VDVI and DVI4
Started by Steve Underwood September 27, 2006
Hi all,
RFC3551 defines the way in which the output from a number of codecs
should be packed into RTP packets. Amongst these is the DVI ADPCM codec,
commonly found on PCs. They refer to this as DVI4. Also, there is VDVI,
which is a kind of run length encoded variable bit rate version of DVI.
They quote some low potential numbers for its bit rate, which don't seem
to make sense. The 4 bit codes from the DVI codec are fairly white, so I
really can't see how run length encoding helps in any way. Even a small
background noise in periods of "silence" exercises all the 4 bit codes
from the codec fairly evenly. Has anyone seen VDVI used in a real
application?
Regards,
Steve
