Hi In the acquisition of direct sequence spread spectrum signals with low signal-to-noise ratio and wide dynamic range.the system use all-digital quadrature demodulation of DS/SS signals.Long pseudo-noise spread spectrum codes with carrier doppler are detected by a method in which the signal is successively IF integrated,differential detected and video integrated. After correlating the incoming signal for T seconds the prompt in-phase and quadrature coherent correlator outputs can be expressed as in: I(m)=SI(m)+nI(m); Q(m)=SQ(m)+nQ(m); where m is the index of the successive inputs of the non-coherent correlation,I(m) and Q(m) are correspondingly the in-phase and quadrature values resulting from the coherent integration.SI(m) and SQ(m) are signal,nI(m) and nQ(m) are assumed to be zero mean Gaussian distribution random variables.For analytical simulations,the hypothesis is : -Hypothesis H0 corresponds to the case that only themal noise is present. -Hypothesis H1 describes the case the desired signal is present. The differential acquisition can be mathematically expressed as : Y=Sum[XI(m)XI(m-1)+XQ(m)XQ(m-1),{m,1,N}]; The signal detection analysis is done on hypothesis H0 and H1.With a given probability of false alarm,the threshold value is computed of false alarm,the threshold value is computed with hypothesis H0.The probability of detection is computed with the computed threshold value in hypothesis H1.but the pdf of H0 and H1 can't expressed with a mathematics formula.So I want to simulation this performance.Because the false alarm probability is 1e-5 or 1e-6.Importance sampling can reducing run time in this simulation.I think that it can use g-method importance sampling to simulation this system,but how to choose the weight funciton ,that is alter the statistical properties of the noise disturbution?Or still have other methods? Thanks
acquisition system with importance sampling
Started by ●December 20, 2006
Reply by ●December 20, 20062006-12-20
tatsec wrote:> Hi > In the acquisition of direct sequence spread spectrum > signals with low signal-to-noise ratio and wide dynamic range.the > system use all-digital quadrature demodulation of DS/SS signals.Long > pseudo-noise spread spectrum codes with carrier doppler are detected by > a method in which the signal is successively IF integrated,differential > detected and video integrated. > After correlating the incoming signal for T seconds the prompt > in-phase and quadrature coherent correlator outputs can be expressed as > in: > I(m)=SI(m)+nI(m); > Q(m)=SQ(m)+nQ(m); > where m is the index of the successive inputs of the non-coherent > correlation,I(m) and Q(m) are correspondingly the in-phase and > quadrature values resulting from the coherent integration.SI(m) and > SQ(m) are signal,nI(m) and nQ(m) are assumed to be zero mean Gaussian > distribution random variables.For analytical simulations,the hypothesis > is : > -Hypothesis H0 corresponds to the case that only themal noise is > present. > -Hypothesis H1 describes the case the desired signal is present. > The differential acquisition can be mathematically expressed as : > Y=Sum[XI(m)XI(m-1)+XQ(m)XQ(m-1),{m,1,N}]; > The signal detection analysis is done on hypothesis H0 and H1.With a > given probability of false alarm,the threshold value is computed of > false alarm,the threshold value is computed with hypothesis H0.The > probability of detection is computed with the computed threshold value > in hypothesis H1.but the pdf of H0 and H1 can't expressed with a > mathematics formula.So I want to simulation this performance.Because > the false alarm probability is 1e-5 or 1e-6.Importance sampling can > reducing run time in this simulation.I think that it can use g-method > importance sampling to simulation this system,but how to choose the > weight funciton ,that is alter the statistical properties of the noise > disturbution?Or still have other methods?This sounds like a composite of a spec and a homework problem. What is "importance sampling"? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Also called biased sampling , this is one of the variance-reducing techniques in Monte Carlo methods. you can see this website:http://rkb.home.cern.ch/rkb/AN16pp/node132.html "Jerry Avins =D0=B4=B5=C0=A3=BA "> tatsec wrote: > > Hi > > In the acquisition of direct sequence spread spectrum > > signals with low signal-to-noise ratio and wide dynamic range.the > > system use all-digital quadrature demodulation of DS/SS signals.Long > > pseudo-noise spread spectrum codes with carrier doppler are detected by > > a method in which the signal is successively IF integrated,differential > > detected and video integrated. > > After correlating the incoming signal for T seconds the prompt > > in-phase and quadrature coherent correlator outputs can be expressed as > > in: > > I(m)=3DSI(m)+nI(m); > > Q(m)=3DSQ(m)+nQ(m); > > where m is the index of the successive inputs of the non-coherent > > correlation,I(m) and Q(m) are correspondingly the in-phase and > > quadrature values resulting from the coherent integration.SI(m) and > > SQ(m) are signal,nI(m) and nQ(m) are assumed to be zero mean Gaussian > > distribution random variables.For analytical simulations,the hypothesis > > is : > > -Hypothesis H0 corresponds to the case that only themal noise is > > present. > > -Hypothesis H1 describes the case the desired signal is present. > > The differential acquisition can be mathematically expressed as : > > Y=3DSum[XI(m)XI(m-1)+XQ(m)XQ(m-1),{m,1,N}]; > > The signal detection analysis is done on hypothesis H0 and H1.With a > > given probability of false alarm,the threshold value is computed of > > false alarm,the threshold value is computed with hypothesis H0.The > > probability of detection is computed with the computed threshold value > > in hypothesis H1.but the pdf of H0 and H1 can't expressed with a > > mathematics formula.So I want to simulation this performance.Because > > the false alarm probability is 1e-5 or 1e-6.Importance sampling can > > reducing run time in this simulation.I think that it can use g-method > > importance sampling to simulation this system,but how to choose the > > weight funciton ,that is alter the statistical properties of the noise > > disturbution?Or still have other methods? > > This sounds like a composite of a spec and a homework problem. What is > "importance sampling"? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5==A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1= =A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5= =A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1= =A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5= =A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5=A1=A5
Reply by ●December 21, 20062006-12-21
On Wed, 20 Dec 2006 10:59:09 -0500, Jerry Avins <jya@ieee.org> wrote:>tatsec wrote: >> Hi >> In the acquisition of direct sequence spread spectrum >> signals with low signal-to-noise ratio and wide dynamic range.the >> system use all-digital quadrature demodulation of DS/SS signals.Long >> pseudo-noise spread spectrum codes with carrier doppler are detected by >> a method in which the signal is successively IF integrated,differential >> detected and video integrated. >> After correlating the incoming signal for T seconds the prompt >> in-phase and quadrature coherent correlator outputs can be expressed as >> in: >> I(m)=SI(m)+nI(m); >> Q(m)=SQ(m)+nQ(m); >> where m is the index of the successive inputs of the non-coherent >> correlation,I(m) and Q(m) are correspondingly the in-phase and(snipped)> >This sounds like a composite of a spec and a homework problem. What is >"importance sampling"? > >JerryJerry, would please stop clowning around and get down to the business of solving this problem for tatsec so that he doesn't have to? :-) :-) See Ya', [-Rick-]
