Jeff When did sinc(0) become 0? Dirk jeff227 wrote:> >Jerry > >You are imagining the wrong model... > >It's no surprise that an analogiy based on a flawed model yields a > >flawed conclusion. > > > > OK, got it. However I believe this "mass model" analogy IS correct - it > has an Fc of zero. "Sinc" of Fc zero is zero. > > Useless information - just trying to gain an understanding of principles. > > Thank you for the replies.
Theory 101 - Impulse response of "perfect" LPF
Started by ●December 12, 2006
Reply by ●December 12, 20062006-12-12
>When did sinc(0) become 0?If Fc is zero then sin(2*PI*Fc*i)/PI*i is zero for any i > 0. Rune; The reason I had "infinite" in my mechanical analogy is because the "perfect" LPF requires an infinite series (e.g., sinc). I was trying to compare the two. I was trying to understand why in the mechanical case the mass doesn't move but in the DSP case it creates a sine function. When you said, "because of the P in LPF" it began to make sense. I think I answered my own question when I suggested that the mechanical example has an Fc of zero - there is no passband. In that case the sinc value (of Fc = 0) would be a constant, not a sine wave, and the analogy would make sense. (Or not?) Yes I do often try to think outside the box to bring about an understanding. When I studied higher math in college many (many) years ago it was purely academic - no one explained how it was related to anything. Much of it made absolutely no sense logically but I learned how to "solve" the equations and got through it. DSP is not my occupation, it's an interest. I am learning as I can from reading books, forums, etc. Sometimes, however, I just have to ask a question (or two or three). Thank you very much, Rune and everyone, for all your comments.
jeff227 skrev:> >When did sinc(0) become 0? > > > If Fc is zero then sin(2*PI*Fc*i)/PI*i is zero for any i > 0. > > > Rune; > > The reason I had "infinite" in my mechanical analogy is because the > "perfect" LPF requires an infinite series (e.g., sinc). I was trying to > compare the two. I was trying to understand why in the mechanical case > the mass doesn't move but in the DSP case it creates a sine function.You have just touched on the main reason why I don't like analogies: If one gets them wrong, they confuse way more than they help.> When you said, "because of the P in LPF" it began to make sense. > > I think I answered my own question when I suggested that the mechanical > example has an Fc of zero - there is no passband.Exactly.> In that case the sinc > value (of Fc = 0) would be a constant, not a sine wave, and the analogy > would make sense. (Or not?)I don't like analogies; I try to avoid them as best I can for the very reason that they cause confusion, which seems to be the case here.> Yes I do often try to think outside the box to bring about an > understanding. When I studied higher math in college many (many) years > ago it was purely academic - no one explained how it was related to > anything.Some times there is nothing to explain. Mathematics is an abstract discipline that exists on its own terms. Accept that, and you are half-way to undertsand DSP. I have seen too many good ideas go down the drains because people insisted on obtaining a "physical" understanding of mathematical concepts.> Much of it made absolutely no sense logically but I learned how > to "solve" the equations and got through it.What do you mean by "logically"? Maths is logic. Maths might not be *intuitive*, though.> DSP is not my occupation, it's an interest. I am learning as I can from > reading books, forums, etc. Sometimes, however, I just have to ask a > question (or two or three).Sure. Asking questions is one of the greatest ways to learn.> Thank you very much, Rune and everyone, for all your comments.Y're welcome. Rune
jeff227 wrote:> Wrong! A spring, damper and mass is EXACTLY equivalent to a LPF. In this > example the spring and damper are zero and the mass is infinite. > > Before you insult my intelligence take some time to think outside the > box. >Wot I don't understand is this: if the mass is infinite, that means it must be >= sizeof(TheUniverse), in which case, how is there anything left to hit it with? Richard Dobson
That's not a sinc function. sinc(x)=sin(x)/x for x!=0 = 1 for x=0, which is the limit of sin(x)/x as x->0 Dirk . jeff227 wrote:> >When did sinc(0) become 0? > > > If Fc is zero then sin(2*PI*Fc*i)/PI*i is zero for any i > 0. > > > Rune; > > The reason I had "infinite" in my mechanical analogy is because the > "perfect" LPF requires an infinite series (e.g., sinc). I was trying to > compare the two. I was trying to understand why in the mechanical case > the mass doesn't move but in the DSP case it creates a sine function. > > When you said, "because of the P in LPF" it began to make sense. > > I think I answered my own question when I suggested that the mechanical > example has an Fc of zero - there is no passband. In that case the sinc > value (of Fc = 0) would be a constant, not a sine wave, and the analogy > would make sense. (Or not?) > > Yes I do often try to think outside the box to bring about an > understanding. When I studied higher math in college many (many) years > ago it was purely academic - no one explained how it was related to > anything. Much of it made absolutely no sense logically but I learned how > to "solve" the equations and got through it. > > DSP is not my occupation, it's an interest. I am learning as I can from > reading books, forums, etc. Sometimes, however, I just have to ask a > question (or two or three). > > Thank you very much, Rune and everyone, for all your comments.
