"Andor" <andor.bariska@gmail.com> writes:> On 9 Feb., 14:59, Randy Yates <y...@ieee.org> wrote: >> "Andor" <andor.bari...@gmail.com> writes: >> > On 9 Feb., 07:50, "Clay" <phys...@bellsouth.net> wrote: >> >> On Feb 8, 11:58 pm, b...@coolgroups.com wrote: >> >> >> > I have a transfer function as follows: >> >> >> > K*z^(-10) >> >> > ---------------------- >> >> > 1 - z^(-1) + K*z^(-10) >> >> >> > I'm trying to figure out for what values of K the system is stable. >> >> > Is there an easy way to do this? >> >> >> > Thanks. >> >> >> > BTW, this isn't homework. >> >> >> The values of K that make the system stable are the ones that ensure >> >> the 10 roots of the denominator polynomial are inside the unit circle. >> >> > stable <=> no poles on the unit circle! >> >> Really? So, for example, the right-handed sequence with z-transform >> >> X(z) = 1 / [(z - 1/3)(z - 2)] >> >> is stable? It doesn't have any poles on the unit circle. > > Allow me to let you answer yourself *): > > " > Hey Randy! > > This is one of those very rare occasions when you're wrong! Perhaps > you > just read the words a little too fast and thought Andor was saying > something > else, but this is very true, i.e., IN GENERAL, if the ROC includes the > unit circle, > the system is stable. I think for whatever reason most of us have been > taught in the > digital domain to consider causal sequences only, and in that case, a > stable > system must have the poles inside the unit circle since a causal > sequence > always has a ROC outside the outermost pole. > " > > Regards, > Andor > > *) From: > http://groups.google.com/group/comp.dsp/msg/395804ea55745999Hi Andor, I agree with my words to Robert in that rare scenario, but they don't apply here to myself. That's because I'm not saying the same thing Robert said. You stated that a system is stable iff there are no poles on the unit circle. This is, in general, wrong. What is true is that a stable system must have a z-transform in which the unit circle is included in the region of convergence. However, that is not what you stated, i.e., you stated nothing about the ROC, instead basing your conditions solely on the location of the poles. In other words, since your statement lacked any constraints on the ROC, we must assume it is true no matter what ROC we choose, which, by the example I gave, it is not. -- % Randy Yates % "She has an IQ of 1001, she has a jumpsuit %% Fuquay-Varina, NC % on, and she's also a telephone." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
transfer function
Started by ●February 9, 2007
Reply by ●February 9, 20072007-02-09
Randy Yates <yates@ieee.org> writes:> [...]PS: Andor, I consider this a rare scenario also. :) -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
On Feb 9, 5:58 pm, b...@coolgroups.com wrote:> I have a transfer function as follows: > > K*z^(-10) > ---------------------- > 1 - z^(-1) + K*z^(-10) > > I'm trying to figure out for what values of K the system is stable. > Is there an easy way to do this? > > Thanks. > > BTW, this isn't homework.This looks likes it's from a Root Locus problem. An open loop system with unity negative feedback and gain k in the forward path. You need a rootfinder - it's easy in Matlab. F.
Reply by ●February 10, 20072007-02-10
bob@coolgroups.com wrote:> I have a transfer function as follows: > > K*z^(-10) > ---------------------- > 1 - z^(-1) + K*z^(-10) > > I'm trying to figure out for what values of K the system is stable. > Is there an easy way to do this? > > Thanks. > > BTW, this isn't homework. >Turn it into a closed-loop problem, then do a Bode plot. It looks like you can use K*z^(-10) H_ol(z) = ----------- 1 - z^(-1) Your gain margin with K = 1 will be the reciprocal of the allowable maximum value of K. If you need precision, use a zero-finder function along with a root finder to narrow down the value of K. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●February 11, 20072007-02-11
<bob@coolgroups.com> wrote in message news:1170997093.784442.53090@m58g2000cwm.googlegroups.com...>I have a transfer function as follows: > > K*z^(-10) > ---------------------- > 1 - z^(-1) + K*z^(-10) > > I'm trying to figure out for what values of K the system is stable. > Is there an easy way to do this? > > Thanks. > > BTW, this isn't homework. >You can get the answer you need easily enough by using a root finder on the denominator polynomial, manually assigning values to K and iteratively finding a value for K that satisfies abs(roots(.))<1. You can get fancier and put the test in a loop and search for K. I was able to do the former in about 5 minutes.... that seems easy enough. Fred
