C6000 EMIF
Started by (news) June 9, 2004
Hi everybody,
Do you know if EMIF (external memory interface) port on C6000 can be use as
GPIO ?
Thanks
"(news)" <news@nospam.com> wrote in message
news:ca73vc$lqj$1@news-reader5.wanadoo.fr...
> Hi everybody, > Do you know if EMIF (external memory interface) port on C6000 can be use
as
> GPIO ? > Thanks
Which C6x device had you in mind? The 6713 still? If I remember correctly, both the 6713 and 641x devices all have GPIO pins. If you just want to use the EMIF as GPIO then you may need some sort of external latch for the outputs.
I already use GPIO.
As you saw in another topic, my problem is to connect an UART on EMIF.
I ask this question with more general subject on EMIF because I didn't have
answer.
Many thanks for your answers.
Max
"Graeme" <graeme_dontreplyhere@hotmail.com> a &#2013265929;crit dans le message de
news:2iquclFpvfueU1@uni-berlin.de...
> "(news)" <news@nospam.com> wrote in message > news:ca73vc$lqj$1@news-reader5.wanadoo.fr... > > Hi everybody, > > Do you know if EMIF (external memory interface) port on C6000 can be use > as > > GPIO ? > > Thanks > > Which C6x device had you in mind? The 6713 still? If I remember correctly, > both the 6713 and 641x devices all have GPIO pins. If you just want to use > the EMIF as GPIO then you may need some sort of external latch for the > outputs. > >
