tony.nospam@nospam.tonyRobinson.com wrote:> Rune, > > I wrote a long reply which on re-reading of it has turned into somewhat > of a rant, so I'm not going to post it and see instead if we can agree > on what's causing you so much upset. > > I think you are saying that you view the proposed task as a comparison > over all possible signals where you view the pattern space as vast and > impossible to enumerate and so you feel there will always be some part > of the pattern space that is poorly modelled.Agreed.> I view the task as one of > a comparison over pattern space for which it is possible to come up with > realistic model of the distribution. The space may still be vast and > impossible to enumerate but over the distribution considered sensible > models may be formulated and evaluated. > Do we agree on this?I agree that this is a sensible way of attacking the problem. Our disagreement is on whether it is this approach that is outlined in the ad, and whether it is this approach the applicant will be assigned to work with. If you are certain your description represents the work at your institution, I suggest you should have a quiet word with whoever wrote that ad and published it as an official ICSI document.> Otherwise you finished your last post with an > indefensible libellous on ICSI, so I shall don my flameproof suit...Maybe indefensible what ICSI is concerned, as I have never worked there, but completely defensible with respect to the majority of my previous projects and employers. There ARE people around who regard "compare the measured data to all possible models, each with all possible parametrizations" as a sane, viable way to analyze data. There ARE people -- distingushed professors with dozens of publicatuions and decades of tenure, no less -- who regard detonating on the order of 50-100 kg of TNT on a regular basis as a perfectly viable (if somewhat expensivee as one would have to use P3 aircraft to deploy the charges) preparation for PASSIVE sonar. I've worked with both approaches. No fun. No fun whatsoever. Rune
Post-doc in Acoustic Event Detection (US citizens only)
Started by ●August 24, 2006
Reply by ●August 25, 20062006-08-25
"Rune Allnor" <allnor@tele.ntnu.no> writes:> tony.nospam@nospam.tonyRobinson.com wrote: > > > I view the task as one of > > a comparison over pattern space for which it is possible to come up with > > realistic model of the distribution. The space may still be vast and > > impossible to enumerate but over the distribution considered sensible > > models may be formulated and evaluated. > > Do we agree on this? > > I agree that this is a sensible way of attacking the problem. Our > disagreement is on whether it is this approach that is outlined in > the ad, and whether it is this approach the applicant will be > assigned to work with.Here is the original wording again: "The Fellow will be working with Nelson Morgan, along with international colleagues, in the area of the detection of one particular target word and/or sound in the background of all other possible words or any other realistic sounds." The "all other possible" refers to words, and we are agreed that it is possible to make reasonable approximations to the distributions of word acoustic features (that's how large vocabulary speech recognition works). I think the use of the word "realistic" in the second part, "any other realistic sounds", implies that it's also possible to make reasonable approximations to the distributions of the non-word acoustic features. I don't think that this needs to be made any more explicit in a job advert. However, you've obviously had some bad experiences which has fired you up on this topic. On the other hand I've had a very good time working with Morgan and the ICSI team. So naturally there is plenty of fuel on both sides for full scale ranting here. I'm very confident that your fears are unfounded in this case, but after what you've said then, yes, there are probably research projects running out there with unrealistic goals, and yes, that is no fun whatsoever. Tony
Wasting taxpayer money ? OK, keep wasting it for now... until someone comes up with the perfect feature extractor (a.k.a "artificial ear") for speech recognition. Then you are out of work... dave_gelbart@yahoo.com wrote:> The International Computer Science Institute (ICSI) invites > applications for a postdoctoral Fellow position in acoustic event > detection. The Fellow will be working with Nelson Morgan, along with > international colleagues, in the area of the detection of one > particular target word and/or sound in the background of all other > possible words or any other realistic sounds. The applicant is expected > to have strong capabilities in signal processing. Familiarity with > speech algorithms per se is a plus but is not absolutely required. > > ICSI is an independent not-for-profit institute located a few blocks > from the University of California Berkeley campus. It is closely > affiliated with the University, and particularly with the EECS > Department. It has world-class activities in Internet research, natural > language processing, bioinformatics, and speech processing. See > www.icsi.berkeley.edu to learn more about ICSI. > > The ICSI Speech Group (including its predecessor, the ICSI Realization > Group) has been a source of novel approaches to speech processing since > 1988. It is primarily known for its work in speech recognition, > although it has housed major projects in speaker recognition and > metadata extraction in the last few years. The new effort will draw > upon lessons learned in our feature extraction work for speech > recognition. > > Applications should include a cover letter, vita, and the names of at > least 3 references (with both postal and email addresses). Applications > should be sent by email to morgan@icsi.berkeley.edu or by postal mail > to: > > Director (re Acoustic Event Detection Postdoctoral Search) > ICSI > 1947 Center Street Suite 600 > Berkeley, CA 94704 > > ICSI is an Affirmative Action/Equal Opportunity Employer. Applications > from women and minorities are especially encouraged. > > For this particular position, US citizenship is required.
