Al wrote:> wow, thanks for your reply, I'll have a look at it. > Now I'm not taking care about the phase so I could discard those phase > rotations I think. Since now I was just performing 8 FFTs of 64 blocks > of consecutive data (not mixed as you said) and summing up them all, > but probably that's not correct >Nope, the phase rotations are required as part of the FFT computation, they are done between the smaller FFTs. That mixed radix algorithm is simply a decomposition of the Fourier transform to allow you to compute a larger FFT using smaller kernels. You need to do this in order to get the spectra of a 512 point FFT. If you skip the phase rotations, you are basically doing a 2D FFT on data in an 8x64 array.
FFT in blocks
Started by ●February 16, 2007
Reply by ●February 16, 20072007-02-16
