Hi there, I want to find the minimum phase spectral factor of a real autocorrelation sequence using cepstral deconvolution. However I run into problems when the spectrum has a null. Is there a way to get around this problem, or is the cepstral deconvolution doomed to fail in case of a null? Could anyone suggest me another efficient method that will take about the same time for a sequence of length ~2^13-2^14. (Could I use Levinson algorithm?) In case anyone wonders if I implement this correctly in Matlab, I run the following code: R = fft(r); Rhat = 1/2*log(R); rcep = ifft(Rhat); rcc(1) = rcep(1)/2; rcc(2:N/2) = rcep(2:N/2); rcc(N/2+1:N) = 0; Rh = exp(fft(rcc)); x = real(ifft(Rh)); P.S. r is the autocorrelation sequence, i.e. r = [1; 0.5; zeros(61,1); 0.5], for which the above problem occurs. N = 64 in this case. Thanks 1/eps :) Emre
spectral factorization using cepstral deconvolution
Started by ●December 23, 2006
Reply by ●December 23, 20062006-12-23
"emre" <eguven@ece.neu.edu> wrote in message news:SNudnbv_UrDlLRHYnZ2dnUVZ_hy3nZ2d@giganews.com...> Hi there, > > I want to find the minimum phase spectral factor of a real autocorrelation > sequence using cepstral deconvolution. However I run into problems whenthe> spectrum has a null. Is there a way to get around this problem, or is the > cepstral deconvolution doomed to fail in case of a null? Could anyone > suggest me another efficient method that will take about the same time for > a sequence of length ~2^13-2^14. (Could I use Levinson algorithm?) > > In case anyone wonders if I implement this correctly in Matlab, I run the > following code: > > R = fft(r); > Rhat = 1/2*log(R); > rcep = ifft(Rhat); > rcc(1) = rcep(1)/2; > rcc(2:N/2) = rcep(2:N/2); > rcc(N/2+1:N) = 0; > Rh = exp(fft(rcc)); > x = real(ifft(Rh)); > > P.S. r is the autocorrelation sequence, i.e. r = [1; 0.5; zeros(61,1); > 0.5], for which the above problem occurs. N = 64 in this case. > > Thanks 1/eps :) > > EmreI doubt it should ever really be zero in the real world since there is also noise of some description. Besides, spectral factorization doesn't mean anything unless you have noise in the first place!! You should always consider there to be some residual white noise besides any coloured additive noise. Tam -- Posted via a free Usenet account from http://www.teranews.com
"emre" <eguven@ece.neu.edu> wrote in message news:SNudnbv_UrDlLRHYnZ2dnUVZ_hy3nZ2d@giganews.com...> Hi there, > > I want to find the minimum phase spectral factor of a real autocorrelation > sequence using cepstral deconvolution. However I run into problems whenthe> spectrum has a null. Is there a way to get around this problem, or is the > cepstral deconvolution doomed to fail in case of a null? Could anyone > suggest me another efficient method that will take about the same time for > a sequence of length ~2^13-2^14. (Could I use Levinson algorithm?) > > In case anyone wonders if I implement this correctly in Matlab, I run the > following code: > > R = fft(r); > Rhat = 1/2*log(R); > rcep = ifft(Rhat); > rcc(1) = rcep(1)/2; > rcc(2:N/2) = rcep(2:N/2); > rcc(N/2+1:N) = 0; > Rh = exp(fft(rcc)); > x = real(ifft(Rh)); > > P.S. r is the autocorrelation sequence, i.e. r = [1; 0.5; zeros(61,1); > 0.5], for which the above problem occurs. N = 64 in this case. > > Thanks 1/eps :) > > EmreI miss-read your original post - yes - you don't need the autocorrelation - use the periodogram instead. Tam -- Posted via a free Usenet account from http://www.teranews.com
Well, this really is a filter design problem, not spectrum estimation, etc. I already assume perfect knowledge of discrete power spectrum at the beginning. My starting point is actually the autocorrelation of a deterministic (but unknown) sequence, from which I want to find the (minimum-phase) signal that results in the given autocorrelation. I hope this clarifies the problem. Thanks again, Emre>I miss-read your original post - yes - you don't need the autocorrelation->use the periodogram instead. > > >Tam
emre skrev:> Hi there, > > I want to find the minimum phase spectral factor of a real autocorrelation > sequence using cepstral deconvolution. However I run into problems when the > spectrum has a null. Is there a way to get around this problem, or is the > cepstral deconvolution doomed to fail in case of a null?Cepstrum processing is notoriously unstable, for two reasons. One reason is nulls in the spectra, as you have discovered, beacuse computing the cepstrum involves computing the logarithm of the spectrum magnitude. The second reason is that one some times need to unwrap the phase of the spectrum, which is not trivial. Rune
