In the following URL; http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 the left side is the original image of Janus taken by Cassini probe and the right side is the processed image deconvoluted by Focus Corrector. For detail of Focus Corrector, visit; http://139.134.5.123/tiddler2/c22508/focus.htm
Unmasked Janus
Started by ●December 9, 2006
Reply by ●December 9, 20062006-12-09
tontoko skrev:> In the following URL; > > http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 > > the left side is the original image of Janus taken by Cassini probe and > the right > side is the processed image deconvoluted by Focus Corrector. > > For detail of Focus Corrector, visit; > > http://139.134.5.123/tiddler2/c22508/focus.htmSeems to me that this improvement is due to floating point arithmetics? The weights 1 and 9 in the integer mask operator are substituted for 1/9 and 1, which reduces overflow and quantization problems? Rune
Rune Allnor wrote:> tontoko skrev: > >>In the following URL; >> >>http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 >> >>the left side is the original image of Janus taken by Cassini probe and >>the right >>side is the processed image deconvoluted by Focus Corrector. >> >>For detail of Focus Corrector, visit; >> >>http://139.134.5.123/tiddler2/c22508/focus.htm > > > Seems to me that this improvement is due to floating point > arithmetics? The weights 1 and 9 in the integer mask operator > are substituted for 1/9 and 1, which reduces overflow and > quantization problems? >This isn't really focus correction anyway. Its just a crude sharpener. Real focus correction means estimating the blurring function - e.g. using maximum entropy analysis - and applying the inverse of that to the image. The processed Hubble picture of Jupiter's spot, for example, gives a simplistic appearance of gerater sharpness. However, it has really just peaked everything, creating bogus structure out of nothing. Steve
Steve Underwood wrote:> Rune Allnor wrote: >> tontoko skrev: >> >>> In the following URL; >>> >>> http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 >>> >>> >>> the left side is the original image of Janus taken by Cassini probe and >>> the right >>> side is the processed image deconvoluted by Focus Corrector. >>> >>> For detail of Focus Corrector, visit; >>> >>> http://139.134.5.123/tiddler2/c22508/focus.htm >> >> >> Seems to me that this improvement is due to floating point >> arithmetics? The weights 1 and 9 in the integer mask operator >> are substituted for 1/9 and 1, which reduces overflow and >> quantization problems? > This isn't really focus correction anyway. Its just a crude sharpener. > Real focus correction means estimating the blurring function - e.g. > using maximum entropy analysis - and applying the inverse of that to the > image. The processed Hubble picture of Jupiter's spot, for example, > gives a simplistic appearance of gerater sharpness. However, it has > really just peaked everything, creating bogus structure out of nothing.Moreover, most blurring functions are circular, so the functions to properly deconvolve the blur must be circular too. The closest I've seen to making something from nothing is deconvolving a diffraction-limited Airy disk, including part of the first and second rings. Of course, there's nothing to be done for the nulls between the rings, but then there's nothing that needs to be done there. Tontoko is either ignorant or a charlatan. Too bad. (If the latter, posting here was an avoidable mistake.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Sat, 09 Dec 2006 11:03:51 -0500, Jerry Avins <jya@ieee.org> wrote:>Steve Underwood wrote: >> Rune Allnor wrote: >>> tontoko skrev: >>> >>>> In the following URL; >>>> >>>> http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 >>>> >>>> >>>> the left side is the original image of Janus taken by Cassini probe and >>>> the right >>>> side is the processed image deconvoluted by Focus Corrector. >>>> >>>> For detail of Focus Corrector, visit; >>>> >>>> http://139.134.5.123/tiddler2/c22508/focus.htm >>> >>> >>> Seems to me that this improvement is due to floating point >>> arithmetics? The weights 1 and 9 in the integer mask operator >>> are substituted for 1/9 and 1, which reduces overflow and >>> quantization problems? >> This isn't really focus correction anyway. Its just a crude sharpener. >> Real focus correction means estimating the blurring function - e.g. >> using maximum entropy analysis - and applying the inverse of that to the >> image. The processed Hubble picture of Jupiter's spot, for example, >> gives a simplistic appearance of gerater sharpness. However, it has >> really just peaked everything, creating bogus structure out of nothing. > >Moreover, most blurring functions are circular, so the functions to >properly deconvolve the blur must be circular too. The closest I've seen >to making something from nothing is deconvolving a diffraction-limited >Airy disk, including part of the first and second rings. Of course, >there's nothing to be done for the nulls between the rings, but then >there's nothing that needs to be done there. > >Tontoko is either ignorant or a charlatan. Too bad. (If the latter, >posting here was an avoidable mistake.) > >JerryWell, he started an interesting discussion, if nothing else! That's worthwhile... ;) Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●December 10, 20062006-12-10
Intuitively there seems to be no difference between usual convolution method and my method except the effect caused from the treatment of floating point, however actual calculation shows definite difference between them. Rune Allnor wrote:> tontoko skrev: > > In the following URL; > > > > http://www.unmannedspaceflight.com/index.php?act=Attach&type=post&id=1980 > > > > the left side is the original image of Janus taken by Cassini probe and > > the right > > side is the processed image deconvoluted by Focus Corrector. > > > > For detail of Focus Corrector, visit; > > > > http://139.134.5.123/tiddler2/c22508/focus.htm > > Seems to me that this improvement is due to floating point > arithmetics? The weights 1 and 9 in the integer mask operator > are substituted for 1/9 and 1, which reduces overflow and > quantization problems? > > Rune
tontoko skrev:> Intuitively there seems to be no difference between usual convolution > method and my method except the effect caused from the treatment of > floating point, however actual calculation shows definite difference > between them.So I am right in my interpretation that this method "only" relies on floating point implementations of operators that usually are implemented with fixed-point arithmetics? These originals you post, are these the "true" originals or are they compressed or smaller versions than what you process? Would it be possible for you to post the full-size, uncompressed image you start from somewhere? Rune
Reply by ●December 11, 20062006-12-11
Rune Allnor wrote:> tontoko skrev: > > Intuitively there seems to be no difference between usual convolution > > method and my method except the effect caused from the treatment of > > floating point, however actual calculation shows definite difference > > between them. > > So I am right in my interpretation that this method "only" relies > on floating point implementations of operators that usually are > implemented with fixed-point arithmetics? > > These originals you post, are these the "true" originals or are they > compressed or smaller versions than what you process? > Would it be possible for you to post the full-size, uncompressed > image you start from somewhere? > > Rune
Reply by ●December 12, 20062006-12-12
Sorry, for my previous post seems not to have been uploaded correctly. The original image was a jpg file, and I converted it to bmp image for Focus Corrector without reducing size (but just used the part of it.) Regarding the deconvolution of the whole image of Tempel 1, please refer to the following thread. http://groups.google.com/group/comp.dsp/browse_thread/thread/cf864b4a3a8454ed/ad2b99168331382c?lnk=st&q=tontoko&rnum=1&hl=en#ad2b99168331382c Rune Allnor wrote:> tontoko skrev: > > Intuitively there seems to be no difference between usual convolution > > method and my method except the effect caused from the treatment of > > floating point, however actual calculation shows definite difference > > between them. > > So I am right in my interpretation that this method "only" relies > on floating point implementations of operators that usually are > implemented with fixed-point arithmetics? > > These originals you post, are these the "true" originals or are they > compressed or smaller versions than what you process? > Would it be possible for you to post the full-size, uncompressed > image you start from somewhere? > > Rune
