Hi DSPers. I want to do a master PCI read from host memory. My test code looks something like this... Uint32 dsp_addr = 0x81000000; Uint32 host_addr = 0x1ef60000; Uint32 count = 64; Uint32 ctlreg; ... VFDM642_init(); CSL_init(); ... ctlreg = count << 16; PCI_xfrConfigArgs(dsp_addr, host_addr, ctlreg, PCI_TRCTL_DEFAULT); PCI_xfrStart(PCI_READ_PREF); while (test = PCI_xfrTest()) ; However, the transfer never completes. Examining the registers, as expected DSPMA is 0x81000000, PCIMA is 0x1ef60000 and PCIMC is (64<<16)+2 (2 being the code for prefetchable read). The current registers seem to be set to begin the transfer (i.e. CDPSA is 0x81000000, CPCIA is 0x1ef60000 and CCNT is 64). But that's how it stays. No interrupts are generated, i.e only CFGDONE is set in PCIIS. On the host side, a Linux driver has previously set up the host registers (DSPP, etc. and mapped the prefetchable and non-prefetchable memory windows. This works fine (the host can see DSP memory, and interrupts can occur in both directions). Any ideas? Does the host need to do something to allow master reads by the DSP. Another complication is there's two identical DSP cards in the system, is this likely to cause a problem? Cheers mark-r -- Currently sigless
DM642 PCI Master reads not starting
Started by ●September 29, 2006
