmed the main part according to the implementation in DVB-T. >But my system is rather abstract. First a symbol will be sent only with >pilots to make the channel estimation. All the other symbols after that >are full of purely real data (without pilots). With the help of the >channel freq. resp. (which calculated in the CE procedure) the channel >equalization will be realized. My question is: is the content of the >preamble important for the CE? Which kind of values can i use in this >preamble? > >thanks in advance!That diverges from DVB-T a bit, but having symbols dedicated entirely for pilots is used in most bursty OFDM systems like 802.11 or 802.16. In those cases the symbols used for channel estimation can also be used for synchronization, so autocorrelation properties are important as well. Other than that certain pilot arrangements will have better PAPR than others. In other words, if you did something nutty like put all pilots the same magnitude with the same phase, you're going to have a serious PAPR problem asssociated with that symbol. So usually a pattern with a fair amount of entropy (i.e., lower PAPR) and a reasonable autocorrelation sequence (if you want the synchronization properties) is used. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
