Dear comp.dsp, Though I did try looking at the previous posts related to this, my question has not been answered. So, here goes: I have a simple OFDM+QPSK code wherein I use one symbol to estimate the channel and do the zero forcing (multiply by reciprocal of channel FFT) to get derotated QPSK symbols. Note that the data is uncoded and not interleaved. 1. BER for QPSK+OFDM in an AWGN channel is identical to the BER of plain BPSK/QPSK in AWGN without multipath. This is confirmed by my simulation, and a previous comp.dsp post. 2. Now, if I start making the channel a fixed FIR channel of length even more than 1, I notice a huge slump in the BER. Is this to be expected? Is this due to the noise becoming larger due to the zero forcing solution? 3. The performance doesn't change much even if I let the cyclic prefix become smaller/larger than the channel; essentially, it's the same as the above slumped value. Could this be due to a mistake in my code? Thanks. Kumar
BER in OFDM
Started by ●March 13, 2007
Reply by ●March 13, 20072007-03-13
Kumar Appaiah wrote:> > I have a simple OFDM+QPSK code wherein I use one symbol to estimate > the channel and do the zero forcing (multiply by reciprocal of channel > FFT) to get derotated QPSK symbols. Note that the data is uncoded and > not interleaved. > > 1. BER for QPSK+OFDM in an AWGN channel is identical to the BER of > plain BPSK/QPSK in AWGN without multipath. This is confirmed by my > simulation, and a previous comp.dsp post. > > 2. Now, if I start making the channel a fixed FIR channel of length > even more than 1, I notice a huge slump in the BER. Is this to be > expected? Is this due to the noise becoming larger due to the zero > forcing solution?In general, a channel length > 1 equates to a frequency-selective channel. Therefore, as you would expect, the received power on certain sub-carriers will be reduced, effectively decreasing their SNR. Therefore, even when equalised, these sub-carriers will experience a worse BER. Even if their SNR is only a few dB lower, their BER may be increased 10 or 100 times. If this is the case, then these sub- carriers will be providing the majority of the total BER. In other words, to a first approximation, the overall BER of an uncoded OFDM system is dominated by the BER of the worst sub-carriers.> 3. The performance doesn't change much even if I let the cyclic prefix > become smaller/larger than the channel; essentially, it's the same as > the above slumped value. Could this be due to a mistake in my code?Possibly! -- Oli
Reply by ●March 14, 20072007-03-14
Oli Charlesworth wrote:> In other words, to a first approximation, the overall BER of an > uncoded OFDM system is dominated by the BER of the worst sub-carriers.Thanks for the explanatio.> > 3. The performance doesn't change much even if I let the cyclic prefix > > become smaller/larger than the channel; essentially, it's the same as > > the above slumped value. Could this be due to a mistake in my code? > > Possibly!OK, I'm checking. Thanks a lot. Kumar
