Hi all We are designing a 128TCM QAM receiver. Our idea is to take advantadge from the Digital Downconverters (DDC as GC4016 or similar) to convert from HF to baseband directly ,let's say sampling at 1MHz, then DDC (CIC + decimation filters), and then a DSP system at 50KHz sampling time where the complete receiver will be implmented. The problem we are guessing is about timing recovery. If we recover the timing at baseband (i.e. recover the 50KHz) and multiply it up to the HF sampling frequency to feed the 1MHz A/D, we will substantially increase the loop time due to the DDC path (order of milisecs). Therefore we suspect (though we don�t know for sure) that the timing recovery will fail to converge or at least will significantly worse this behaviour. Will be in this way? Do you know about any source/paper talking about the use of DDC in a QAM receiver down to baseband directly? Any other isuue that we should take care of? Thanks a lot Alex Moreno Software engineer
Timing recovery in HF
Started by ●January 11, 2007
