Lol @ the star trek joke. Just a thought : i know it wouldnt be a constructive suggestion, but wouldnt it be faster to program in assembler?? There is a software VisualDSP++ which has a very reliable compiler. I programmed a circular buffer to run an echo signal in the 21065 Sharc once, and it worked very well. Hmmmm.
faster way to implement a circular buffer
Started by ●September 2, 2006
Reply by ●September 2, 20062006-09-02
Oli Filth wrote:> Not upset, just confused! (Not least because I've never seen Star Trek...)Where they have to save a pair of whales ... ? http://www.imdb.com/title/tt0092007/
Have a look here for FIR filtering examples on the ADSP-2136x: http://www.analog.com/processors/sharc/technicalLibrary/codeExamples/2136x_simd_code.html --------- Thanks. I had a look at it. I'm not sure I can use that since I am not trying to implement a FIR filter?
There is a software> VisualDSP++ which has a very reliable compiler. I programmed a circular > buffer to run an echo signal in the 21065 Sharc once, and it worked very > well. Hmmmm.I'm using VisualDSP++. However, I am not an experienced assembly-programmer. I read somewhere that I can use macros for setting up circular buffers, but I can't find this litterature....
dilpreet06 wrote:> Lol @ the star trek joke. > > Just a thought : i know it wouldnt be a constructive suggestion, but > wouldnt it be faster to program in assembler?? There is a software > VisualDSP++ which has a very reliable compiler. I programmed a circular > buffer to run an echo signal in the 21065 Sharc once, and it worked very > well. Hmmmm.Why not constructive? I'm always irked by a need to psych a compiler into producing exactly the assembly code I I know I want in the first place. As long as I can call the assembly routine from HLL -- sometimes even if it means saving and restoring a lot of registers -- it's likely to be the most straightforward (hence bug-free) way. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 2006-09-02, Oli Filth <catch@olifilth.co.uk> wrote:>>> CyclicCounter=CyclicCounter%256; > ... >> in general, for C, the faster way is to mask: >> >> CyclicCounter=CyclicCounter&0xFF; > > Wouldn't a decent compiler perform this sort of optimisation > automatically? (Just as it might optimise x/2 to x>>1, etc.).As the old saying goes, the implementation may cheat, but it must not get caught. If CyclicCounter is unsigned, then those are identical. If it's signed, the compiler has to add extra code to handle negative values. It's not nearly as costly as an actual divide, but if you are counting instructions in an inner loop it might matter. -- Ben Jackson AD7GD <ben@ben.com> http://www.ben.com/
Hans S=F8rensen wrote:> Have a look here for FIR filtering examples on the ADSP-2136x: > > http://www.analog.com/processors/sharc/technicalLibrary/codeExamples/2136=x_simd_code.html> > --------- > > > Thanks. I had a look at it. I'm not sure I can use that since I am not > trying to implement a FIR filter?i'm not quite as sanguine about how good VisualDSP++ is (how good the compiled code comes out to be). i know what the syntax was in the "old" SHArC C compiler for assigning register varibles in C to specific registers in asm (i didn't think it worked so good). anyway what is the syntax to do that now? can you assign one register float* to B1 and another to I1 (set both to the buffer base) and then assign a register long to L1 (set it to the buffer length)? or a similar set of address registers? then you can just plop stuff on the buffer using autoincrement on the I1 register (in the C code) and not worry about it not wrapping. same thing for offsets on that register (it should wrap automagically). r b-j
Hans S=F8rensen schrieb:> Have a look here for FIR filtering examples on the ADSP-2136x: > > http://www.analog.com/processors/sharc/technicalLibrary/codeExamples/2136=x_simd_code.html> > --------- > > > Thanks. I had a look at it. I'm not sure I can use that since I am not > trying to implement a FIR filter?These FIR filters are implemented with circular buffers ...
Andor wrote:>> Wouldn't a decent compiler perform this sort of optimisation >> automatically? (Just as it might optimise x/2 to x>>1, etc.).If x is signed, they are not the same. Divison rounds towards zero, bitshift rounds down. -- Mark Borgerding
Mark Borgerding wrote:> Andor wrote: >>> Wouldn't a decent compiler perform this sort of optimisation >>> automatically? (Just as it might optimise x/2 to x>>1, etc.). > > If x is signed, they are not the same. > > Divison rounds towards zero, bitshift rounds down.The rounding of division is implementation dependent. When using integer calculation of coordinates, including best approximation of straight lines and circles, rounding toward negative infinity avoids extra discontinuity around zero. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
