"stromhau" <stromhau@stud.ntnu.no> wrote in message news:Lq6dneTCCJl2RT_YnZ2dnUVZ_uuqnZ2d@giganews.com...> >> >>Tommy, >> >>OK - well I'm not at all sure that you really care about absolute levels > nor >>an absolute reference for this application. dB, being a ratio, can be >>scaled by adding or subtracting a constant - in which case all measures >>remain the same distance apart in dB. So, an arbitrary reference is > quite >>likely fine for what you're doing. As long as the sensor is the same > then >>intensities will vary according to their absolute levels and the > attenuation >>from the source to the sensor - which it sounds like you don't really > care >>about and only care about the levels at the sensor (microphone or .... > ). >> >>The simplest reference is no reference at all - that is use an intensity > of >>1.0 on whatever scale you're using. >>So, 20*log(I1/I2) = 20*log(I1) - 20*log(I2). >>If I2=1.0 then log(I2)=0 and you're left with 20*log(I1). >> >>Part of the problem you're having is that there can be a sound pressure >>level reference which will translate to volts according to the sensor's >>sensitivity (gain or transfer function) in volts per micropascal for >>example. At the output of a microphone you get volts and the only way to > go >>backwards to sound pressure level is to inversely apply the sensitivity > to >>the output voltage: volts/(volts/micropascal). The other way is to > simply >>relate the microphone output to 1.0v as the zero dB level and forget > about >>absolute sound pressure levels altogether - since it's related to the > volts >>by a constant factor. >> >>You could calculate the rms level in the frame time - that's a measure of > >>energy. >>Square the values, add them together, divide by the number of them and > take >>the square root for relative intensity (as micropascals or volts) or > don't >>take the square root for relative power. In either case, the dB level > will >>be the same as 20* log10(ratio) if using intensities or 10*log10(ratio) > if >>using power. >> >>If you care about comparing speakers (people) in a room then intensity >>differences will be more difficult because of distance / attenuation for > >>each speaker and the need to differentiate from one speaker to another. >>That would be a much tougher problem. >> >>Fred >> >> >> >> > > > Thank you very much for helping me out here! > > However i have another thing on my mind if you or someone else would be so > nice to help. > > I see that when people calculate short time evergy they use a time > frame(about 10 ms) and the multiply with a window function(often hanning) > and then they have a overlap between frames. Could anyone explain why ? > What i dont understand is the windowing function and the overlap of > frames. > > Let me dig this algorithm back :) : > > "The algorithm used there says ; The values in the sound are first > squared, > then convolved with a Gaussian analysis window (Kaiser-20; sidelobes > below > -190 dB)" > > Nearly the same thing but here a convolution with the windowing function > is used. Why ?It seems this is a quote out of context. If all you need is an intensity measure then why window at all? And, why have a spectral analysis at all? Windows are more likely used when there is spectral analysis. The window will tend to smooth out sharp intensity changes - which may or may not be what you want. Fred
intensity of sound/speech
Started by ●January 6, 2007
Reply by ●January 9, 20072007-01-09
