Hi Folks, According to both [proakiscomm] and [bracewell], the convolution integral is defined to be y(t)= \int_{-\infty}^{+\infty} x(\tau) g(t - \tau) d\tau. Notice that there is no dependence in the limits of integration on the independent variable "t." HOWEVER, in Proakis' second equation in deriving the matched filter, equation 5.1-15, which is describing the matched filter output, he writes: y_k(t) = \int_{0}^{t} r(\tau) h_k(t-tau) d\tau. Now since both r(t) and h_k(t) are non-zero only in the range 0 <= t < T, then the expression above is true. However, it seems to be non-standard, and since there is nothing subsequently that requires this form, unnecessarily complex. Thoughts? Why would Proakis write the equation in this form? --Randy @BOOK{proakiscomm, title = "{Digital Communications}", author = "John~G.~Proakis", publisher = "McGraw-Hill", edition = "fourth", year = "2001"} @BOOK{bracewell, title = "{The Fourier Transform and Its Applications}", author = "{Ronald~N.~Bracewell}", publisher = "McGraw-Hill", edition = "second", year = "1986"} -- % Randy Yates % "Midnight, on the water... %% Fuquay-Varina, NC % I saw... the ocean's daughter." %%% 919-577-9882 % 'Can't Get It Out Of My Head' %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Why Strange Form of Convolution Integral in Proakis' Matched Filter Discussion?
Started by ●August 28, 2006
Reply by ●August 28, 20062006-08-28
Randy Yates said the following on 28/08/2006 14:24:> According to both [proakiscomm] and [bracewell], the convolution integral > is defined to be > > y(t)= \int_{-\infty}^{+\infty} x(\tau) g(t - \tau) d\tau. > > Notice that there is no dependence in the limits of integration on the > independent variable "t." > > HOWEVER, in Proakis' second equation in deriving the matched filter, > equation 5.1-15, which is describing the matched filter output, he > writes: > > y_k(t) = \int_{0}^{t} r(\tau) h_k(t-tau) d\tau. > > Now since both r(t) and h_k(t) are non-zero only in the range > 0 <= t < T, then the expression above is true. However, it seems > to be non-standard, and since there is nothing subsequently > that requires this form, unnecessarily complex. > > Thoughts? Why would Proakis write the equation in this form? >As it says in the line above that equation: "h_k(t) = 0 outside of the interval 0 <= t <= T" -- Oli
Randy Yates <yates@ieee.org> writes:> Hi Folks, > > According to both [proakiscomm] and [bracewell], the convolution integral > is defined to be > > y(t)= \int_{-\infty}^{+\infty} x(\tau) g(t - \tau) d\tau.Sorry, I meant to write According to both [signalsandsystems] and [bracewell], the convolution integral is defined to be . . . @BOOK{signalsandsystems, title = "{Signals and Systems}", author = "{Alan~V.~Oppenheim, Alan~S.~Willsky, with Ian~T.~Young}", publisher = "Prentice Hall", year = "1983"} @BOOK{bracewell, title = "{The Fourier Transform and Its Applications}", author = "{Ronald~N.~Bracewell}", publisher = "McGraw-Hill", edition = "second", year = "1986"} -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Oli Filth said the following on 28/08/2006 14:25:> Randy Yates said the following on 28/08/2006 14:24: >> According to both [proakiscomm] and [bracewell], the convolution integral >> is defined to be >> >> y(t)= \int_{-\infty}^{+\infty} x(\tau) g(t - \tau) d\tau. >> >> Notice that there is no dependence in the limits of integration on the >> independent variable "t." >> >> HOWEVER, in Proakis' second equation in deriving the matched filter, >> equation 5.1-15, which is describing the matched filter output, he >> writes: >> >> y_k(t) = \int_{0}^{t} r(\tau) h_k(t-tau) d\tau. >> >> Now since both r(t) and h_k(t) are non-zero only in the range >> 0 <= t < T, then the expression above is true. However, it seems >> to be non-standard, and since there is nothing subsequently >> that requires this form, unnecessarily complex. >> Thoughts? Why would Proakis write the equation in this form? >> > > As it says in the line above that equation: > > "h_k(t) = 0 outside of the interval 0 <= t <= T" >Oops, sorry, I missed that you already said that yourself. I think the point is that as we only need to integrate over T, we can implement it as an integrate-and-dump architecture. -- Oli
Oli Filth <catch@olifilth.co.uk> writes:> Oli Filth said the following on 28/08/2006 14:25: >> Randy Yates said the following on 28/08/2006 14:24: >>> According to both [proakiscomm] and [bracewell], the convolution integral >>> is defined to be >>> >>> y(t)= \int_{-\infty}^{+\infty} x(\tau) g(t - \tau) d\tau. >>> >>> Notice that there is no dependence in the limits of integration on the >>> independent variable "t." >>> >>> HOWEVER, in Proakis' second equation in deriving the matched filter, >>> equation 5.1-15, which is describing the matched filter output, he >>> writes: >>> >>> y_k(t) = \int_{0}^{t} r(\tau) h_k(t-tau) d\tau. >>> >>> Now since both r(t) and h_k(t) are non-zero only in the range >>> 0 <= t < T, then the expression above is true. However, it seems >>> to be non-standard, and since there is nothing subsequently >>> that requires this form, unnecessarily complex. >>> Thoughts? Why would Proakis write the equation in this form? >>> >> As it says in the line above that equation: >> "h_k(t) = 0 outside of the interval 0 <= t <= T" >> > > Oops, sorry, I missed that you already said that yourself. I think > the point is that as we only need to integrate over T, we can > implement it as an integrate-and-dump architecture.Hi Oli, The obvious alternate [non-t-dependent in the limits] representation of the convolution given the domains of the functions in use would be y_k(t) = \int_{0}^{T} r(\tau) h_k(t-tau) d\tau. In that representation, the sum-and-dump becomes apparent when we let t = T, y_k(T) = \int_{0}^{T} r(\tau) h_k(T-tau) d\tau. Again, I don't see the need to use the confusing form of the convolution. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
