Hello, Im at yet another DSP challenge ... Im trying to implement a simple software modem to transmit 4kbps over a 3Khz radio channel. Any suggestions on what the absolute simplest form of digital modulation to be used? Thanks! --Shafik Amin
Simple Software Modem
Started by ●July 18, 2006
Reply by ●July 18, 20062006-07-18
On 18 Jul 2006 13:33:13 -0700, "Shafik" <shafik23@gmail.com> wrote:>Hello, > >Im at yet another DSP challenge ... > >Im trying to implement a simple software modem to transmit 4kbps over a >3Khz radio channel. Any suggestions on what the absolute simplest form >of digital modulation to be used? > >Thanks! >--Shafik AminWhat do you know about the channel? If the SNR is high and the channel is flat then PAM is pretty easy to get working. The channel assumptions are pretty important, though. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Shafik wrote:> Hello, > > Im at yet another DSP challenge ... > > Im trying to implement a simple software modem to transmit 4kbps over a > 3Khz radio channel. Any suggestions on what the absolute simplest form > of digital modulation to be used? > > Thanks! > --Shafik AminI don't know how to measure simplicity in your context, but I would suggest differential PSK. This kind of modulation is bandwidth efficient, can be detected noncoherently, and is insensitive to amplitude variations. If you choose D8PSK, a symbol rate of 1500 baud, and use a root-rasied cosine filter, you have a shot. Try a one baud delay-conjugate multiply for demodulation. Some of the old telephone modems used this modulation. V.27 is one that comes to mind. Go download the spec from ITU web site (I think you get three specs free) for info. John
Reply by ●July 19, 20062006-07-19
johns@3db-labs.com wrote: (snip)> I don't know how to measure simplicity in your context, but I would > suggest differential PSK. This kind of modulation is bandwidth > efficient, can be detected noncoherently, and is insensitive to > amplitude variations.Why, then, were most early modems, such as the 103, FSK? Though that assumes analog filters, which is probably the wrong assumption for this newsgroup. -- glen
glen herrmannsfeldt wrote:> johns@3db-labs.com wrote: > > (snip) > > > I don't know how to measure simplicity in your context, but I would > > suggest differential PSK. This kind of modulation is bandwidth > > efficient, can be detected noncoherently, and is insensitive to > > amplitude variations. > > Why, then, were most early modems, such as the 103, FSK? > > Though that assumes analog filters, which is probably the > wrong assumption for this newsgroup. > > -- glenFSK doesn't require analog filters, and I would say that it is simpler than DPSK. The reason I didn't suggest it because I don't think simple FSK can meet the BW objective. John
glen herrmannsfeldt wrote:> johns@3db-labs.com wrote: > > (snip) > >> I don't know how to measure simplicity in your context, but I would >> suggest differential PSK. This kind of modulation is bandwidth >> efficient, can be detected noncoherently, and is insensitive to >> amplitude variations. > > Why, then, were most early modems, such as the 103, FSK? > > Though that assumes analog filters, which is probably the > wrong assumption for this newsgroup.In those modems, the baud rate equaled the bit rate. The OP's specification doesn't allow that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 21, 20062006-07-21
Jerry Avins wrote: (snip regarding the simplicity of FSK modems)> In those modems, the baud rate equaled the bit rate. The OP's > specification doesn't allow that.I don't know that it is required that only two frequencies are used, though that seems usual. It might be, though, that PSK is easier with more than one bit/baud. -- glen
glen herrmannsfeldt wrote:> Jerry Avins wrote: > > (snip regarding the simplicity of FSK modems) > >> In those modems, the baud rate equaled the bit rate. The OP's >> specification doesn't allow that. > > I don't know that it is required that only two frequencies > are used, though that seems usual. It might be, though, > that PSK is easier with more than one bit/baud.Modems usually go beyond 4 phases before amplitude becomes a variable. If independent quadrature carriers are amplitude modulated, simply turning them on(+/-) and off yields 8 phases. The 45-degree phases have greater amplitude, making room for half-amplitude pulses without sinking below the noise. Great minds took it from there and flew with the idea. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 23, 20062006-07-23
