"Ron N." wrote ...> "Richard Crowley" wrote: >> CCIR 601 appears to be 4:2:2 That means that the >> chrominance data is compressed 2:1 > > Only if you regard reducing the sample rate as a > form of compression.If it weren't compression, they wouldn't bother doing it.> But then your typical 44.1kHz audio CD has also likely > been reduced in sample rate from 48 or 96 kHz as > recorded in the studio. Is that compression?Many would say "yes".> Or just an appropriate choice of filtering and data format?Selecting a sample rate always performs some sort of "compression". One could argue that setting the sample rate of audio merely selects what you want your HF cutoff to be. OTOH, purposely digitally sub-sampling (or analog band- width-limiting) the color part of the image is a data-saving perceptual shell game similar to the lossy compression done by MP3, AAC, Ogg, et.al.> The chrominance in 601 is reduced to a bandwidth > that better matches the typical human perceptual > bandwidth of the luminance channel.And yet the casual observer can tell the difference between full-bandwidth RGB and reduced-color rez video transmission schemes when viewed side-by- side.
Uncompressed Digital Video vs. Uncompressed Digital Audio
Started by ●February 12, 2007
Reply by ●February 13, 20072007-02-13
Ron N. wrote: (snip)> As for storing uncompressed formats, didn't amateur radio > types try storing monochrome (very) slow scan video on > audio tape?There was a story in Popular Science many years ago that I still remember about storing fast scan (normal TV) video on 0.25 inch audio tape. It ran the tape at 120in/s, with the cover page of the story showing the results after the tape breaks. They heat the record/play head to reduce friction. 10 inch tape reels were normally used to get a reasonable time. I don't believe it ever got popular. -- glen
glen herrmannsfeldt wrote:> There was a story in Popular Science many years ago that I > still remember about storing fast scan (normal TV) video > on 0.25 inch audio tape. It ran the tape at 120in/s, > with the cover page of the story showing the results after > the tape breaks. They heat the record/play head to reduce > friction. 10 inch tape reels were normally used to get a > reasonable time. I don't believe it ever got popular. >When I was a kid, I was trying to record the video signal from TV to a modified conventional cassette tape recorder. For that purpose, the recorder was operating in the fast forward mode, so the tape speed was about 2m/s. I was able to establish the horizontal and vertical sync,and even to see something, however I woudn't call this a picture. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
glen herrmannsfeldt wrote:> Ron N. wrote: > > (snip) > >> As for storing uncompressed formats, didn't amateur radio >> types try storing monochrome (very) slow scan video on >> audio tape? > > There was a story in Popular Science many years ago that I > still remember about storing fast scan (normal TV) video > on 0.25 inch audio tape. It ran the tape at 120in/s, > with the cover page of the story showing the results after > the tape breaks. They heat the record/play head to reduce > friction. 10 inch tape reels were normally used to get a > reasonable time. I don't believe it ever got popular. > > -- glen >I used to use 2" wide (so far more robust) instrumentation tape at 120 inches/second. The drives used air bearing guides, to reduce friction, but dragged the tape across ordinary heads with no special method of dealing with heat or friction. They did have elaborate arrangements to stabilise the tape as it passed over the heads, though. A 15" reel of tape ran for about 16 minutes, and had 24 or 28 tracks. Those drives used to be the mainstay of instrumentation in a number of fields (mostly military). They could put a fair quality TV picture onto each of their 24 tracks. Several people made drives of that kind - Ampex, Honeywell, Enertec, and others. We used to fly compact versions, while large floor standing ones were used in the lab. So, the popular science article was not describing anything crazy. I just wonder about handling 0.25" tape at that speed. Regards, Steve
"Richard Crowley" <rcrowley@xp7rt.net> wrote in message news:53eq2sF1rcdkaU1@mid.individual.net...> Selecting a sample rate always performs some sort of > "compression".Not at all. Compression involves a manipulation of data *within* the range under consideration. (either lossy compression or lossless) If extraneous data falls completely outside the required range, then no compression is necessary within that range.> One could argue that setting the sample > rate of audio merely selects what you want your HF > cutoff to be.No, there would be no *real* argument at all, since that *is* what it does. MrT.
Reply by ●February 14, 20072007-02-14
"Mr.T" wrote ...> > "Richard Crowley" wrote ... >> Selecting a sample rate always performs some sort of >> "compression". > > Not at all. Compression involves a manipulation of data *within* the range > under consideration. (either lossy compression or lossless) > If extraneous data falls completely outside the required range, then no > compression is necessary within that range. > >> One could argue that setting the sample >> rate of audio merely selects what you want your HF >> cutoff to be. > > No, there would be no *real* argument at all, since that *is* what it > does.And limiting the bandwidth is a form of "data compression". It was invented before our grandparents were born in the days of early telephony.
Richard Crowley wrote: ...> And limiting the bandwidth is a form of "data compression". > It was invented before our grandparents were born in > the days of early telephony.Call it data reduction if you wish. "Compression" is generally given a more restricted meaning. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