>Cepstrum processing is notoriously unstable, for two reasons. >One reason is nulls in the spectra, as you have discovered, beacuse >computing the cepstrum involves computing the logarithm of the >spectrum magnitude. The second reason is that one some times >need to unwrap the phase of the spectrum, which is not trivial. > >RuneThanks a lot Rune. In my specific case I have a real spectrum, so I don't need phase unwrapping, but the former issue is apparently troublesome enough.. I wish there was a computationally efficient alternative. Any suggestions? Emre
emre skrev:> >Cepstrum processing is notoriously unstable, for two reasons. > >One reason is nulls in the spectra, as you have discovered, beacuse > >computing the cepstrum involves computing the logarithm of the > >spectrum magnitude. The second reason is that one some times > >need to unwrap the phase of the spectrum, which is not trivial. > > > >Rune > > Thanks a lot Rune. In my specific case I have a real spectrum, so I don't > need phase unwrapping, but the former issue is apparently troublesome > enough.. I wish there was a computationally efficient alternative. > > Any suggestions?If the minimum hase representation is what you want, exploiting an AR(p) model springs to mind... Rune
Reply by ●December 24, 20062006-12-24
emre wrote:> I want to find the minimum phase spectral factor of a real autocorrelation > sequence using cepstral deconvolution. However I run into problems when the > spectrum has a null.You can't take the log of a null. What you can try is to add some decreasing noise floors, take the cepstrums, and interpolate the limit as the noise floor decreases, if a limit seems to exist or to just converge somewhere within your precision requirements. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Reply by ●December 25, 20062006-12-25
Hi Emre, IIRC from >20 years ago, there was an approach to cepstral deconvolution of f(n), n>=0, where there were nulls in the spectrum, that multiplied f(n) with a decaying exponential g(n)=e^(-an), for n>=0, a>0. Again, IIRC, the multiplication shifted the zeroes away from the unit circle so the the nulls were no longer present AND modified the cepstrum in a very predictable way. IIRC the cepstrum could then be modified, inverted, and the scaling by g(n) removed. I think you can work through the math (I did at the time), but I believe I saw this in Ron Schafer's MS (or is it S.M.?) disertation. If anyone remembers more detail, feel free to contibute. Dirk Dirk Bell DSP Consultant emre wrote:> Hi there, > > I want to find the minimum phase spectral factor of a real autocorrelation > sequence using cepstral deconvolution. However I run into problems when the > spectrum has a null. Is there a way to get around this problem, or is the > cepstral deconvolution doomed to fail in case of a null? Could anyone > suggest me another efficient method that will take about the same time for > a sequence of length ~2^13-2^14. (Could I use Levinson algorithm?) > > In case anyone wonders if I implement this correctly in Matlab, I run the > following code: > > R = fft(r); > Rhat = 1/2*log(R); > rcep = ifft(Rhat); > rcc(1) = rcep(1)/2; > rcc(2:N/2) = rcep(2:N/2); > rcc(N/2+1:N) = 0; > Rh = exp(fft(rcc)); > x = real(ifft(Rh)); > > P.S. r is the autocorrelation sequence, i.e. r = [1; 0.5; zeros(61,1); > 0.5], for which the above problem occurs. N = 64 in this case. > > Thanks 1/eps :) > > Emre
Reply by ●December 26, 20062006-12-26
dbell skrev:> Hi Emre, > > IIRC from >20 years ago, there was an approach to cepstral > deconvolution of f(n), n>=0, where there were nulls in the spectrum, > that multiplied f(n) with a decaying exponential g(n)=e^(-an), for > n>=0, a>0. Again, IIRC, the multiplication shifted the zeroes away > from the unit circle so the the nulls were no longer present AND > modified the cepstrum in a very predictable way. IIRC the cepstrum > could then be modified, inverted, and the scaling by g(n) removed. > > I think you can work through the math (I did at the time), but I > believe I saw this in Ron Schafer's MS (or is it S.M.?) disertation.I wouldn't be surprised if this was investigated by Schafer; I know Oppenheim has written a thesis over cepstrum processing. However, nulls is only one of the problems with cepstra. Another big problem is phase unwrapping. In order to extract the interesting pulse shapes, one needs to both unwrap the phase of the spectrum unambiguously, and also keep the FT pair of the log magnitude and unwrapped phase in sync with the requirements to causal signals. Not very easy. Rune
