Hi, I have used TMS320VC5510 DSK to connect with a RF module through SPI. I encounter a problem that using scope I can see the correct timing of transmit data, receive data, FSX, and CLKX. But after that RRDY in SPCR10 does not pulled high. More detail, I try to write a register in RF module and read it back, checking whether it is the same. I'm sure that in scope I see the writing did happens and RF module did transmit the register data back to me. But I did not see any change in RRDY. In the reason I can't receive data by detecting RRDY. Does there have some procedure that I've lost to do? I would be very appreciated for your helping. Regards, SJ Hsu ------------------------------------------------------------------------ ps1. The RF module works as following sequences : ------------------------------------------------------------------------ A. Write: 1. Generate FSX as slave enable, generate CLKX (SCLK). 2. First write 8 bits address. 3. Then write 8 bits data. B. Read: 1. Generate FSX as slave enable, generate CLKX (SCLK). 2. First write 8 bits address. 3. Then RF module will reponse 8 bits data back. RF module will not care the incoming data while it is responding. ------------------------------------------------------------------------ ps2. Following is my setting about SPI and my code. ------------------------------------------------------------------------ MCBSP_Config spi_Init = { 0x1830, /* Serial Port Control Register 1 */ 0x0130, /* Serial Port Control Register 2 */ 0x0040, /* Receive Control Register 1 */ 0x0005, /* Receive Control Register 2 */ 0x0040, /* Transmit Control Register 1 */ 0x0005, /* Transmit Control Register 2 */ 0x001f, /* Sample Rate Generator Register 1 */ 0x2000, /* Sample Rate Generator Register 2 */ 0x0000, /* Multichannel Control Register 1 */ 0x0000, /* Multichannel Control Register 2 */ 0x0e09, /* Pin Control Register */ 0x0000, /* Receive Channel Enable Register Partition A */ 0x0000, /* Receive Channel Enable Register Partition B */ 0x0000, /* Receive Channel Enable Register Partition C */ 0x0000, /* Receive Channel Enable Register Partition D */ 0x0000, /* Receive Channel Enable Register Partition E */ 0x0000, /* Receive Channel Enable Register Partition F */ 0x0000, /* Receive Channel Enable Register Partition G */ 0x0000, /* Receive Channel Enable Register Partition H */ 0x0000, /* Transmit Channel Enable Register Partition A */ 0x0000, /* Transmit Channel Enable Register Partition B */ 0x0000, /* Transmit Channel Enable Register Partition C */ } void spi_init () { MCBSP_FSET(SPCR10, RRST, 0) ; // reset Rx MCBSP_FSET(SPCR20, XRST, 0) ; // reset Tx MCBSP_FSET(SPCR20, FRST, 0) ; // reset frame-sync logic MCBSP_FSET(SPCR20, GRST, 0) ; // reset sample rate generator MCBSP_config(hMcbsp0, &spi_Init) ; MCBSP_FSET(SPCR20, GRST, 1); // enable sample rate generator MCBSP_FSET(SPCR20, FRST, 1); // enable frame-sync logic MCBSP_FSET(SPCR10, RRST, 1); // set Rx MCBSP_FSET(SPCR20, XRST, 1); // set Tx } void spi_sw(UINT8 addr, UINT8* dataPtr) { //UINT16 i ; addr = (addr << 9) | 0x0100 ; addr = addr | (*dataPtr) ; while (MCBSP_FGET(SPCR20,XRDY)== 0) {} // write address to DXR MCBSP_RSET (DXR20,0) ; MCBSP_RSET (DXR10,addr); //for(i = 0; i < 1000; i++) ; } void spi_sr(UINT8 addr, UINT8* dataPtr) { addr = ((UINT16)addr << 9) ; while (MCBSP_FGET(SPCR20,XRDY)== 0) {} // write address to DXR MCBSP_RSET (DXR20,0) ; MCBSP_RSET (DXR10,addr); while (MCBSP_FGET(SPCR10,RRDY) == 0) {} *dataPtr = MCBSP_RGET(DRR10) ; } UINT8 d = 0xaa ; UINT8 r = 0x01 ; void main() { spi_init() ; spi_sw(0x01, &d) ; spi_sr(0x01, &r) ; printf("The returned value : %d", r) ; }
McBSP as SPI master problem
Started by ●August 15, 2006
Reply by ●August 15, 20062006-08-15
