hi, I am a starter of CCS. And i started by trying to run a COFF file provided by ti, examples.out, and it turned out successful. However, when i try to build the .mak file in the CCS i encountered some errors and could not build successfully due to many undefined symbols which are contained in the header file. I tried adding all the required header files to the project but it still cant work. Can anyone give me some suggestions? Thank you, your help is greatly appreciated. regards, Geran Lau
Need Help with code composer studio version 1.2
Started by ●September 22, 2006
Reply by ●September 22, 20062006-09-22
"lauy0001" <lauy0001@msn.com> writes:> hi, > > I am a starter of CCS. And i started by trying to run a COFF file provided > by ti, examples.out, and it turned out successful. However, when i try to > build the .mak file in the CCS i encountered some errors and could not > build successfully due to many undefined symbols which are contained in > the header file. > > I tried adding all the required header files to the project but it still > cant work. > > Can anyone give me some suggestions? > > Thank you, your help is greatly appreciated.Hi Geran, Can you post the output of the make file? -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://home.earthlink.net/~yatescr
