function call which returns parameters take a long time
Started by (news) May 26, 2004
Hi everybody,
I work on DSP C2000 and I don't understand:
In release mode, a call to a function which returns parameters takes
considerably more time than if I put direcly the same code in the main
program.
The difference is approximately 1000 times !
I think the problem is when the function returns the parameters.
I program in C and I use the default linker file in code composer studio.
I must execute my program in less time !
Thanks
Max
(news) wrote:
> Hi everybody, > I work on DSP C2000 and I don't understand: > In release mode, a call to a function which returns parameters takes > considerably more time than if I put direcly the same code in the main > program. > The difference is approximately 1000 times ! > I think the problem is when the function returns the parameters. > I program in C and I use the default linker file in code composer studio. > I must execute my program in less time ! > Thanks > Max > >
What are you returning that's making it 1000 times slower? My experience with Code Composter doesn't indicate that it is nearly that bad. Are you benchmarking this with a routine that does nothing? If so Code Composter may be optimizing your in-line stuff away entirely -- this would certainly account for a 1000x speed difference, and Code Composter will do that even when you tell it to turn optimizations off. Generally Code Composter is very good at removing dead code but only if you don't call a function. In C you mean "which returns a parameter" -- yes? If you are returning a structure the function return would be doing a memory copy, which can take a lot of time. If this is what you are doing then you probably want to pass the structure pointer and operate on it directly within the function. You should try compiling to assembly language, then pick through the output and figure out what it's doing to your code. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@wescottnospamdesign.com> wrote:
> > ... Code Composter...
I like that one. Do you do a lot of gardening, Tim? :-) --smb
Stephan M. Bernsee wrote:
> Tim Wescott <tim@wescottnospamdesign.com> wrote: > >>... Code Composter... > > > I like that one. Do you do a lot of gardening, Tim? > > :-) > > --smb
I was wondering how long it would take someone to notice -- I've been calling it that on this list for a couple of months. And yes, I do garden. The project that motivated me to invent the term was too busy, but some day I want to hack into the Code Composer executable so I can insert the 't' in the splash screen (with nice bright red edit marks, of course). Unfortunately that would not only demonstrate a dangerously high level of competence with Windows programming, which is something I try hard to avoid but it would also require that I _develop_ a higher level of Windows programming competence, which is something I avoid harder yet. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Thanks for your answer.
"return parameters" meant all this cases :
- a parameter which is returned with the "return" keyword.
- a parameter returned by argument out in function.
The result is the same when I use each case.
Excuse me, I didn't precise that.
I pass parameter by pointer or by reference (in C++) and the parameter
is a structure (composed by 4 doubles) or an object (in C++).
First I programed in C++, so I tryed in C but the performances are the
same.
There is no difference in Debug mode but in Release mode.
Program execution is too long for my application so I search what
takes time. And I call many times this function.
Below I give you an exemple of my program.
Thanks a lot
Max
Program (in C++):
typedef struct{
double	w;
double	x;
double	y;
double	z;
}quat;
void multiplication(quat& q,quat& q1, quat& q2)
	q.w = q1.w * q2.w - q1.x * q2.x - q1.y * q2.y - q1.z * q2.z;
	q.x = q1.w * q2.x + q1.x * q2.w + q1.y * q2.z - q1.z * q2.y;
	q.y = q1.w * q2.y - q1.x * q2.z + q1.y * q2.w + q1.z * q2.x;
	q.z = q1.w * q2.z + q1.x * q2.y - q1.y * q2.x + q1.z * q2.w;
int main()
	quat q1, q2, q;
	q1 = ini(1.25,0.36,2.56,8.9);
	q2 = ini(4.25,2.63,5.36,7.2);
	q = ini(0,0,0,0);
	while(1)
		// First possibility:
                multiplication(q,q1,q2);
                // Second possibility; directly in code:
q2.z;
q2.x;
q2.w;
Tim Wescott <tim@wescottnospamdesign.com> wrote in message news:<10b9n40dhhhr6a@corp.supernews.com>...
> > What are you returning that's making it 1000 times slower? My > experience with Code Composter doesn't indicate that it is nearly that bad. > > Are you benchmarking this with a routine that does nothing? If so Code > Composter may be optimizing your in-line stuff away entirely -- this > would certainly account for a 1000x speed difference, and Code Composter > will do that even when you tell it to turn optimizations off. Generally > Code Composter is very good at removing dead code but only if you don't > call a function. > > In C you mean "which returns a parameter" -- yes? > > If you are returning a structure the function return would be doing a > memory copy, which can take a lot of time. If this is what you are > doing then you probably want to pass the structure pointer and operate > on it directly within the function. > > You should try compiling to assembly language, then pick through the > output and figure out what it's doing to your code.