"Rune Allnor" <allnor@tele.ntnu.no> wrote in news:1156489566.536459.51370@ 75g2000cwc.googlegroups.com:> The term "all possible" is insane from both an engineering and a R&D > point of view. How do you know that you have covered **all**possible** > variants of anything?"All possible" of course approaches hyperbole, but its a rather convenient term to make your goals understood in a short sentence in lay language, which is what's usually required if you expect to successfully attract funding from government sources. -- Scott Reverse name to reply
Rune Allnor wrote: ...> The term "all possible" is insane from both an engineering and a R&D > point of view. How do you know that you have covered **all**possible** > variants of anything? How do you know that some person from half-way > around the world doesn't throw in the odd word of his native language? > There are some languages of the bushmen in the Namib desert that > sound like clicks to me and most probably to almost everybody else > in the world. Do you count these "clicks" among the "all possible > words" of yours? If not, on what basis do you discriminate between > "possible" and "impossible" words? > > Paying attention to detail is the key characteristic of the > professional, > irrespective of trade or craft.I'm reminded of a line from the movie /Cool Hand Luke/: "What we have here is a failure to communicate." These PR types get so caught up in (what they think is) fancy rhetoric that they lose sight of the actual meaning of what they write. It's such a widespread failing that most of the time it slides by without anyone noticing. I applaud Rune for picking up on it this time. I'm tired of guessing at probable meanings. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
tony.nospam@nospam.tonyRobinson.com wrote:> "Rune Allnor" <allnor@tele.ntnu.no> writes: > > > tony.nospam@nospam.tonyRobinson.com wrote: > > > > > I view the task as one of > > > a comparison over pattern space for which it is possible to come up with > > > realistic model of the distribution. The space may still be vast and > > > impossible to enumerate but over the distribution considered sensible > > > models may be formulated and evaluated. > > > Do we agree on this? > > > > I agree that this is a sensible way of attacking the problem. Our > > disagreement is on whether it is this approach that is outlined in > > the ad, and whether it is this approach the applicant will be > > assigned to work with. > > Here is the original wording again: "The Fellow will be working with > Nelson Morgan, along with international colleagues, in the area of the > detection of one particular target word and/or sound in the background > of all other possible words or any other realistic sounds." > > The "all other possible" refers to words, and we are agreed that it is > possible to make reasonable approximations to the distributions of word > acoustic features (that's how large vocabulary speech recognition > works).These are three statements in one sentence: 1) The scope of ambition ("all possible words") 2) The reasonable characterization of sound signals 3) The characterization of "word acoustic features" As far as I recall, I have agreed to only one of these premises, item 2), that it is reasonable to define features of acoustic signals that may turn out to be useful in some sort of analysis. As for item 1), it ought to be clear by now that I regard that stype of scope as insane. I have never agreed to item 3, which I can only interpret to state that there is some characteristic unique to human words, as opposed to both non-anthropogenic sounds or anthropogenic sounds that are not words. Please refer to any statement of mine you might have interpreted as such an agreement, and we will sort out the misunderstanding. As for vocabulary speech recognition, please refer to any system that does *not* take advantage of a severely constrained data recording. I only know of vocabulary speech recognition systems where the signal to be processed is *known* to be of a human voice, like in a telephone or where the user wears a microphone. The restriction of the data recording to contain almost solely human speech, is one of those tiny details which implications a theoretician with no relevant practical experience would understand.> I think the use of the word "realistic" in the second part, > "any other realistic sounds", implies that it's also possible to make > reasonable approximations to the distributions of the non-word acoustic > features. I don't think that this needs to be made any more explicit in > a job advert.The job advert is as explicit as it can get in that the issuing institution is not by any means up to scratch, professionally speaking: - Somebody drafted an ad that not by any stretch of the imagination can be said to be realistic in scope - Somebody did not catch this glitch during proofreading - The ad needs considerable interpretation, goodwill and sheer incompetence with the reader to be regarded as interesting - The ad projects an image to the general public about what these people work with, that isn't by any means realistic - The ad confirms various views held by laymen about what it is reasonable to expect from speech processing technology in general, and this institution in particular Every time I have got myself into a really bad project, my instincts and alarm bells have trigged on far more subtle clues than these. Rune
