Hi everybody i'm newbie in DSP, I'm writing an application in Java. My application does the following: Trace an ECG diagram, diagram is represented by an array of 2000 values, the signal duration is 4 secs, it's mean 500 points/second, so my frequency is 500Hz. Now my application must remove 60 Hz noise from diagram using notch filter. I dodn't know how to process exactely, but if i understood: W0 = 2*pi*f0/fs where f0 = 60Hz and fs = 500Hz So if the sampling frequency is 500 Hz, the zero at +43,2� will completely eliminate any signal at 60 Hz, is it correct? I got +43,2� from this 2*pi*f0/fs where pi is in degres(180)
remove 60 Hz noise
Started by ●October 5, 2006
Reply by ●October 5, 20062006-10-05
Yes, this is correct. You may have to watch where you put the zeros of the digital filter, basically you want a zero at z0=3De^+/-j(0.24*pi) where 0.24 comes from 60/250 because 250Hz is your Fs/2. This gives an FIR filter at 60Hz given by h =3D z^2 + z 2*Real(-z0) + 1 or an FIR filter with coefficients b0 =3D 1, b1 =3D 2*Real(-z0), b2 =3D 1 hope that helps. col zorgz wrote:> Hi everybody i'm newbie in DSP, > > I'm writing an application in Java. > My application does the following: Trace an ECG diagram, diagram is > represented by an array of 2000 values, the signal duration is 4 secs, > it's mean 500 points/second, so my frequency is 500Hz. > > Now my application must remove 60 Hz noise from diagram using notch > filter. > > I dodn't know how to process exactely, but if i understood: > > W0 =3D 2*pi*f0/fs > where f0 =3D 60Hz and fs =3D 500Hz > > So if the sampling frequency is 500 Hz, the zero at +43,2=B0 will complet=ely> eliminate any signal at 60 Hz, is it correct? >=20 > I got +43,2=B0 from this 2*pi*f0/fs where pi is in degres(180)
You may want to plot the response of this. It gives high-frequency emphasis that you may not want, and you may not like how it shapes the spectrum in general. Dirk Bell DSP Consultant cb135@hotmail.com wrote:> Yes, this is correct. You may have to watch where you put the zeros of > the digital filter, basically you want a zero at z0=3De^+/-j(0.24*pi) > where 0.24 comes from 60/250 because 250Hz is your Fs/2. This gives an > FIR filter at 60Hz given by > > h =3D z^2 + z 2*Real(-z0) + 1 > > or an FIR filter with coefficients b0 =3D 1, b1 =3D 2*Real(-z0), b2 =3D 1 > > hope that helps. > > col > > > zorgz wrote: > > Hi everybody i'm newbie in DSP, > > > > I'm writing an application in Java. > > My application does the following: Trace an ECG diagram, diagram is > > represented by an array of 2000 values, the signal duration is 4 secs, > > it's mean 500 points/second, so my frequency is 500Hz. > > > > Now my application must remove 60 Hz noise from diagram using notch > > filter. > > > > I dodn't know how to process exactely, but if i understood: > > > > W0 =3D 2*pi*f0/fs > > where f0 =3D 60Hz and fs =3D 500Hz > > > > So if the sampling frequency is 500 Hz, the zero at +43,2=B0 will compl=etely> > eliminate any signal at 60 Hz, is it correct? > >=20 > > I got +43,2=B0 from this 2*pi*f0/fs where pi is in degres(180)
Reply by ●October 6, 20062006-10-06
"zorgz" <zorgz@mail.ru> wrote in message news:tpGdnTwg8J7fjrjYnZ2dnUVZ_sGdnZ2d@giganews.com...> Hi everybody i'm newbie in DSP, > > I'm writing an application in Java. > My application does the following: Trace an ECG diagram, diagram is > represented by an array of 2000 values, the signal duration is 4 secs, > it's mean 500 points/second, so my frequency is 500Hz. > > Now my application must remove 60 Hz noise from diagram using notch > filter. > > I dodn't know how to process exactely, but if i understood: > > W0 = 2*pi*f0/fs > where f0 = 60Hz and fs = 500Hz > > So if the sampling frequency is 500 Hz, the zero at +43,2� will completely > eliminate any signal at 60 Hz, is it correct? > > I got +43,2� from this 2*pi*f0/fs where pi is in degres(180) > >H(z)= 1-z^-N/(1-(z/alpha)^-N) where mag (alpha)<1 This is a notch filter. You need to work out N for your sampling freq and alpha = 0.9 say. This will also notch out dc too. M. -- Posted via a free Usenet account from http://www.teranews.com
Major Misunderstanding wrote: <clipped>> H(z)= 1-z^-N/(1-(z/alpha)^-N) where mag (alpha)<1Do you mean: H(z)= (1-z^-N)/(1-(z/alpha)^-N) where mag (alpha)<1 ? Takes out the harmonics too! Dirk> > This is a notch filter. You need to work out N for your sampling freq and > alpha = 0.9 say. > This will also notch out dc too. > > > M. > > > > -- > Posted via a free Usenet account from http://www.teranews.com