Max wrote:
> Thanks for your answer. > "return parameters" meant all this cases : > - a parameter which is returned with the "return" keyword. > - a parameter returned by argument out in function. > The result is the same when I use each case. > Excuse me, I didn't precise that. > > I pass parameter by pointer or by reference (in C++) and the parameter > is a structure (composed by 4 doubles) or an object (in C++). > First I programed in C++, so I tryed in C but the performances are the > same. > There is no difference in Debug mode but in Release mode. > > Program execution is too long for my application so I search what > takes time. And I call many times this function. > > Below I give you an exemple of my program. > > Thanks a lot > > Max > > Program (in C++): > > typedef struct{ > double w; > double x; > double y; > double z; > }quat; > > void multiplication(quat& q,quat& q1, quat& q2) > { > q.w = q1.w * q2.w - q1.x * q2.x - q1.y * q2.y - q1.z * q2.z; > q.x = q1.w * q2.x + q1.x * q2.w + q1.y * q2.z - q1.z * q2.y; > q.y = q1.w * q2.y - q1.x * q2.z + q1.y * q2.w + q1.z * q2.x; > q.z = q1.w * q2.z + q1.x * q2.y - q1.y * q2.x + q1.z * q2.w; > } > > int main() > { > quat q1, q2, q; > q1 = ini(1.25,0.36,2.56,8.9); > q2 = ini(4.25,2.63,5.36,7.2); > q = ini(0,0,0,0); > while(1) > { > // First possibility: > multiplication(q,q1,q2); > > // Second possibility; directly in code: > q.w = q1.w * q2.w - q1.x * q2.x - q1.y * q2.y - q1.z * > q2.z; > q.x = q1.w * q2.x + q1.x * q2.w + q1.y * q2.z - q1.z * q2.y; > q.y = q1.w * q2.y - q1.x * q2.z + q1.y * q2.w + q1.z * > q2.x; > q.z = q1.w * q2.z + q1.x * q2.y - q1.y * q2.x + q1.z * > q2.w; > > [...] > } > } > > > > > > Tim Wescott <tim@wescottnospamdesign.com> wrote in message news:<10b9n40dhhhr6a@corp.supernews.com>... > >>What are you returning that's making it 1000 times slower? My >>experience with Code Composter doesn't indicate that it is nearly that bad. >> >>Are you benchmarking this with a routine that does nothing? If so Code >>Composter may be optimizing your in-line stuff away entirely -- this >>would certainly account for a 1000x speed difference, and Code Composter >>will do that even when you tell it to turn optimizations off. Generally >>Code Composter is very good at removing dead code but only if you don't >>call a function. >> >>In C you mean "which returns a parameter" -- yes? >> >>If you are returning a structure the function return would be doing a >>memory copy, which can take a lot of time. If this is what you are >>doing then you probably want to pass the structure pointer and operate >>on it directly within the function. >> >>You should try compiling to assembly language, then pick through the >>output and figure out what it's doing to your code.
This shouldn't have a significant difference in execution speed, unless the optimizer is getting ahold of it. _Are_ you just benchmarking at this point, or are you actually doing something with q? If you don't do anything with q then the optimizer will see that it's value is never used and it will snip out the code. You need to go look. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
> Stephan M. Bernsee wrote: > > > Tim Wescott <tim@wescottnospamdesign.com> wrote: > > > >>... Code Composter... > > > > > > I like that one. Do you do a lot of gardening, Tim? > > > > :-) > > > > --smb > > I was wondering how long it would take someone to notice -- I've been > calling it that on this list for a couple of months.
Most people don't notice spelling errors at all. Yuo can canhge the oredr of lettres in a wrod to a graet exntet bfeore it bcoeems unraedblae. As long as you leave the first and last as they are, that is... I generally skip threads that deal with hardware-specific questions. Don't know what made me read this one... but usually, if I open up a book or any paper I would immediately spot a spelling error (even if it's just one in the whole thing you can be sure I'll see it within the first five minutes without looking for it). And yes, I also garden a lot. And it's the same there: if there's one four-leaved clover you can be sure I'll find it, again, without actually searching for it :-) That's my particular piece of luck I guess... not that it would be very useful except for driving all graphics and text people crazy...
> And yes, I do > garden. The project that motivated me to invent the term was too busy, > but some day I want to hack into the Code Composer executable so I can > insert the 't' in the splash screen (with nice bright red edit marks, of > course).
Can't you just patch the bitmap file? I don't know Code Composer, but usually, the splash screen is a plain bitmapped graphics.
> Unfortunately that would not only demonstrate a dangerously high level > of competence with Windows programming, which is something I try hard to > avoid but it would also require that I _develop_ a higher level of > Windows programming competence, which is something I avoid harder yet.
Same here... :-) --smb
I think you are maybe right. For the tests I always do the same
calcul. I suppose the compiler deletes many of them. But he doesn't do
that when code is in a function.
Unfortunately I think this DSP is too slow for my application. I
thought to find what took time in calculs.
Thanks for your answers.
Max
