Hello! I want to use FFTW to calculate derivatives. But it doesn't work. I think I make a big mistake, but I couldn't find it. I calculate the fourier transform, multiply the coefficents with -i*k, and transform back. My code is: void TestFFTW() { fstream o1,o2; o1.open("out1.txt", ios::out); o2.open("out2.txt", ios::out); int N=1000; std::complex<double>* c=new std::complex<double> [N]; fftw_plan p = fftw_plan_dft_1d(N,reinterpret_cast<fftw_complex*>(c), reinterpret_cast<fftw_complex*>(c), FFTW_FORWARD, FFTW_ESTIMATE); // Generate input for (int i=0;i<N;i++){ c[i]=sin(2.*M_PI/(double)N*(double)i*2.)+cos(2.*M_PI/(double)N*(double)i); o1 << (double)i/(double)N << " " << c[i].real() << endl; } fftw_execute(p); complex<double> I(0,1.); for (int i=0;i<N;i++){ // Calculate derivative c[i]*=-I*(double)i/(double)N; } fftw_execute(p); for (int i=0;i<N;i++) // renormalize c[i]/=(double)N; // output for (int i=0;i<N;i++) o2 << (double)i/(double)N << " " << c[i].real() << " " << c[i].imag() << std::endl; fftw_destroy_plan(p); delete [] c; o1.close(); o2.close(); } Thanks for any help! Hanno
Using FFTW to calculate derivatives
Started by ●December 11, 2006
Reply by ●December 11, 20062006-12-11
Hanno Rein skrev:> Hello! > > I want to use FFTW to calculate derivatives. But it doesn't work. I > think I make a big mistake, but I couldn't find it. I calculate the > fourier transform, multiply the coefficents with -i*k, and transform > back. My code is: >> complex<double> I(0,1.); > for (int i=0;i<N;i++){ > // Calculate derivative > c[i]*=-I*(double)i/(double)N; > }You probably need to negative frequencies into account. This loop seems correct for 0 <= i < N/2, but from N/2 onwards you may want to multiply by something like -(N/2-i). Remember, the spectrum needs to preserve symmetry. Rune
Rune Allnor schrieb:> You probably need to negative frequencies into account. This loop > seems correct for 0 <= i < N/2, but from N/2 onwards you may want > to multiply by something like -(N/2-i). Remember, the spectrum > needs to preserve symmetry.I think you are right. However, It is still not working. But I tried the real to complex transform where you only get N/2+1 complex numbers back. It works fine with that if I multiply every coefficent by -I*i. Hanno
Hanno Rein skrev:> Rune Allnor schrieb: > > > You probably need to negative frequencies into account. This loop > > seems correct for 0 <= i < N/2, but from N/2 onwards you may want > > to multiply by something like -(N/2-i). Remember, the spectrum > > needs to preserve symmetry. > > I think you are right. However, It is still not working. But I tried > the real to complex transform where you only get N/2+1 complex numbers > back. It works fine with that if I multiply every coefficent by -I*i.I never get the details about the symmetries right the first time around; the correct factor might be something like -((N-1)/2+i) or something like that. My point was merely that you can't scale naively with spectrum index. Rune
Reply by ●December 12, 20062006-12-12
Rune Allnor wrote:> You probably need to negative frequencies into account. This loop > seems correct for 0 <= i < N/2, but from N/2 onwards you may want > to multiply by something like -(N/2-i). Remember, the spectrum > needs to preserve symmetry.Its (i-N) for i > N/2, actually. Remember that the point of aliasing is that you can add any *integer* multiple of N to the frequency index i (although I'd prefer to use "i" for sqrt(-1)). To get a minimal-slope interpolation, you want to add the integer multiple that minimizes the frequency, which is 0*N for i < N/2 and -1*N for i > N/2. And the N/2 component (for even N) should be set to zero. But, as the original poster discovered for himself, these difficulties are largely avoided by using the r2c (specialized real-input FFT) interface, which doesn't compute the redundant half of the spectrum in the first place. Steven G. Johnson
