Greetings, I am seeking general ideas/opinions/guidance on software development for TI DSP devices, in particular, the newer fixed point devices such as 6455. I do both algorithm development and implementation work. Most of my implementation work has been on simpler devices such as 5600, 96002, Sharc and 5510. I have been developing code for 6455 for about a month or so. Most of what I have done so far on 6455 has been porting of key processing modules that I had previously developed for another device. Thanks to a better compiler, use of intrinsics and linear assembly, this work has not been as painful as I had anticipated. Engaging all functional units (.L, .M, .S, .D x 2) in critical loops is not a trivial task but it is not impossible. I am contemplating using DSP BIOS to setup the operating framework. I am not too worried about the additional processing burden imposed by the use of BIOS objects. It looks like the groups within TI (spectron and go dsp ???) responsible for BIOS and CSS/CSL have stopped communicating with each other. Previously, there was very little overlap between CSL and BIOS. Use of BIOS didn't prevent the user from the using CSL and vice versa. However, may changes have taken place in the recent version of CSL (3.00.10.02), and BIOS (5.31). CSL seems to have become a bit more primitive and BIOS doesn't seem to require CSL at all. So, my main question is can these two coexist in the new world? I have not been able to get satisfactory answer from my friends (AEs and FAEs) at TI. You get a different spin from people belonging to BIOS and CSL groups. Any thoughts/ideas/guidance on this will be greatly appreciated. Cheers, Eknath
TI BIOS/CSL for 64xx/64x+ devices
Started by ●November 11, 2006
Reply by ●November 11, 20062006-11-11
UglanceIcatch wrote:> Greetings, > > I am seeking general ideas/opinions/guidance on software development > for TI DSP devices, in particular, the newer fixed point devices such > as 6455. > > I do both algorithm development and implementation work. Most of my > implementation work has been on simpler devices such as 5600, 96002, > Sharc and 5510. I have been developing code for 6455 for about a month > or so. Most of what I have done so far on 6455 has been porting of key > processing modules that I had previously developed for another device. > Thanks to a better compiler, use of intrinsics and linear assembly, > this work has not been as painful as I had anticipated. Engaging all > functional units (.L, .M, .S, .D x 2) in critical loops is not a > trivial task but it is not impossible. > > I am contemplating using DSP BIOS to setup the operating framework. I > am not too worried about the additional processing burden imposed by > the use of BIOS objects. > > It looks like the groups within TI (spectron and go dsp ???) > responsible for BIOS and CSS/CSL have stopped communicating with each > other. Previously, there was very little overlap between CSL and BIOS. > Use of BIOS didn't prevent the user from the using CSL and vice versa. > However, may changes have taken place in the recent version of CSL > (3.00.10.02), and BIOS (5.31). CSL seems to have become a bit more > primitive and BIOS doesn't seem to require CSL at all. So, my main > question is can these two coexist in the new world? > > I have not been able to get satisfactory answer from my friends (AEs > and FAEs) at TI. You get a different spin from people belonging to BIOS > and CSL groups. > > Any thoughts/ideas/guidance on this will be greatly appreciated. > > Cheers, > > Eknath >CSL 3.x has separated the interrupt code (i.e. what they are now calling the INTC module) from the rest of the CSL. If you are using BIOS then you should not using the INTC module as BIOS has its own APIs for dealing with interrupts (i.e. the HWI module). I don't see any reason you cannot use both BIOS and CSL. In fact, they are complimentary. BIOS serves as your RTOS/kernel and CSL is used for peripheral configuration/control. Cheers, Brad
Reply by ●November 12, 20062006-11-12
