Hi, I have designed a IIR filter which is formed of 14 2nd order cells. I'd like to make it work on a FPGA. I've seen that differents forms of cells do exist (direct, form 1, form2...). I'd like to know which one is better for a FPGA. Any piece of advice is welcome ! Thanks a lot for your help. S.
FPGA
Started by ●July 13, 2006
Reply by ●July 13, 20062006-07-13
What do these "different forms" look like? In terms of structure, what is the difference between direct, form 1, form 2? "better" in what context? Do you want the highest clock rate or smallest amount of FPGA logic used, or easiest to design/test? What is your sample rate? Regards Andrew stephaneo@gmail.com wrote:> Hi, > > I have designed a IIR filter which is formed of 14 2nd order cells. > > I'd like to make it work on a FPGA. I've seen that differents forms of > cells do exist (direct, form 1, form2...). > > I'd like to know which one is better for a FPGA. > > Any piece of advice is welcome ! > > Thanks a lot for your help. > > S.
Reply by ●July 17, 20062006-07-17
Hi, Differents structures are described here : http://www.bores.com/courses/intro/iir/5_transp.htm By "better" I meant the best way to describe the filter so that it would be design easily for the FPGA. I've seen on the internet that pipelined cell could be useful in designing filters for FPGAs... I'm quite new to FPGA so any information or link is welcomed. I'm not supposed to code it for the FPGA so I'm not quite aware with very specific technical details. However, I've understood that, according to the structure I choose, the design on the FPGA will be either very complicated or more simple. My sample rate is 18 Mhz. Thanks a lot for your help, Regards, St=E9phane Andrew FPGA wrote:> What do these "different forms" look like? In terms of structure, what > is the difference between direct, form 1, form 2? > > "better" in what context? Do you want the highest clock rate or > smallest amount of FPGA logic used, or easiest to design/test? > > What is your sample rate? > > Regards > Andrew > > stephaneo@gmail.com wrote: > > Hi, > > > > I have designed a IIR filter which is formed of 14 2nd order cells. > > > > I'd like to make it work on a FPGA. I've seen that differents forms of > > cells do exist (direct, form 1, form2...). > > > > I'd like to know which one is better for a FPGA. > > > > Any piece of advice is welcome ! > >=20 > > Thanks a lot for your help. > >=20 > > S.
Reply by ●July 19, 20062006-07-19
> By "better" I meant the best way to describe the filter so that it > would be design easily for the FPGA. I've seen on the internet that > pipelined cell could be useful in designing filters for FPGAs... >Ok, in that case why not just use the direct form. Implement each tap multiplication using a FPGA embedded multiplier. (look at xilinx spartan 3 datasheet and you will see this fpga has a number of 18x18 multipliers embedded in the FPGA fabric). Feed all 28 tap outputs back to a 28 input adder. I'm guessing a 28 input adder will still meet timing with a clock rate of only 18MHz. If the adder doesn't meet timing then I would suggest adding pipeling as required to the adder. But because the filter is IIR and therfore has feedback, one can't just simply add register delays to the adder. What you could do is use a clock rate of 2x18MHz, but only enable the tap multipliers on every 2nd cycle. This now gives your adder 2 clock cycles to generate its sum - i.e. you can now add 1 level of pipelining to the adder. Disclaimer: The implementation I have described is very wasteful of FPGA resources - but you wanted "easiest to design". Actually, you never mentioned coefficient or sample bit widths. I think one of the (several?) reasons filters are often implemented on traditional DSPs using various other forms/2nd order stages etc is to reduce the filter sensitivity to the quantisation of the coefficients. I assume that is always going to be an issue, no matter if your implementation is DSP or FPGA. (although I guess the FPGA does have the advantage in that the arithmetic precision can be tailored precisely to your needs). Regards Andrew
Hi andrew, First thanks a lot for your detailed answer. OK for the direct form I, I think I can see how to do it. However I've made a previous study on problems that can occurs with IIR and it appears that 2nd order cells would be the best way to implement IIR filters. By the way as you said, quantization errors are easier to control with such structures, that's why I would prefer to keep a 2nd order cascade structure. By the way, I think that, when I will have succeed in designing a efficient 2nd order cells on the FPGA, I will be able to do any order of filters. As I will know how much "space" a single cell takes, I will just need to connect these cells in cascade. Thus, I think I should look on a more complex way to design 2nd order cell even if it's not, this time, the easiest way to design it, but the more efficient use of the FPGA and overall a way to re-use my cells to create new filters of higher orders. Do you think that Direct-Form (or even tranposed) I 2nd order structures with a pipeline at 2*Freq is the best way to achieve such a design? Again, thanks for your help and your time. Stephane Andrew FPGA wrote:> > By "better" I meant the best way to describe the filter so that it > > would be design easily for the FPGA. I've seen on the internet that > > pipelined cell could be useful in designing filters for FPGAs... > > > Ok, in that case why not just use the direct form. Implement each tap > multiplication using a FPGA embedded multiplier. (look at xilinx > spartan 3 datasheet and you will see this fpga has a number of 18x18 > multipliers embedded in the FPGA fabric). Feed all 28 tap outputs back > to a 28 input adder. I'm guessing a 28 input adder will still meet > timing with a clock rate of only 18MHz. > > If the adder doesn't meet timing then I would suggest adding pipeling > as required to the adder. But because the filter is IIR and therfore > has feedback, one can't just simply add register delays to the adder. > What you could do is use a clock rate of 2x18MHz, but only enable the > tap multipliers on every 2nd cycle. This now gives your adder 2 clock > cycles to generate its sum - i.e. you can now add 1 level of pipelining > to the adder. > > Disclaimer: The implementation I have described is very wasteful of > FPGA resources - but you wanted "easiest to design". > > Actually, you never mentioned coefficient or sample bit widths. I think > one of the (several?) reasons filters are often implemented on > traditional DSPs using various other forms/2nd order stages etc is to > reduce the filter sensitivity to the quantisation of the coefficients. > I assume that is always going to be an issue, no matter if your > implementation is DSP or FPGA. (although I guess the FPGA does have the > advantage in that the arithmetic precision can be tailored precisely to > your needs). > > Regards > Andrew
Andrew FPGA wrote:>>By "better" I meant the best way to describe the filter so that it >>would be design easily for the FPGA. I've seen on the internet that >>pipelined cell could be useful in designing filters for FPGAs...> Ok, in that case why not just use the direct form. Implement each tap > multiplication using a FPGA embedded multiplier. (look at xilinx > spartan 3 datasheet and you will see this fpga has a number of 18x18 > multipliers embedded in the FPGA fabric). Feed all 28 tap outputs back > to a 28 input adder. I'm guessing a 28 input adder will still meet > timing with a clock rate of only 18MHz.My favorite architecture for FPGA implementations of algorithms is the systolic array. I don't know if that is best for this problem, but it works well for many problems. It is then usually not so hard to balance logic resources and clock speed to make optimal use of the FPGA hardware. -- glen