Sorry everyone, I post this in wrong place and I can not find where to delete this post. Please recept my apology. Best Regards, SJ Hsu>Hi, I have used TMS320VC5510 DSK to connect with a RF module throughSPI.>I encounter a problem that using scope I can see the correct timing >of transmit data, receive data, FSX, and CLKX. But after that RRDY in >SPCR10 does not pulled high. > >More detail, I try to write a register in RF module and read it back, >checking whether it is the same. I'm sure that in scope I see thewriting>did happens and RF module did transmit the register data back to me. ButI>did not see any change in RRDY. > >In the reason I can't receive data by detecting RRDY. Does there havesome>procedure that I've lost to do? I would be very appreciated for your >helping. > >Regards, SJ Hsu >------------------------------------------------------------------------ >ps1. The RF module works as following sequences : >------------------------------------------------------------------------ > A. Write: > 1. Generate FSX as slave enable, generate CLKX (SCLK). > 2. First write 8 bits address. > 3. Then write 8 bits data. > B. Read: > 1. Generate FSX as slave enable, generate CLKX (SCLK). > 2. First write 8 bits address. > 3. Then RF module will reponse 8 bits data back. RF module will > not care the incoming data while it is responding. >------------------------------------------------------------------------ >ps2. Following is my setting about SPI and my code. >------------------------------------------------------------------------ >MCBSP_Config spi_Init = { > 0x1830, /* Serial Port Control Register 1 */ > 0x0130, /* Serial Port Control Register 2 */ > 0x0040, /* Receive Control Register 1 */ > 0x0005, /* Receive Control Register 2 */ > 0x0040, /* Transmit Control Register 1 */ > 0x0005, /* Transmit Control Register 2 */ > 0x001f, /* Sample Rate Generator Register 1 */ > 0x2000, /* Sample Rate Generator Register 2 */ > 0x0000, /* Multichannel Control Register 1 */ > 0x0000, /* Multichannel Control Register 2 */ > 0x0e09, /* Pin Control Register */ > 0x0000, /* Receive Channel Enable Register Partition A */ > 0x0000, /* Receive Channel Enable Register Partition B */ > 0x0000, /* Receive Channel Enable Register Partition C */ > 0x0000, /* Receive Channel Enable Register Partition D */ > 0x0000, /* Receive Channel Enable Register Partition E */ > 0x0000, /* Receive Channel Enable Register Partition F */ > 0x0000, /* Receive Channel Enable Register Partition G */ > 0x0000, /* Receive Channel Enable Register Partition H */ > 0x0000, /* Transmit Channel Enable Register Partition A */ > 0x0000, /* Transmit Channel Enable Register Partition B */ > 0x0000, /* Transmit Channel Enable Register Partition C */ >} > >void spi_init () >{ > MCBSP_FSET(SPCR10, RRST, 0) ; // reset Rx > MCBSP_FSET(SPCR20, XRST, 0) ; // reset Tx > MCBSP_FSET(SPCR20, FRST, 0) ; // reset frame-sync logic > MCBSP_FSET(SPCR20, GRST, 0) ; // reset sample rate generator > > MCBSP_config(hMcbsp0, &spi_Init) ; > > MCBSP_FSET(SPCR20, GRST, 1); // enable sample rate generator > MCBSP_FSET(SPCR20, FRST, 1); // enable frame-sync logic > > MCBSP_FSET(SPCR10, RRST, 1); // set Rx > MCBSP_FSET(SPCR20, XRST, 1); // set Tx > >} > > > >void spi_sw(UINT8 addr, UINT8* dataPtr) >{ > //UINT16 i ; > > addr = (addr << 9) | 0x0100 ; > addr = addr | (*dataPtr) ; > > while (MCBSP_FGET(SPCR20,XRDY)== 0) {} > > // write address to DXR > MCBSP_RSET (DXR20,0) ; > MCBSP_RSET (DXR10,addr); > > //for(i = 0; i < 1000; i++) ; >} > > > >void spi_sr(UINT8 addr, UINT8* dataPtr) >{ > addr = ((UINT16)addr << 9) ; > > while (MCBSP_FGET(SPCR20,XRDY)== 0) {} > > // write address to DXR > MCBSP_RSET (DXR20,0) ; > MCBSP_RSET (DXR10,addr); > > while (MCBSP_FGET(SPCR10,RRDY) == 0) {} > > *dataPtr = MCBSP_RGET(DRR10) ; >} > > > >UINT8 d = 0xaa ; >UINT8 r = 0x01 ; > >void main() >{ > spi_init() ; > > spi_sw(0x01, &d) ; > > spi_sr(0x01, &r) ; > > printf("The returned value : %d", r) ; > >} > > >
SJ Hsu wrote:> Sorry everyone, I post this in wrong place and I can not find where to > delete this post. Please recept my apology.Display the post in your newsreader and use the "delete" key on your keyboard. Not every news server honors a delete request, but many do. (Yahoo might not.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 30, 20062006-08-30
Hi, have a look at MCBSP_SPCR_RINTM_RRDY bit in your serial port control register. You can view all the registers related to the mcbsp interface via code composer studio and if the DRR1/0 register isn=B4t written something is wrong with your port configuration - maybe the RRDY irq mode is enabled but the receiver is waiting for a wrong word length. I use the mcbsp with the c6 dsp family and configure these interfaces also for spi. If you use the chip support library (CSL) you get more readerfriendly code. regards stephan
