"Andor" <andor.bariska@gmail.com> wrote in message news:1152784565.872351.298120@b28g2000cwb.googlegroups.com...> > ma wrote: > >> Hello, >> >> I know that one way of interpolation is low pass filtering. But I >> think >> any other type of interpolation (such as spile or linre ,...) can be >> modeled >> as a low pass filter with different frequency response. Am I wrong? if >> no, >> where can I read more? for example what is the frequency response of a >> spilne interpolator? > > They are commonly known as "spline" interpolators. There is a paper > somewhere which discusses general polynomial interpolation filters and > their frequency responses ... <click, click> ... it moved .... ah, > here: > > http://www.biochem.oulu.fi/~oniemita/dsp/deip.pdf > > Regards, > Andor >Thanks Andor, This is a very nice paper on 1D interpolation. Is there any paper similar to this one but about 2D interpolations? Best regards
interpolation and filtering
Started by ●July 11, 2006
Reply by ●July 13, 20062006-07-13
ma wrote:> "Andor" wrote in message > news:1152784565.872351.298120@b28g2000cwb.googlegroups.com... > > > > ma wrote: > > > >> Hello, > >> > >> I know that one way of interpolation is low pass filtering. But I > >> think > >> any other type of interpolation (such as spile or linre ,...) can be > >> modeled > >> as a low pass filter with different frequency response. Am I wrong? if > >> no, > >> where can I read more? for example what is the frequency response of a > >> spilne interpolator? > > > > They are commonly known as "spline" interpolators. There is a paper > > somewhere which discusses general polynomial interpolation filters and > > their frequency responses ... <click, click> ... it moved .... ah, > > here: > > > > http://www.biochem.oulu.fi/~oniemita/dsp/deip.pdf > > > > Regards, > > Andor > > > > Thanks Andor, > This is a very nice paper on 1D interpolation. Is there any paper > similar to this one but about 2D interpolations?Your wish ... http://bigwww.epfl.ch/publications/thevenaz0002.pdf
Wilson wrote:> [...] > Linear interpolation is the equivalent of taking your data samples > (spaced by 'T' seconds) and sending them through a continuous-time > filter which has a triangular impulse response and then re-sampling the > output at the new (interpolated) sample times.> > The impulse response of this continuous-time filter is: > h(t) = 1 - abs(t)/T for abs(t) <= T; and h(t) = 0 abs(t) >= T. > > At each new sampling instant, the output is a weighted combination of > only two samples, in accordance to the the linear interpolation > formula. For the case where the new sample falls exactly on the time > index of an old sample, then the new sample equals the old sample (as > one would hope!). > > The frequency response of this procedure is determined by the Fourier > Transform of h(t). > The response has a sinc() squared response. > > WilsonHi Wilson, Yes, you are correct. I made a mistake. I guess I had a strange view of linear interpolation in mind. Assuming we're interpolating by M, then I was thinking of a process that *began* with a sequence of values at the upsampled rate, then computed values m*M + 1, m*M + 2, ..., m*M + M - 1 from the points m*M and (m+1)*M, where m is an arbitrary integer. Normally the values m*M are the samples from the original sequence, but in my gedanken they don't have to be. In case they are, you get the linear interpolation we all know and love. If, however, you shifted this sequence by 1 (and assuming the in-between values were zero), you'd get zeros out with this scheme. This is why I said it wasn't LTI, and thus cannot be represented as a linear filter. But I tend to think in strange ways... --Randy