jeff227 wrote:>> When did sinc(0) become 0? > > > If Fc is zero then sin(2*PI*Fc*i)/PI*i is zero for any i > 0. > > > Rune; > > The reason I had "infinite" in my mechanical analogy is because the > "perfect" LPF requires an infinite series (e.g., sinc). I was trying to > compare the two. I was trying to understand why in the mechanical case > the mass doesn't move but in the DSP case it creates a sine function. > > When you said, "because of the P in LPF" it began to make sense. > > I think I answered my own question when I suggested that the mechanical > example has an Fc of zero - there is no passband. In that case the sinc > value (of Fc = 0) would be a constant, not a sine wave, and the analogy > would make sense. (Or not?)Only very vaguely. The analogy isn't close enough to draw conclusions from because a mass is not even close to a brick-wall filter. Two ways to model mechanical objects (springs. masses, dashpots) as electrical components make a mass either an inductor or a capacitor. One inductor does not a filter make, at least not a filter with sharp cutoff. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>Wot I don't understand is this: if the mass is infinite, that means it >must be >= sizeof(TheUniverse), in which case, how is there anything >left to hit it with?Now THAT is thinking outside the box - brilliant!!! Cheers
jeff227 wrote:>> This has no relevance to LPFs. > > > Wrong! A spring, damper and mass is EXACTLY equivalent to a LPF. ...But not *every* LPF. Your analogy depends on a "perfect" lowpass, which an inductor is not. An mass hit by an impulse moves at a rate proportional to the strength of the impulse and inversely proportional to the amount of mass. That velocity goes to zero when mass goes to infinity is no more significant here than with any other denominator. I'll embellish now what you seem to have overlooked earlier: a lowpass filter passes a range of low frequencies with no attenuation and high frequencies not at all. In practical filters, there is a transition band between those behaviors. The width of the transition in an ideal filter is zero. No isolated mass approaches LP, let alone ideal LP, behavior. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Rune Allnor wrote:> jeff227 skrev: >>> When did sinc(0) become 0? >> >> If Fc is zero then sin(2*PI*Fc*i)/PI*i is zero for any i > 0. >> >> >> Rune; >> >> The reason I had "infinite" in my mechanical analogy is because the >> "perfect" LPF requires an infinite series (e.g., sinc). I was trying to >> compare the two. I was trying to understand why in the mechanical case >> the mass doesn't move but in the DSP case it creates a sine function. > > You have just touched on the main reason why I don't like > analogies: If one gets them wrong, they confuse way more > than they help. > >> When you said, "because of the P in LPF" it began to make sense. >> >> I think I answered my own question when I suggested that the mechanical >> example has an Fc of zero - there is no passband. > > Exactly. > >> In that case the sinc >> value (of Fc = 0) would be a constant, not a sine wave, and the analogy >> would make sense. (Or not?) > > I don't like analogies; I try to avoid them as best I can for the > very reason that they cause confusion, which seems to be > the case here. > >> Yes I do often try to think outside the box to bring about an >> understanding. When I studied higher math in college many (many) years >> ago it was purely academic - no one explained how it was related to >> anything.> > Some times there is nothing to explain. Mathematics is an > abstract discipline that exists on its own terms. Accept that, > and you are half-way to undertsand DSP. I have seen too > many good ideas go down the drains because people insisted > on obtaining a "physical" understanding of mathematical concepts.More strictly speaking, mathematics is a language[1]. A precise one [3], but a language nonetheless. It is the language one must speak fluently before attempting DSP; or perhaps before attempting to understand DSP :) As with all languages, there are varying levels of proficiency and required levels of proficiency - one might get by with a mere nodding acquaintance if one is a plumber [2], but one needs a more thorough linguistic acquaintance to effectively navigate filter theory. [1] I have a BA in mathematics, and it was stated to me that 'one gets a BA because mathematics is not science, it is one of the arts'. [2] Although they tend to be very good at multiplication, especially of hours * billable rate. [3] This might well be disputed, something I won't go into in this thread :) Cheers PeteS> >> Much of it made absolutely no sense logically but I learned how >> to "solve" the equations and got through it. > > What do you mean by "logically"? Maths is logic. Maths > might not be *intuitive*, though. > >> DSP is not my occupation, it's an interest. I am learning as I can from >> reading books, forums, etc. Sometimes, however, I just have to ask a >> question (or two or three). > > Sure. Asking questions is one of the greatest ways to learn. > >> Thank you very much, Rune and everyone, for all your comments. > > Y're welcome. > > Rune >
Jerry Avins wrote:> jeff227 wrote: > >> This has no relevance to LPFs. > > > > > > Wrong! A spring, damper and mass is EXACTLY equivalent to a LPF. ... > > But not *every* LPF. Your analogy depends on a "perfect" lowpass, which > an inductor is not. An mass hit by an impulse moves at a rate > proportional to the strength of the impulse and inversely proportional > to the amount of mass. That velocity goes to zero when mass goes to > infinity is no more significant here than with any other denominator. > > I'll embellish now what you seem to have overlooked earlier: a lowpass > filter passes a range of low frequencies with no attenuation and high > frequencies not at all. In practical filters, there is a transition band > between those behaviors. The width of the transition in an ideal filter > is zero. No isolated mass approaches LP, let alone ideal LP, behavior. >I think Jerry had it right before when he said the mass/force are a (good) analogy for an integrator. The mass of the mass corresponds to the gain of the integrator. And an integrator is a low pass filter but not a very good one. The response is 6dB per octave forever. Now the op can add a few more masses to the analogy and couple them with some springs and some dashpots and we might get to a better low pass filter. Mark
