This is a MATLAB code for DCT and DWT Compression. I tried this code with 512X512 TIF image. The DCT part worked fine, but I faced some problems with DWT compression. The output image was just blank. Any help regarding this will be highly appreciated!! inp_image=imread('c:\zenacolor.tif'); inp_imaged=double(inp_image); siz = size(inp_imaged) ; no_row = siz(1) ; no_col = siz(2) ; energy_image = sum(sum(inp_imaged.^2)) % Energy of the input image % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % 2-D DCT Calculation and Experiment %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% dctcoeffd=zeros(siz(1),siz(2)) ; %%%%%%%%%%%%%%%%%%%555 zeros(no_row,no_col) dctrearr=zeros(siz(1),siz(2)) ; dctrearrs=zeros(siz(1),siz(2)) ; rmse = zeros(8,8) ; nbr = no_row/8 ; nbc = no_col/8 ; for m=0:(no_row/8-1) %%use nbr for n=0:(no_col/8-1)%%% use nbc x=m*8 ; y=n*8 ; block=inp_imaged(x+1:x+8,y+1:y+8); %%%%%%%%%%%%%%% change dctcoeffd(x+1:x+8,y+1:y+8)=dct2(block) ;%%%%%%%%%%%%%%% change end end %DCT calculation is over. Now rearranging the data for m=0:7 for n=0:7 x=m*nbr ; y=n*nbc ; block =dctcoeffd(m+1:8:end,n+1:8:end) ; dctrearr(x+1:x+nbr,y+1:y+nbr) = block ; dctrearrs(x+1:x+nbr,y+1:y+nbr) = (1+25*(m+n))*block ; rmse(m+1,n+1)=sqrt(sum(sum(block.*block))/(nbr*nbc)) ; end end maxv = max(max(abs(dctrearr))) ; %imshow(dctcoeffd) ; dctrearrs = abs(dctrearrs) ; % The DCTC > 0 now imshow(dctrearrs/maxv) ; imshow(dctrearrs(1:2*nbr,1:2*nbc)/maxv) ; print -dtiff plot.tiff % fprintf('\nRMS Energy cof the DCT coefficients are as follows:\n') ; round(rmse) %print -dtiff plot.tiff % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % 2-D DCT Calculation and Experiment Over % Now 2-D DWT Calculation and Experiment %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% nstage = 3 ; % No. of Decomposition stage wtype = 1 ; % Wavelet filter type, 0=Haar, 1=Daub-4 wtcoeffd = dwt2(inp_imaged,no_row,no_col,nstage,wtype,1) ; out_image = dwt2(wtcoeffd,no_row,no_col,nstage,wtype,-1) ; wtcoeffdisp = zeros(no_row,no_col) ; %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Calculating RMSE of the subbands. for level=nstage:-1:1 k=2^level ; res = nstage-level ; npix = no_row*no_col/(k^2) ; if (res==0) block = wtcoeffd(1:no_row/k, 1:no_col/k) ; rmse = sqrt(sum(sum((block).^2))/npix); % LH subband fprintf('\nRMSE in subband-%d = %d', 3*(nstage-level),rmse) end k=2*k; block1 = wtcoeffd(1:no_row/k, (no_col/k)+1:no_col/(k/2)) ; block2 = wtcoeffd(no_row/k+1:no_row/(k/2), 1:no_col/(k)) ; block3 = wtcoeffd(no_row/k+1:no_row/(k/2), no_col/k+1:no_col/(k/2)) ; %RMSE Calculation rmse1 = sqrt(sum(sum((block1).^2))/npix) ; % LH subband rmse2 = sqrt(sum(sum((block2).^2))/npix) ; % HL subband rmse3 = sqrt(sum(sum((block3).^2))/npix) ; % HH subband fprintf('\nRMSE in subband-%d = %d', 3*res+1,rmse1) ; fprintf('\nRMSE in subband-%d = %d', 3*res+2,rmse2) ; fprintf('\nRMSE in subband-%d = %d', 3*res+3,rmse3) ; %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%The following code scales up the coefficients for better viewing % The scaling is adhoc wtcoeffdisp(1:no_row/k, no_col/k+1:no_col/(k/2)) = (2^(res+1))*block1 ; wtcoeffdisp(no_row/k+1:no_row/(k/2), 1:no_col/k) = (2^(res+1))*block2 ; wtcoeffdisp(no_row/k+1:no_row/(k/2), no_col/k+1:no_col/(k/2)) = (2.5^(res+1))*block3 ; k=k/2; if (res==0) wtcoeffdisp(1:no_row/k, 1:no_col/k) = block/5; end %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% end energy_percent = (rmse^2)*(no_row*no_col/(4^nstage))*100/energy_image ; fprintf('\nEnergy compacted in the LL subband = %d\n', energy_percent) ; %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % A large number of DWT coefficients are likely to exceed the 8-bit % dynamic range i.e., 0-255. The following code will clip the coefficients % to [0,255] range wtcoeffdisp = abs(wtcoeffdisp) ; % The DCTC > 0 now mask = wtcoeffdisp > 255 ; wtcoeffdisp1 = wtcoeffdisp.*(~mask) + 255.* mask ; % all coeffs are now <= 255 % Converting the image to uint8 format wtcoeffdisp8b = uint8(wtcoeffdisp1) ; imshow(wtcoeffdisp8b) ; print -dtiff plot.tiff imshow(wtcoeffdisp8b(1:no_row,1:no_col)) ; %print -dtiff plot.tiff imwrite(wtcoeffdisp8b,'C:\wtcoeffdisp.tif','tif') ;
DCT & DWT
Started by ●July 17, 2006
