PrasadBC(CISC Tech) wrote:> X(z) = 1 + az^-1+(az^-1)^2 +(az^-1)^3+.....+infinity; > .....(eq 1)Writing "+ infinity" to indicate infinitely many terms mixes up two independent notions; don't do that.> X(z) = 1/(1-az^-1); provided |az^-1|<1 => |z| >|a| > ......(eq 2) > > now X(z) can be written as X(z) = z/(z-a). > ......(eq 3) > > Now the question is what are the poles and zeros location of > X(z)???????? > > DSP Books says Zero at z = 0 Pole at z = a from (eq 3) > > but how can z=0 be substituted in the equation for X(z) = > 1/(1-az^-1) as 0 < |a| which is not in ROC and it makes the > original X(z) calculated using (eq 1) to go to infinity.No. Each term in (1) is *indeterminate*, not infinite, at z = 0. Algebraic manipulation without regard to possible singularities -- such as augmenting (2) with z to get (3) -- amounts to implicit analytic continuation, thereby defining the value at a removable singularity. Martin -- Quidquid latine scriptum est, altum videtur.
Z-Transform(poles, Zeros and ROC)
Started by ●December 26, 2006
Reply by ●December 26, 20062006-12-26
Reply by ●December 28, 20062006-12-28
> > X(z) = 1/(1-az^-1); provided |az^-1|<1 => |z| >|a| > > ......(eq 2) > > > > now X(z) can be written as X(z) = z/(z-a). > > ......(eq 3) > >equation 3 of X(z) is obtained by multiplying and dividing numerator and denominator of X(z) of equation 2 with z. It is the basics of algebra that you cant do it when z = 0. 1/(1-az^-1) is not equal to z/(z-a) at z = 0. so evaluation of the poles and zeros should be done for equations expressed in negative powers of z and not positive powers of z X(z) = 1/(1-az^-1); doesnt have zero at z = 0, Infact it doesnt have any zeros In conclusion "no zeros exist outside the Region of convergence"
Reply by ●December 29, 20062006-12-29
kee skrev:> > > X(z) = 1/(1-az^-1); provided |az^-1|<1 => |z| >|a| > > > ......(eq 2) > > > > > > now X(z) can be written as X(z) = z/(z-a). > > > ......(eq 3) > > > > equation 3 of X(z) is obtained by multiplying and dividing numerator > and denominator of X(z) of equation 2 with z. > > It is the basics of algebra that you cant do it when z = 0. > > 1/(1-az^-1) is not equal to z/(z-a) at z = 0. > > so evaluation of the poles and zeros should be done for equations > expressed in negative powers of z and not positive powers of z > > > X(z) = 1/(1-az^-1); doesnt have zero at z = 0, Infact it doesnt have > any zeros > > In conclusion "no zeros exist outside the Region of convergence"What you are say, then, is that X(z) = 1/(1-az^-1) = 1/(1-az^-1) *1 = 1/(1-az^-1) *z/z = z/(z-a) =/= X(z)... Rune
Reply by ●December 31, 20062006-12-31
On Dec 29, 11:20 am, "Rune Allnor" <all...@tele.ntnu.no> wrote:> kee skrev: > > > > > > > X(z) = 1/(1-az^-1); provided |az^-1|<1 => |z| >|a| > > > > ......(eq 2) > > > > > now X(z) can be written as X(z) = z/(z-a). > > > > ......(eq 3) > > > equation 3 of X(z) is obtained by multiplying and dividing numerator > > and denominator of X(z) of equation 2 with z. > > > It is the basics of algebra that you cant do it when z = 0. > > > 1/(1-az^-1) is not equal to z/(z-a) at z = 0. > > > so evaluation of the poles and zeros should be done for equations > > expressed in negative powers of z and not positive powers of z > > > X(z) = 1/(1-az^-1); doesnt have zero at z = 0, Infact it doesnt have > > any zeros > > > In conclusion "no zeros exist outside the Region of convergence"What you are say, then, is that > > X(z) = 1/(1-az^-1) = 1/(1-az^-1) *1 = 1/(1-az^-1) *z/z = z/(z-a) =/= > X(z)...At z=0, indeed. In the same way that: 1 = 1 * z/z = z/z =/= 1 at z = 0 -- Oli
Reply by ●January 1, 20072007-01-01
Oli Charlesworth wrote:> On Dec 29, 11:20 am, "Rune Allnor" <all...@tele.ntnu.no> wrote: > > > > > > > X(z) = 1/(1-az^-1); provided |az^-1|<1 => |z| >|a| > > > > > ......(eq 2) > > > > > > > now X(z) can be written as X(z) = z/(z-a). > > > > > ......(eq 3) > > > > > equation 3 of X(z) is obtained by multiplying and dividing numerator > > > and denominator of X(z) of equation 2 with z. > > > > > It is the basics of algebra that you cant do it when z = 0. > > > > > 1/(1-az^-1) is not equal to z/(z-a) at z = 0. > > > > > so evaluation of the poles and zeros should be done for equations > > > expressed in negative powers of z and not positive powers of z > > > > > X(z) = 1/(1-az^-1); doesnt have zero at z = 0, Infact it doesnt have > > > any zeros > > > > > In conclusion "no zeros exist outside the Region of convergence"What you are say, then, is that > > > > X(z) = 1/(1-az^-1) = 1/(1-az^-1) *1 = 1/(1-az^-1) *z/z = z/(z-a) =/= > > X(z)... > > At z=0, indeed. In the same way that: > > 1 = 1 * z/z = z/z =/= 1 at z = 0but when this is a removable singularity, i think it *is* accurate and appropriate to say something like " X(z) = 1/(1 - p*z^(-1)) has a zero at z = 0. " or simply that X(z) = 1/(1 - p*z^(-1)) = z/(z-p) = (z-q)/(z-p) where q = 0 they are, in fact, two different expressions of transfer function for the same LTI system. r b-j
