Hi guys, I use splines quite a bit in my audio applications, I use them for envelopes, blending functions and even to create waveforms. I'm talking about cubic interpolation between endpoints. Is there another word I can use, maybe something more technical ? I really don't like the word spline. Thanks.
OT: Another word for Spline ?
Started by ●November 15, 2006
Reply by ●November 15, 20062006-11-15
Noekk wrote:> Hi guys, > > I use splines quite a bit in my audio applications, I use them for > envelopes, blending functions and even to create waveforms. > > I'm talking about cubic interpolation between endpoints. > > Is there another word I can use, maybe something more technical ? I > really don't like the word spline.Splines are a thin pieces of wood. Joiners use them for strengthening miters, and draftsmen use them for fairing curves through arbitrary points, driving brads or drafting pins into the board to hold the splines in place. Now, equivalents made of steel springs have grooves in one edge that allow them to be pinned down by iron weights (called ducks) with a wire from weight to groove that looks a bit like a neck. Laying down full-size ships curves requires a large floor, and is usually done in the loft of the construction shed. The process, both for hulls and for sails, is called lofting. While desk-top drafting is done with splines, lofting is done with heavier stuff called a limber batten. (A batten is thicker than a spline.) http://www.duckworksmagazine.com/06/howto/splineweights/index.htm Just as the work done in a loft is called lofting, the fairing of curves through a series of points is called splining, even when it's done with software. "Spline" is a good word. Use it. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> Is there another word I can use, maybe something more technical ? I > really don't like the word spline.There's nothing wrong with the term "spline" if you're doing cubic (or any other polynomial order, for that matter) piecewise fits between points; that's what the method is called. http://en.wikipedia.org/wiki/Spline_interpolation No sense in using another term when this one describes exactly what you're doing. Jason
Reply by ●November 16, 20062006-11-16
Hi, Yeah, you guys are right, I'll stick with Spline. What are the points usually called, Knots ? Thanks. Noekk wrote:> Hi guys, > > I use splines quite a bit in my audio applications, I use them for > envelopes, blending functions and even to create waveforms. > > I'm talking about cubic interpolation between endpoints. > > Is there another word I can use, maybe something more technical ? I > really don't like the word spline. > > Thanks.
"Noekk" <noekk@noekk.com> wrote in message news:md37h.512$LN6.115@newsfe11.lga...> Hi, > > Yeah, you guys are right, I'll stick with Spline. > > What are the points usually called, Knots ? > > Thanks. >Are you confusing "spline" with "splice"?
Noekk wrote:> Hi, > > Yeah, you guys are right, I'll stick with Spline. > > What are the points usually called, Knots ?Nodes (http://stsdas.stsci.edu/cgi-bin/gethelp.cgi?vigfit), datum points (www.iop.org/EJ/article/0031-9155/18/4/306/pbv18i4p550.pdf), offsets (from the naval architect's table), other; varies with the application. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Noekk wrote: >> Hi, >> >> Yeah, you guys are right, I'll stick with Spline. >> >> What are the points usually called, Knots ? > > Nodes (http://stsdas.stsci.edu/cgi-bin/gethelp.cgi?vigfit), datum points > (www.iop.org/EJ/article/0031-9155/18/4/306/pbv18i4p550.pdf), offsets > (from the naval architect's table), other; varies with the application. > > JerryFrom http://www.newavesys.com/new00002.htm: Entering a Table of Offsets (ProSurf Only) If you have a full table of offsets (more than 25 offsets or so) for an existing boat/ship that you wish to match up exactly using the ProSurf package, you should follow the steps below. If you have less that 25 offsets, it may be faster to use the File-Create Boat command and the Edit-Set Point command method described in the section on "Setting Offsets in ProBasic or ProSurf". A. Use the Offsets module to enter offsets for each station. The offset half-breadth and height values must first be converted to decimal form if they are in some other form, such as feet-inches-eights. See the Offsets module manual for more details. B. Verify the station shapes using the Body Plan display or the Hull Draw module. You want to make sure that the station shapes looks good before you fit surfaces to them. C. Correct any errors using the Offsets or Digitize modules. The Digitize module can be used with a mouse for doing interactive editing of station shapes. D. Convert this "Station Definition" to a "Surface Definition" using the Convert Hull module. This program fits or "skins" the stations with one or more B-spline surfaces. A "Station Definition" of a hull describes the hull shape using only a number of stations located along the length of the hull. Station definition programs fit B-spline curves through the offset points of each station. The "station definition" is good for input and calculation, but not accurate enough for fairing and construction templates. A B-spline (NURB) surface definition is required to perform full surface fairing and lofting. See the Convert Hull manual for a detailed example of this surface fitting process. E. Read the new surfaces into ProSurf using the File-Get Old Surf command. Conversion from an arbitrary table of offsets to a surface definition is a complex process, since the hull being defined might have many chines separating many surfaces. Before you begin this conversion process, you need to read up on the definition of the "Station Definition" and "Surface Definition" of a hull and read about the conversion example in the Convert Hull manual. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~` For those interested, stations correspond roughly to frames that support the planking in a wooden boat. Offsets are three-dimensional data measured up from an arbitrary plane (often through the bottom of the keel) and outward from the fore-and-aft plane that bisects the boat. There's more than one world out there! Jerry P.S. The head shipwright at the Minneford boat yard at City Island once offered me an apprenticeship. Sometimes I'm sorry I turned him down. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
