Tim Wescott <tim@seemywebsite.com> wrote in news:sJGdnYoniK7nXU7YnZ2dnUVZ_vLinZ2d@web-ster.com:> and you can bet that you'll never get the MathWorks to > cough up their code. >Actually, Mathworks makes no bones about using FFTW. Very well known, and well tested. -- Scott Reverse name to reply
Complex FFT in DSP vs Matlab
Started by ●February 14, 2007
Reply by ●February 15, 20072007-02-15
Scott Seidman <namdiesttocs@mindspring.com> wrote in news:Xns98D8899C85DDEscottseidmanmindspri@130.133.1.4:> Tim Wescott <tim@seemywebsite.com> wrote in > news:sJGdnYoniK7nXU7YnZ2dnUVZ_vLinZ2d@web-ster.com: > >> and you can bet that you'll never get the MathWorks to >> cough up their code. >> > > Actually, Mathworks makes no bones about using FFTW. Very well known, > and well tested. >Oops, should read a bit further down before replying. -- Scott Reverse name to reply
Do both implementations use a rectangular window? That would effect your main lobe width and side lobe heights. There is also the effect of zero-padding. If I'm not mistaken, increasing the FFT length by zero-padding will create interpolative effects in the frequency resolution. Are you using the same fft lengths? -marc
"marc" <marc.robins@gmail.com> wrote in message news:1171577308.283470.185100@m58g2000cwm.googlegroups.com...> Do both implementations use a rectangular window? That would effect > your main lobe width and side lobe heights. There is also the effect > of zero-padding. If I'm not mistaken, increasing the FFT length by > zero-padding will create interpolative effects in the frequency > resolution. Are you using the same fft lengths? > > -marcIn Matlab "fft" has more than one form: fft(x) is of the length of x fft(x,n) is of the length n, no matter the length of x. So, if the second form is used then it could well be different than another implementation on a vector of the length of x. Also, "fft" often means or requires the length be a factor of 2 and a shorter length vector might be zero padded to make up the difference. I don't know what the TI DSP library does... Fred Fred
