I originally posted this to the Scilab group assuming i just had a syntax error. While waiting for a response, I started wondering if I was also headed for some DSP specific pitfalls. Comments welcome. *********** I know I'm making a basic (no pun intended) error. But i just can not find the proper syntax. My code is: sheets = readxls('E:\parasitic.xls') s1=sheets(1); //get the first sheet dwave=s1(:,2); y=size(dwave,'r'); k=max(abs(dwave([2:y]))); dwave=dwave([2:y])/k; //first line is col titles //normalize array for i=1:19 j=500*(i-1); farray(i,:)=fft(dwave(j+1:j+500)); end Scilab-4.0 chokes on farray(i,:) I'm sure I've seen that syntax in the help files. What obvious thing am I missing? My eventual goal is a 3D surface plot of farray. farray will eventually be larger than 19x500. The data I'm using is a simple/simplistic test case. corrections, pointers, general guidance appreciated. Thank you.
HELP - submatrix incorrectly defined ;(
Started by ●November 16, 2006
Reply by ●November 16, 20062006-11-16
Richard Owlett wrote:> I originally posted this to the Scilab group assuming i just had a > syntax error. While waiting for a response, I started wondering if I was > also headed for some DSP specific pitfalls. > > Comments welcome. > > > *********** > > I know I'm making a basic (no pun intended) error. > But i just can not find the proper syntax. > My code is: > > > sheets = readxls('E:\parasitic.xls') > s1=sheets(1); //get the first sheet > dwave=s1(:,2); > y=size(dwave,'r'); > k=max(abs(dwave([2:y]))); > dwave=dwave([2:y])/k; //first line is col titles > //normalize array > for i=1:19 > j=500*(i-1); > farray(i,:)=fft(dwave(j+1:j+500)); > end > > > Scilab-4.0 chokes on > farray(i,:) > > I'm sure I've seen that syntax in the help files. > What obvious thing am I missing? > > My eventual goal is a 3D surface plot of farray. > farray will eventually be larger than 19x500. > The data I'm using is a simple/simplistic test case. > > corrections, pointers, general guidance appreciated. > Thank you.ARGGHH ;< farray(i,:)=fft(dwave(j+1:j+500)); should be farray(i,:)=fft(dwave(j+1:j+500))';
