Hello All, In Matlab, I have this function: y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); When I try to see the result of y(0.5) on the m-file, the system generates a synatx error: ??? Error using ==> run Attempted to access y(0.5); index must be a positive integer or logical. The question is that how can I access this value as I need to sample this function into 1000 intervals, and use these samples for discrete analysis. My program is: function wave=haarX(); x = [0:0.001:1]; y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); %y(0.5); for i=1:length(x) Array(i) = y(i/1000); end Thanks for time and your response is much appreciated. Sincerely, Kal
Matlab question
Started by ●July 26, 2006
Reply by ●July 26, 20062006-07-26
Hi, your 'y' in matlab is a matrix (1x1000). You can only get y(1),y(2)... So if you want to get y(0.5) you need to find which index is 0.5, ie n=3D0.5/0.001; then y(n)... I hope my explanation is clear... Regards, kal a =E9crit :> Hello All, > In Matlab, I have this function: > y =3D 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > When I try to see the result of y(0.5) on the m-file, the system > generates a synatx error: > > ??? Error using =3D=3D> run > Attempted to access y(0.5); index must be a positive integer or > logical. > The question is that how can I access this value as I need to sample > this function into 1000 intervals, and use these samples for discrete > analysis. > My program is: > > function wave=3DhaarX(); > x =3D [0:0.001:1]; > > > y =3D 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > %y(0.5); > for i=3D1:length(x) > Array(i) =3D y(i/1000); > end > Thanks for time and your response is much appreciated. > Sincerely, > Kal
kal wrote:> Hello All, > In Matlab, I have this function: > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > When I try to see the result of y(0.5) on the m-file, the system > generates a synatx error: > > ??? Error using ==> run > Attempted to access y(0.5); index must be a positive integer or > logical. > The question is that how can I access this value as I need to sample > this function into 1000 intervals, and use these samples for discrete > analysis. > My program is: > > function wave=haarX(); > x = [0:0.001:1]; > > > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > %y(0.5); > for i=1:length(x) > Array(i) = y(i/1000); > end > Thanks for time and your response is much appreciated. > Sincerely, > KalAren't you trying to do: x = [0:0.0001:1]; for i = 1:length(x) Array(i) = 20 * (x.^2).*((1-x).^4)*cos(12*pi*x) / 1000; end %Array(5000); or is that %Array[5000]; ??? Of course you can't take y(0.5) as Matlab states very simply that the index needs to be integer. The half way sample point of your 10, 000x samples (yup that's 10, 000 otherwise use x=[0:0.001:1]) is the 5000 value.
kal skrev:> Hello All, > In Matlab, I have this function: > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > When I try to see the result of y(0.5) on the m-file, the system > generates a synatx error: > > ??? Error using ==> run > Attempted to access y(0.5); index must be a positive integer or > logical. > The question is that how can I access this value as I need to sample > this function into 1000 intervals, and use these samples for discrete > analysis. > My program is: > > function wave=haarX(); > x = [0:0.001:1]; > > > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > %y(0.5); > for i=1:length(x) > Array(i) = y(i/1000); > end > Thanks for time and your response is much appreciated. > Sincerely, > Kalyidx=find(x==0.5); Y = y(yidx); Rune
kal wrote:> Hello All, > In Matlab, I have this function: > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > When I try to see the result of y(0.5) on the m-file, the system > generates a synatx error: > > ??? Error using ==> run > Attempted to access y(0.5); index must be a positive integer or > logical. > The question is that how can I access this value as I need to sample > this function into 1000 intervals, and use these samples for discrete > analysis. > My program is: > > function wave=haarX(); > x = [0:0.001:1]; > > > y = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); > %y(0.5); > for i=1:length(x) > Array(i) = y(i/1000); > endKal -- in your program, you DO NOT have a function y(x); you have a MATLAB statement creating a vector y from another vector x. If you wish to use y(x) as a function, then I suggest that your program should look something like this, with an internal function y(x): function wave=haarX(); x = [0:0.001:1]; for i=1:length(x) Array(i) = y(i/1000); end end function value = y(x) value = 20 * (x.^2).* ((1-x).^4) .* cos (12 * pi * x); end cheers, jerry
