Hi, I'm not sure whether to be posting a new topic or piggybacking on the backs of many others, I've got so many questions If people can point me at some literature that can point me in the right direction or have some comments about my proposed plan I'd be very grateful. For my final year project I want to take a crude look at signal source acquisition. My plan was to take some recordings using two cardiod microphones and be able to 'listen' in certain directions, such as towards one of two people speaking. I understand I can apply weighted delays to the incoming sounds to attenuate the surrounding signals from the one I'm trying to listen to. In my case is it as simple as having two circular buffers holding the incoming audio data and just applying a delay to one side or the other, then once a certain level of confidence has been found between the similarities of the two signals I can assume the beam is being steered in the direction I require? Once a certain level of confidence has been achieved is it as simple as summing the two signals together to create a single mono channel with the required audio in it? Compared to many of the current questions being asked this is very trivial. Many thanks in advance, apologies if this seems like some daft questions, Andrew
Newbie Understanding Beamforming and Steering
Started by ●November 30, 2006
Reply by ●November 30, 20062006-11-30
flamingo11 skrev:> Hi, I'm not sure whether to be posting a new topic or piggybacking on the > backs of many others, I've got so many questions If people can point me > at some literature that can point me in the right direction or have some > comments about my proposed plan I'd be very grateful.> For my final year project I want to take a crude look at signal source > acquisition.Hmm... exactly what do you mean by "source acquisition"? Most people are familiar with "signal acquisition"...> My plan was to take some recordings using two cardiod > microphones and be able to 'listen' in certain directions, such as towards > one of two people speaking. I understand I can apply weighted delays to > the incoming sounds to attenuate the surrounding signals from the one I'm > trying to listen to.In principle, this is correct, yes.> In my case is it as simple as having two circular > buffers holding the incoming audio data and just applying a delay to one > side or the other, then once a certain level of confidence has been found > between the similarities of the two signals I can assume the beam is being > steered in the direction I require?No. You could have locked on to that noisy AC unit humming in the corner of the room.> Once a certain level of confidence has > been achieved is it as simple as summing the two signals together to create > a single mono channel with the required audio in it?Well... yes and no. The operations required to achieve beamforming are as simple as summing weighted signals. Consider two sensors in air 15 cm apart, which is half a wavelength for a 1000 Hz tone. If we sum the signals of the mics with the same polarity, we see that the system enhances a signal that impignes from broadside (the direction perpendicular to the axis between sensors) and reject signals impigning inline with the axis bewteen sensors (can you see why?). Similarly, if the signals are summed with reverse polarity, the inline signal is permitted and the broadside signal is rejected. Make a sketch on paper to see why. Unfortunately, there are many complicating factors. First, the beam width of the opening lobe is proportional to the size of the array. Second, one has to make similar considerations for lots of narrow frequency bands in order to deal with broadband signals like speech. Third, multiple reflections mess things seriously up if such a system is used indoor.> Compared to many of the current questions being asked this is very > trivial.The question may be trivial, but the answer is not...> Many thanks in advance,Y're welcome> apologies if this seems like some daft questions,By no means. Rune
Reply by ●December 3, 20062006-12-03
> >flamingo11 skrev: >> Hi, I'm not sure whether to be posting a new topic or piggybacking onthe>> backs of many others, I've got so many questions If people can pointme>> at some literature that can point me in the right direction or havesome>> comments about my proposed plan I'd be very grateful. > >> For my final year project I want to take a crude look at signal source >> acquisition. > >Hmm... exactly what do you mean by "source acquisition"? >Most people are familiar with "signal acquisition"... > >> My plan was to take some recordings using two cardiod >> microphones and be able to 'listen' in certain directions, such astowards>> one of two people speaking. I understand I can apply weighted delaysto>> the incoming sounds to attenuate the surrounding signals from the oneI'm>> trying to listen to. > >In principle, this is correct, yes. > >> In my case is it as simple as having two circular >> buffers holding the incoming audio data and just applying a delay toone>> side or the other, then once a certain level of confidence has beenfound>> between the similarities of the two signals I can assume the beam isbeing>> steered in the direction I require? > >No. You could have locked on to that noisy AC unit humming >in the corner of the room. > >> Once a certain level of confidence has >> been achieved is it as simple as summing the two signals together tocreate>> a single mono channel with the required audio in it? > >Well... yes and no. The operations required to achieve >beamforming are as simple as summing weighted signals. >Consider two sensors in air 15 cm apart, which is half a >wavelength for a 1000 Hz tone. > >If we sum the signals of the mics with the same polarity, >we see that the system enhances a signal that impignes >from broadside (the direction perpendicular to the axis >between sensors) and reject signals impigning inline with >the axis bewteen sensors (can you see why?). > >Similarly, if the signals are summed with reverse polarity, >the inline signal is permitted and the broadside signal >is rejected. Make a sketch on paper to see why. > >Unfortunately, there are many complicating factors. >First, the beam width of the opening lobe is proportional >to the size of the array. Second, one has to make similar >considerations for lots of narrow frequency bands in order >to deal with broadband signals like speech. Third, multiple >reflections mess things seriously up if such a system >is used indoor. > >> Compared to many of the current questions being asked this is very >> trivial. > >The question may be trivial, but the answer is not... > >> Many thanks in advance, > >Y're welcome > >> apologies if this seems like some daft questions, > >By no means. > >Rune > >Thanks for the reply Rune, looks like I've got a lot more research to get involved with before doing much more with the project. Do you know of any books or material that would help me with my ideas? Andrew
flamingo11 skrev:> Thanks for the reply Rune, looks like I've got a lot more research to get > involved with before doing much more with the project. Do you know of any > books or material that would help me with my ideas? > > AndrewFor beamforming alone, try Haykin's "Adaptive Filter Theory" (?). For the application, you might want to check out various publications in room acoustics. Room acoustics is a bit outside my main field of interest so I don't know the details, but fairly recently there was published a book on microphone arrays. You might want to post on alt.sci.physics.acoustics. Rune