"Rune Allnor" <allnor@tele.ntnu.no> wrote in news:1156521775.946503.254890@ 74g2000cwt.googlegroups.com:> I have never agreed to item 3, which I can only interpret to > state that there is some characteristic unique to human > words, as opposed to both non-anthropogenic sounds or > anthropogenic sounds that are not words.There is huge research along such lines in the language area. Richard Aslin and Elissa Newport spring to mind as possible search terms. -- Scott Reverse name to reply
Scott Seidman wrote:> "Rune Allnor" <allnor@tele.ntnu.no> wrote in news:1156489566.536459.51370@ > 75g2000cwc.googlegroups.com: > > > The term "all possible" is insane from both an engineering and a R&D > > point of view. How do you know that you have covered **all**possible** > > variants of anything? > > > > "All possible" of course approaches hyperbole, but its a rather convenient > term to make your goals understood in a short sentence in lay language, > which is what's usually required if you expect to successfully attract > funding from government sources.Ah, now we are approaching interesting waters. For some reason, I have noted that quite a few people who have gained extreme levels of skills in some subject tend to regard other people who have not gained the same levels in general, in the same subjects in particular, as somehow "inferior" or even all out "stupid". I don't agree with such views. In my experience, literate people -- even laymen what my own field of work is concerned -- are actually able to comprehend written text. The term "all possible" has a very definite meaning: It means that a technique covers "all possible" variations of whatever, and in that sense, the technique is perfect. Pepole tend to understand such claims. What's more, they are able to review test results and expect the method in question to actually cover "all possible" situations. Stay clear of projects where such claims are made. Somebody in the funding institutions will, some day, start asking questions why the explicitly stated goals are not met. Rune
Scott Seidman wrote:> "Rune Allnor" <allnor@tele.ntnu.no> wrote in news:1156521775.946503.254890@ > 74g2000cwt.googlegroups.com: > > > I have never agreed to item 3, which I can only interpret to > > state that there is some characteristic unique to human > > words, as opposed to both non-anthropogenic sounds or > > anthropogenic sounds that are not words. > > There is huge research along such lines in the language area. Richard > Aslin and Elissa Newport spring to mind as possible search terms.Is their test(s) able to include the tongue clicks of the Namib bushmen? And distinguish that from a six-year old clicking and singing to herself in a make-believe language while playing in the garden? Does their test(s) distiguish between human speech and a parrot uttering the same phrase? Does their test(s) separate human sound from synthesized computer voices? The claim that a technique classifies something as anthropogenic, as opposed to parrots or computers, and word, as opposed to humming or make-believe languages, is pretty bold. It only takes one failed test to kick the feet away under it. Rune
"Rune Allnor" <allnor@tele.ntnu.no> wrote in news:1156522496.169055.197210 @i42g2000cwa.googlegroups.com:> > I don't agree with such views. > > In my experience, literate people -- even laymen what my own > field of work is concerned -- are actually able to comprehend > written text. The term "all possible" has a very definite meaning: > It means that a technique covers "all possible" variations of > whatever, and in that sense, the technique is perfect. Pepole > tend to understand such claims. What's more, they are able > to review test results and expect the method in question to > actually cover "all possible" situations. > > Stay clear of projects where such claims are made. Somebody > in the funding institutions will, some day, start asking questions > why the explicitly stated goals are not met. > > Rune >I'm merely suggesting that in documents like this, you really don't know what the real claims are simply by reading the abstract. If you could, then journals would consist of a stack of abstracts. -- Scott Reverse name to reply