Brad, Thanks for the clarification. I have another related question. It has to do with what TI calls as either DSP algorithm standard or XDAIS. Is this applicable only to third party software developers? How are IDMA2, ACPY etc. related to CSL? Is this a layer on top of CSL? Thanks, Eknath. Brad Griffis wrote:> UglanceIcatch wrote: > > Greetings, > > > > I am seeking general ideas/opinions/guidance on software development > > for TI DSP devices, in particular, the newer fixed point devices such > > as 6455. > > > > I do both algorithm development and implementation work. Most of my > > implementation work has been on simpler devices such as 5600, 96002, > > Sharc and 5510. I have been developing code for 6455 for about a month > > or so. Most of what I have done so far on 6455 has been porting of key > > processing modules that I had previously developed for another device. > > Thanks to a better compiler, use of intrinsics and linear assembly, > > this work has not been as painful as I had anticipated. Engaging all > > functional units (.L, .M, .S, .D x 2) in critical loops is not a > > trivial task but it is not impossible. > > > > I am contemplating using DSP BIOS to setup the operating framework. I > > am not too worried about the additional processing burden imposed by > > the use of BIOS objects. > > > > It looks like the groups within TI (spectron and go dsp ???) > > responsible for BIOS and CSS/CSL have stopped communicating with each > > other. Previously, there was very little overlap between CSL and BIOS. > > Use of BIOS didn't prevent the user from the using CSL and vice versa. > > However, may changes have taken place in the recent version of CSL > > (3.00.10.02), and BIOS (5.31). CSL seems to have become a bit more > > primitive and BIOS doesn't seem to require CSL at all. So, my main > > question is can these two coexist in the new world? > > > > I have not been able to get satisfactory answer from my friends (AEs > > and FAEs) at TI. You get a different spin from people belonging to BIOS > > and CSL groups. > > > > Any thoughts/ideas/guidance on this will be greatly appreciated. > > > > Cheers, > > > > Eknath > > > > CSL 3.x has separated the interrupt code (i.e. what they are now calling > the INTC module) from the rest of the CSL. If you are using BIOS then > you should not using the INTC module as BIOS has its own APIs for > dealing with interrupts (i.e. the HWI module). > > I don't see any reason you cannot use both BIOS and CSL. In fact, they > are complimentary. BIOS serves as your RTOS/kernel and CSL is used for > peripheral configuration/control. > > Cheers, > Brad
Reply by ●November 15, 20062006-11-15
Eknath, I'm afraid I can't answer your question though I will tell you what I know. TI created xDAIS several years ago as a standard to have a more structured interface to algorithms. Basically it made good coding practices into rules. For example, you'd have to tell how much persistent memory your algorithm needs, how much scratch memory, etc. Recently TI came up with a specific implementation of xDAIS called xDM (xDAIS Digital Media). This follows all the xDAIS rules but with specific APIs and structures intended specifically for voice, audio, video, and imaging algorithms. This is being used on TI's "DaVinci" platform. That would include the DM6446/DM6443 and I believe that also includes the parts they announced yesterday, the DM6431, DM6435, etc. Now there are also DMAN3, IDMA3, and ACPY. These are part of what TI calls its "Framework Components". I believe these are intended for use by xDM/xDAIS algorithms to use for controlling DMA channels. Note that CSL 3.x does not take care of resource allocation so that needs to be done by the application. I believe these framework components are in place for that very reason. I'm not sure if they were built on top of CSL or not though. You may want to either create a separate post here or you may have better luck subscribing to one of the DaVinci forums and asking there. Check out http://linux.davincidsp.com and you can subscribe to the mailing list. Brad UglanceIcatch wrote:> Brad, > > Thanks for the clarification. I have another related question. It has > to do with what TI calls as either DSP algorithm standard or XDAIS. Is > this applicable only to third party software developers? How are IDMA2, > ACPY etc. related to CSL? Is this a layer on top of CSL? > > Thanks, > > Eknath. > > > Brad Griffis wrote: >> UglanceIcatch wrote: >>> Greetings, >>> >>> I am seeking general ideas/opinions/guidance on software development >>> for TI DSP devices, in particular, the newer fixed point devices such >>> as 6455. >>> >>> I do both algorithm development and implementation work. Most of my >>> implementation work has been on simpler devices such as 5600, 96002, >>> Sharc and 5510. I have been developing code for 6455 for about a month >>> or so. Most of what I have done so far on 6455 has been porting of key >>> processing modules that I had previously developed for another device. >>> Thanks to a better compiler, use of intrinsics and linear