Hi all, I am looking for an efficient implementation of the 2D maximum filter in C++. I tried to write one using the Blitz library, but my code's speed is far slower than the matlab code. I am new to the field and I'm not sure if it is my algorithm that is suboptimal, or if matlab has special optimization I can't achieve. In any case I am looking for either a C++ code for maximum filtering, or advice on algorithm and implementation. My image is 512 x 512 and the filter is 11 x 11. Thanks, RS
Maximum 2D Filter in C++
Started by ●October 20, 2006
Reply by ●October 20, 20062006-10-20
RS wrote:> I am looking for an efficient implementation of the 2D maximum filter in > C++. > [...] > My image is 512 x 512 and the filter is 11 x 11.How are you currently doing it? Are you actually trying to find the maximum over an 11x11 area for each pixel? This would require 121 comparisons for each pixel. Note that a comparison is actually an expensive operation compared to an addition: A sequence of additions can easily be pipelined by the CPU whereas comparisons require a change of the control flow which is not as easily pipelined. Here are some ideas: The maximum operation is a separable operation. That is, if you wish to find the maximum over a set of pixels this is the same as splitting the set into disjoint subsets, then finding the maximum over each subset and then finding the maximum over the maxima. In other words: What you can do is compute an intermediate image as follows: Go over the image row-wise and find the maxima over 11 consecutive pixels in a row. Then go over the intermediate image column-wise and find the maxima over 11 consecutive pixels in a column. This results in only 22 comparisons per pixel. Note that you do not need to do a full maximum search at each pixel. If you remember the position of the last maximum found you only need to update the maximum if either the current pixel is above the maximum or if the position is more than 11 pixels away. Hope this helps, Marcus
Speedy wrote:> RS wrote: >> I am looking for an efficient implementation of the 2D maximum filter in >> C++. >> [...] >> My image is 512 x 512 and the filter is 11 x 11. > > How are you currently doing it? Are you actually trying to find the > maximum over an 11x11 area for each pixel? This would require 121 > comparisons for each pixel. Note that a comparison is actually an > expensive operation compared to an addition: A sequence of additions > can easily be pipelined by the CPU whereas comparisons require a change > of the control flow which is not as easily pipelined. >Thanks for your response. I am actually using the max (of a matrix) function of the Blitz library. I am pretty sure they are efficient in that. But I'll try to do that manually. Thanks again, RS
Reply by ●October 21, 20062006-10-21
"RS" <rsina_no.ssppaamm@comcast.net> wrote in message news:1_CdnY3VXeAs0qXYnZ2dnUVZ_qGdnZ2d@comcast.com...> I am looking for an efficient implementation of the 2D maximum filter in > C++. I tried to write one using the Blitz library, but my code's speed is > far slower than the matlab code.If you are in the Windows environment ... How are you getting the pixel to start with? You have to load the image (I assume a bitmap file format) and then get at each pixel. You could use the GetPixel API call, but this is NOTORIOUSLY s-l-o-w, whihc perhaps you did not realize. The fast way (any environment) is to get a pointer to the start of the image data (after the image header), and increment the pointer along each line. -- regards, Stewart DIBBS ======================================== Image Acquisition and Advanced Image Processing PiXCL 6.1 is very affordable and available now ! www.pixcl.com Gatineau, Quebec, CANADA ========================================
