Hello, The mathematics of frequency mixing seems so simple, but I always end up getting confused when I am trying to relate the math to what I observe in the lab - I don't get the correct products - have to change a sign or something to get things to work out correctly. Right now, I am trying to come up with the power transfer function of sinewave that is delayed and frequency, mixed with itself. One way I think of an "ideal mixer" in the time domain is as a multipler - in the frequency domain I think of it as a convolver. But if I think of the mixing process as a difference in the frequency domain (which seems intuitively obvious), I get the power transfer function that corresponds with my observations: H(w)=1-e^jwT, or |H(w)|^2=2*(1-cos(w*T)), where T is the delay. I tried to prove to myself that a mixer performs a difference in the frequency domain by taking the simplest case, but couldn't work it out. If I difference the fourier transform of two complex functions, e^jw1t and e^jw2t (to inspect the resulting difference frequency w1-w2) I have to difference two delta functions, and, embarassingly I don't know how to do that. I then got even more confused when I tried to just sit down and prove to myself that the mixer does indeed perform a convolution, by convolving the aforementioned delta functions, but ended up with a delta function at w1+w2 - not w1-w2. Can someone help me out with this? Is there a paper or book that lines out frequency mixing so I can understand the basic math of mixing? I would assume this is basic linear systems stuff. And is it valid to think of mixing as a difference, not a convolution, in the frequency domain? Thanks, John M.
mixing a sinewave with time delayed replica of itself
Started by ●July 27, 2006
Reply by ●July 27, 20062006-07-27
JohnReno wrote:> Hello, > The mathematics of frequency mixing seems so simple, but I always end up > getting confused when I am trying to relate the math to what I observe in > the lab -Mixing a sine wave with itself will give you a sine with 2x the frequency and a DC term. The value of the DC term depend on the PHASE relationship betwen the two inputs to the mixer... A mixer and phase detector are both fundamentally multipliers. When used as a phase detector, the low frequency DC term is kept and the higher stuff is filtered out. Mark