assembly, >>> this work has not been as painful as I had anticipated. Engaging all >>> functional units (.L, .M, .S, .D x 2) in critical loops is not a >>> trivial task but it is not impossible. >>> >>> I am contemplating using DSP BIOS to setup the operating framework. I >>> am not too worried about the additional processing burden imposed by >>> the use of BIOS objects. >>> >>> It looks like the groups within TI (spectron and go dsp ???) >>> responsible for BIOS and CSS/CSL have stopped communicating with each >>> other. Previously, there was very little overlap between CSL and BIOS. >>> Use of BIOS didn't prevent the user from the using CSL and vice versa. >>> However, may changes have taken place in the recent version of CSL >>> (3.00.10.02), and BIOS (5.31). CSL seems to have become a bit more >>> primitive and BIOS doesn't seem to require CSL at all. So, my main >>> question is can these two coexist in the new world? >>> >>> I have not been able to get satisfactory answer from my friends (AEs >>> and FAEs) at TI. You get a different spin from people belonging to BIOS >>> and CSL groups. >>> >>> Any thoughts/ideas/guidance on this will be greatly appreciated. >>> >>> Cheers, >>> >>> Eknath >>> >> CSL 3.x has separated the interrupt code (i.e. what they are now calling >> the INTC module) from the rest of the CSL. If you are using BIOS then >> you should not using the INTC module as BIOS has its own APIs for >> dealing with interrupts (i.e. the HWI module). >> >> I don't see any reason you cannot use both BIOS and CSL. In fact, they >> are complimentary. BIOS serves as your RTOS/kernel and CSL is used for >> peripheral configuration/control. >> >> Cheers, >> Brad >
UglanceIcatch wrote:> Thanks for the clarification. I have another related question. It has > to do with what TI calls as either DSP algorithm standard or XDAIS. Is > this applicable only to third party software developers? How are IDMA2, > ACPY etc. related to CSL? Is this a layer on top of CSL?XDAIS essentially comes in two parts. The first is simply a list of coding standards and rules which, if followed, simplify combining multiple algorithms into a complete system. The second is a set of APIs to enable the programmer to comply with the rules. For example, one rule is that an algorithm must not allocate any memory. Instead, the algorithm implements an interface that the application uses to query its memory requirements. The app then allocates the memory and grants use of it to the algorithm. TI provides an API within the Reference Frameworks to manage this process (ALGRF/SSCR) which provides some nice features like allowing different algorithms to share scratch memory. Another of the rules is that algorithms must not touch chip resources, including, for example, DMA. However, TI realised that many algorithms need to make DMA transfers, so they defined the IDMA (and subsequently IDMA2) interface to allow algorithms to request and use DMA channels. ACPY/DMAN are TIs reference implementation of this interface. Cheers mark-r -- Currently sigless.
Reply by ●November 17, 20062006-11-17
Brad, Thanks for the explanation. I want to understand the relationship between the framework components and CSL. I will start a separate thread on that topic. Regards, Eknath> ... I believe these framework components are in > place for that very reason. I'm not sure if they were built on top of > CSL or not though.
Thank you. Mark Robinson wrote:> > XDAIS essentially comes in two parts. The first is simply a list of > coding standards and rules which, if followed, simplify combining > multiple algorithms into a complete system. The second is a set of > APIs to enable the programmer to comply with the rules. > > For example, one rule is that an algorithm must not allocate any memory. > Instead, the algorithm implements an interface that the application > uses to query its memory requirements. The app then allocates the memory > and grants use of it to the algorithm. TI provides an API within the > Reference Frameworks to manage this process (ALGRF/SSCR) which provides > some nice features like allowing different algorithms to share scratch > memory. > > Another of the rules is that algorithms must not touch chip resources, > including, for example, DMA. However, TI realised that many algorithms > need to make DMA transfers, so they defined the IDMA (and subsequently > IDMA2) interface to allow algorithms to request and use DMA channels. > ACPY/DMAN are TIs reference implementation of this interface. > > Cheers > > mark-r > > -- > Currently sigless.
