HI , i am satish doing my MS. I need c programming code for audio signal compression. The code should be compatible to run on TMS320c55x platform. The software used for this is "code composer studio". Can any help me out fr getting the code for the above topic. Regards satish
hi
Started by ●March 5, 2007
Reply by ●March 5, 20072007-03-05
satish wrote:> HI , i am satish doing my MS. I need c programming code for audio > signal compression. The code should be compatible to run on TMS320c55x > platform. The software used for this is "code composer studio". Can > any help me out fr getting the code for the above topic."Compression" has two meanings: reduction in size (or bit rate), and reduction of volume range. No one can help you without knowing which you need. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
satish wrote:> HI , i am satish doing my MS. I need c programming code for audio > signal compression.There are two types of compression commonly applied to audio signals: - dynamic range compression - data rate compression You should really specify which you are talking about. However, people rarely get complete working code just by asking for it here. They often get advice, pointers to useful papers/books/ websites or simply pointers for the right direction. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ "Linux is produced to be used, whereas the others are produced to be sold" -- Bobby D. Bryant
On Mar 5, 2:32 pm, "satish" <prakash.na...@gmail.com> wrote:> HI , i am satish doing my MS. I need c programming code for audio > signal compression. The code should be compatible to run on TMS320c55x > platform. The software used for this is "code composer studio". Can > any help me out fr getting the code for the above topic. > > Regards > satishI would start at the TI website. They have many pointers to commercial vocoders (assuming that is what you mean by compression). There are free implementations floating around for some of the older vocoders, but I believe you'll find that isn't the case for modern algorithms that you would find in a mobile phone. John
Jerry Avins wrote:> satish wrote: >> HI , i am satish doing my MS. I need c programming code for audio >> signal compression. The code should be compatible to run on TMS320c55x >> platform. The software used for this is "code composer studio". Can >> any help me out fr getting the code for the above topic. > > "Compression" has two meanings: reduction in size (or bit rate), and > reduction of volume range. No one can help you without knowing which you > need.And reduction in size has different meanings. Do you want lossless compression, like FLAC? Gentle general purpose compression, like MP3? Aggressive source specific compression, like G.729? Steve
