Hi Friends, I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. I wana interpolate by factor 6. Wht should i use, interpolation filter? Amrish.
Interpolation
Started by ●February 8, 2007
Reply by ●February 8, 20072007-02-08
amrish wrote:> I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. I wana > interpolate by factor 6. > > Wht should i use, interpolation filter? >No offense intended, but you should consider doing your own homework. If you don't have a textbook, I like Oppenheim and Schafer, but others have other opinions. What is the application of this filter? What is more important: SNR, bandwidth or performance? How much data do you have? You need the answers to these questions before you find a solution to a real world problem. There are many types of interpolation filters which would be suitable. Which you choose depends on the details of the application. Regards Marc Brooker
>amrish wrote: >> I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. I wana >> interpolate by factor 6. >> >> Wht should i use, interpolation filter? >> > >No offense intended, but you should consider doing your own homework. If>you don't have a textbook, I like Oppenheim and Schafer, but others have>other opinions. > >What is the application of this filter? What is more important: SNR, >bandwidth or performance? How much data do you have? You need the >answers to these questions before you find a solution to a real world >problem. > >There are many types of interpolation filters which would be suitable. >Which you choose depends on the details of the application. > >Regards > >Marc Brooker >First i m very new to this, i tried but i m not able to get any clear view on this. I have to do it urgently, so i dont have time to research. My application - I intention to increase the resolution of my data by 2ns, which may b required to compensate 2ns jitter. Thats what i have been told to do. How can you suggest. Data rate is 80ms/s. 14 bit output from ADC.
amrish wrote:>> amrish wrote: >>> I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. I wana >>> interpolate by factor 6. >>> >>> Wht should i use, interpolation filter? >>> >> No offense intended, but you should consider doing your own homework. If > >> you don't have a textbook, I like Oppenheim and Schafer, but others have > >> other opinions. >> >> What is the application of this filter? What is more important: SNR, >> bandwidth or performance? How much data do you have? You need the >> answers to these questions before you find a solution to a real world >> problem. >> >> There are many types of interpolation filters which would be suitable. >> Which you choose depends on the details of the application. >> >> Regards >> >> Marc Brooker >> > > First i m very new to this, i tried but i m not able to get any clear view > on this. I have to do it urgently, so i dont have time to research. My > application - I intention to increase the resolution of my data by 2ns, > which may b required to compensate 2ns jitter. Thats what i have been told > to do. How can you suggest. Data rate is 80ms/s. 14 bit output from ADC. > >First, and most importantly, upsampling will not increase your resolution. You aren't going to get any more data than what you already have. If you know this already, then you can proceed. Do you need to do this in real time? On a general purpose CPU or on a DSP? If not, then how much efficiency do you need? What kind of limitation can there be on your passband? What amount of distortion are you willing to put up with? It's impossible to hand you a recipe for doing this without knowing a bit more about your system and application. Cheers Marc Brooker
hi marc, though i am not sure of this, but interpolating this signal ie increasing the resolution by 2ns might introduce noise? APS>amrish wrote: >>> amrish wrote: >>>> I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. Iwana>>>> interpolate by factor 6. >>>> >>>> Wht should i use, interpolation filter? >>>> >>> No offense intended, but you should consider doing your own homework.If>> >>> you don't have a textbook, I like Oppenheim and Schafer, but othershave>> >>> other opinions. >>> >>> What is the application of this filter? What is more important: SNR, >>> bandwidth or performance? How much data do you have? You need the >>> answers to these questions before you find a solution to a real world>>> problem. >>> >>> There are many types of interpolation filters which would be suitable.>>> Which you choose depends on the details of the application. >>> >>> Regards >>> >>> Marc Brooker >>> >> >> First i m very new to this, i tried but i m not able to get any clearview>> on this. I have to do it urgently, so i dont have time to research. My >> application - I intention to increase the resolution of my data by2ns,>> which may b required to compensate 2ns jitter. Thats what i have beentold>> to do. How can you suggest. Data rate is 80ms/s. 14 bit output fromADC.>> >> > >First, and most importantly, upsampling will not increase your >resolution. You aren't going to get any more data than what you already >have. If you know this already, then you can proceed. > >Do you need to do this in real time? On a general purpose CPU or on a >DSP? If not, then how much efficiency do you need? What kind of >limitation can there be on your passband? What amount of distortion are >you willing to put up with? > >It's impossible to hand you a recipe for doing this without knowing a >bit more about your system and application. > >Cheers > >Marc Brooker >
On Thu, 08 Feb 2007 14:10:24 +0200, Marc Brooker <myrealname@gmail.com> wrote: (snipped)>>> >> >> First i m very new to this, i tried but i m not able to get any clear view >> on this. I have to do it urgently, so i dont have time to research. My >> application - I intention to increase the resolution of my data by 2ns, >> which may b required to compensate 2ns jitter. Thats what i have been told >> to do. How can you suggest. Data rate is 80ms/s. 14 bit output from ADC. >> >> > >First, and most importantly, upsampling will not increase your >resolution. You aren't going to get any more data than what you already >have. If you know this already, then you can proceed. > >Do you need to do this in real time? On a general purpose CPU or on a >DSP? If not, then how much efficiency do you need? What kind of >limitation can there be on your passband? What amount of distortion are >you willing to put up with? > >It's impossible to hand you a recipe for doing this without knowing a >bit more about your system and application. > >Cheers > >Marc BrookerHi Marc, you're very considerate to try to help Amrish. I always wonder about these posts that say, "What's the solution to my problem? Hurry and give me an answer because I don't have the time to learn the theory so that I can solve it on my own." See Ya', [-Rick-]
> >Hi Friends, > >I hav a signal(time_domain). 80ms/s. Sample distance = 12.5ns. I wana >interpolate by factor 6. > >Wht should i use, interpolation filter? > >Amrish. >Hi, perhaps you could try with inserting 6 samples between every two adjacent samples. The easy method is by using spline function. This works if you are working in Matlab.
